I'm stumped HELP!
I'm stumped HELP!
I have a Vilano Diverse 3.0 24 speed Hybrid with the el cheapo Shimano Tourney TX rear derailleur. I put a new chain on a month ago and I always ride in Mid-range. I noticed that if I used any gear other then 2,3,4 & 5, the chain would rub on the Front Derailleur guide and sometimes jam up.
Now yesterday on my ride, the chain locked up & the rear Derailleur is horizontal (the two small guide wheels) and the chain is so tight that I can do nothing with it and cannot shift.
I can't post a pic until I have 10 posts.
Any help will be greatly appreciated.
KF
KF
Quoted: 564 Post(s)
Liked 424 Times
Needs a complete drivetrain verification by the book:
-check RD dropout alignment with a DAG-3
-check RD alignment and screws
-check FD height, alignment and screws
-verify chain is a narrow for 6-8s (sometimes folks grab 1s chains because they are cheep).
-Once all above done, then finally do the RD+FD cables
Videos out there to tell you what to do exactly.
If you get stuck, a basic tune up at the LBS is all that is required.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 886 Post(s)
Liked 1,235 Times
Welcome to Bike Forums
post 2-3 good pictures in the gallery.
We will go find them and place them in this thread for you.
Barry
Barry
Quoted: 6329 Post(s)
Liked 4,917 Times
Yeah, that's messed up. Here is one of your pictures and a link below to your album with the others..
https://www.bikeforums.net/g/album/33476731
Welcome to BF
Welcome to BF
Quoted: 3606 Post(s)
Liked 3,023 Times
Looks like the chain is way too short to me.
Likes For smd4:
Quoted: 4554 Post(s)
Liked 1,697 Times
The chain is too short.
Likes For Kontact:
Quoted: 5900 Post(s)
Liked 2,772 Times
+1
Chain's unbelievably short.
Unbelievable because I'm amazed you lasted a month before this happened.
When you cut it longer, the minimum acceptable length is so it can loop the big/big combination with an inch to spare.
Likes For FBinNY:
Liked 3,023 Times
Curious as to how this chain was sized...
Likes For smd4:
LR÷P=HR
Quoted: 886 Post(s)
Liked 1,235 Times
I don't think it's been mentioned, but your chain is TOO SHORT
THIS is how to size the chain to length. <<clickable link
Barry
Barry
Likes For Barry2:
Liked 1,697 Times
Barry
Barry
Likes For Kontact:
LR÷P=HR
Quoted: 886 Post(s)
Liked 1,235 Times
OK, fun time over..
After all this is their first ever post at Bike Forums.
King Friday , Welcome to bike forums (and our sad sense of humor)
When sizing a chain it needs to be long enough for the longest/worst case.
The chain needs to be long enough for the big ring at the front and the big cog at the back at the same time, plus a bit for safety.
The link I sent above has a video demonstrating how to achieve this.
Your new chain has been cut at the incorrect length.
To fix it you could rejoin the piece removed with a 7 speed master link then cut the chain to the correct length.
All the best
Barry
PS: Master Links come in different widths, you do need one for the correct number of cogs at the rear. Your's appears to be a 7 speed at the rear.
All the best
Barry
Likes For Barry2:
Quoted: 858 Post(s)
Liked 1,094 Times
And I'll add that you will almost always have to remove some links with any chain you buy as they are usually sold in 2 or 3 generic lengths and most bikes require a different length than what is in the package. Try the sizing method in post #9. I wouldn't ride your bike until you get the chain properly sized as it may safely work in several gears but one mistaken shift into a non-working gear could trash your derailleur, chain and spokes.
Slightly different model of the same rear derailleur below. I also suspected chain too short. However, my own philosophy is not, to make the chain as short as possible (big/big combo plus a couple links), but as long as possible and still be able to take up the slack on the small/small combo, that way, the derailleur cage is not wound up as tight, makes things like cage springs and derailleur pulley bores last better. It also gives me enough chain to upgrade from my 30 low cog to a 32 or perhaps 34.
big/big:
small/small:
big/big:
small/small:
Likes For Duragrouch:
Liked 3,023 Times
Liked 1,697 Times
Any fool would know that.
It isn't appropriate for 1x because the derailleur geometry is optimized for a certain amount of chain pull - something that a double cannot do
Quoted: 548 Post(s)
Liked 482 Times
Small/small is fine if you do it right, you're setting the chain as long as it can be which can be useful if you might want to fit a larger ring or sprocket. Big/big is harder to get wrong, you're setting the chain as short as it can be which is good for reducing chain slap and weight. Whichever method you use, you have to check that the gears operate through the full range without any under- or over-tension when you're done (including cross-chaining, although the forbidden gears needn't be as crisp and smooth as the preferred combinations). Any deviation from this is technically incorrect, although it might be a useful bodge to make a derailleur work beyond its actual range it's not something you should do on a customer's bike without being sure that they understand what the workaround entails.
Liked 2,772 Times
But you have to follow the entire set of instructions, understanding that small/small is used to determine the MAXIMUM chain length, and big/big the MINIMUM.
Also, that the MINIMUM is the more critical consideration.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
That might have been me. I've always sized chains this way, preferring to carry the longest chain that works.
Liked 2,772 Times
Will the real fool please stand up.
FB
Chain-L site
FB
Chain-L site
Liked 1,697 Times
I resemble that remark.
I thought I was being original. But I went long, for reasons stated above (by me, and others), tried it out, worked fine.
I also don't like having the RD cage wound so far forward that it's barely behind its limit-stop, that just makes me worry about some road hazard or my right heel or whatever that yanks the bottom chain run down. I like being away from the limit-stops to prevent damage.
Small small is best as long as you know the total capacity doesn't exceed the derailleur capacity. Max chain length puts less wear on the drivetrain and future proofs the bike against a larger cassette being added without accounting for chain length.
Liked 3,023 Times
And all this time I’ve just followed the manufacturer’s instructions.
Silly me.
Silly me.
Liked 2,772 Times
