Low profile suspension seatpost
My wife and I have a Litespeed tandem. She would like a suspension seatpost but there is not enough room for one. It's only 2 1/4" or 57mm from the seatpost clamp to the top of the rails on her seat. The Cane Creek Thudbuster requires 4" and most of the other suspension seatposts don't even specify this dimension. I told her we could put her in the height stretcher like Barney Fife, but she did not agree!
Does anyone know of a low profile suspension seatpost? 27.2mm THANKS
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 192 Post(s)
Liked 111 Times
Cane Creek makes a second type of suspension seatpost which is smaller. https://canecreek.com/product/eesilk-plus/
Cheers, Mike
Cheers, Mike
Quoted: 567 Post(s)
Liked 424 Times
If seapost height is critical because of a large frame, you may want to consider another saddle instead.
Comfort saddles have come a long way because of baby boomer uprighters and from all the ones I have tried, they work just as well a seatpost.
Unless you combine comfort saddle AND spring seatpost That's going for the Cadillac.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 886 Post(s)
Liked 1,235 Times
I replaced my wife's saddle with a Zeta Ultima and never heard another word of complaint.
With a 30day risk free, it might be worth a look.
Barry
Barry
Quoted: 608 Post(s)
Liked 697 Times
Consider shorter crank arms in addition to the suspension seatpost.
(stay with me here)
If she is short or shorter inseam, she might require a shorter crankarm set, maybe 160mm, which would require a seat height increase making more room for a suspension seat post.
If the shorter crank arms ARE necessary, it might remove the need for a suspension post due the reduction of pelvic deflection needed for a too long crank arm with too short an inseam.
https://www.applemanbicycles.com/res...-crank-length/
(stay with me here)
Likes For CrimsonEclipse:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 142 Post(s)
Liked 317 Times
It may not work w/o at least swapping in a thinner profile saddle, but I have this Ultimate Vybe that is considerably more compact and lighter than the Cane Creek.
https://www.exposure-use.com/Brands/...atpost-ULTVYBE
Not a lot of room to work with here.
Tranzx makes one that is quite compact. I use it on my touring bike.
https://na.tranzx.com/products/antis...uspension-post
