View Poll Results: Is there a way I can switch the end caps or should I look for a different skewer?
Do I need to search for a trainer QR with a custom or smaller axle online
1
100.00%
Switch the parts between the two different QR
0
0%
Voters: 1. You may not vote on this poll
Switching parts from one QR to another
I am trying to set up an old steel bike of mine on a trainer however I needed a new qr skewer as the end caps didn’t fit the trainer. The axle it to long to fit the bike properly as the width is noticeably shorter so the axle will stick out of the end cap preventing the bike from mounting correctly. So I was planning on taking the end cap and lever end of the new axle and put it on my old one that way it fits the bike correctly. But I’m having trouble taking off the enclosed cam on the qr I got with the trainer. Any methods or tools you might recommend?
Quoted: 4585 Post(s)
Liked 1,740 Times
I don't understand how parts are both too long and too short, but all QR skewers are not made with identical parts, so just switching them is like putting a Toyota piston in a Ford engine.
Just buy a skewer. They are cheap. Trainer skewers are usually stocked by bike shops.
If you have a narrow hub, and the trainer has no hole in the ends for the skewer to stick into, you can find old skewers that should work (all metal), or you can cut the one you have.
Likes For Kontact:
Quoted: 4236 Post(s)
Liked 3,963 Times
Wasn't this recently asked about? Maybe the OP is shopping for the answer they want?
I wouldn't mess with the chance of a wheel coming loose or not being tightened well enough. As others have said (here and elsewhere) different QR brands will often have their own dimensions of skewer cam and end cap and the default is they are not interchangeable between brands (or even models within a brand). The adjusting nut end cap is fine to swap as long as the threading is the same (and many are M5 but I wouldn't assume that till checked).
This is just one more example where the component designers/manufacturers and the accessory ones don't "work with each other" before they make something.
For the low cost of a replacement skewer, and the high possible cost of failure, to not do the right thing is being penny foolish.
I'd answer your poll but #1 doesn't make sense to me. Is the problem that the trainer won't close up enough to grab the replacement skewer ends fully? or the skewer threaded end will stick out too far and thus bottom out on the trainer's cupping clamp ends before the skewer cap seats fully? or is there something else going on (you use the word "axle" when you might have meant the skewer's shaft)?
If it's that the skewer end bottoms out in the trainer clamping cup then just cut it down some. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 5957 Post(s)
Liked 2,867 Times
First of all, why is this a poll?
Otherwise, if I understand correctly, the original skewer shape is wrong, (or it's too nice to ruin) for the trainer. The one that came with the trainer is too long and sticks out past the nut.
Calls for a hack saw, not a complicated mix and match of skewer parts.
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,349 Times
dp_i83 This is a case where a picture is worth a 1000 words. You can't post one, but you can upload some and let us know when you uploaded and someone will do a pic assist.
Likes For Chuck M:
