Fork swap sketchy
Fork swap sketchy
Hi all. I got my hands on a Giant Boulder and took off the super low end suspension fork and replaced it with a rigid that I had laying around. I tried to reuse all the parts that came off the bike but wound up with two rubber washers that didn’t seem to fit right. They would wind up squished a protruding, like. Bad-back disc. It made the front end squishy and unstable. So I heated them since they were “part of” the suspension for that I removed. I installed the non-rubberized rigid fork and when I tighten the stem nut it goes from “totally sloppy” to “no free rotation” and never hits that sweet spot where it “works right”. Any thoughts?
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
Quoted: 4554 Post(s)
Liked 1,697 Times
I would think that they were, but when I tried to put them in there I got the sqishing out the sides. The rigid fork had a fixed shelf on the steering tube shaft. This now directl abuts the non-ball bearing surface of the bottom headset bearing, the ball bearings facing “up” into the head tube.
2023 Rad Rover 6
2023 Rad Rover 6
Quoted: 858 Post(s)
Liked 1,094 Times
A photo of the parts assembled and disassembled would help us see what's going on. Might be an incompatible headset or installed wrong or ??
LOL, yea those are the so things I was thinking, leaning more twos the later to be honest. I’ll try to get some pics later on
2023 Rad Rover 6
2023 Rad Rover 6
Likes For bboy314:
Quoted: 5904 Post(s)
Liked 2,772 Times
Echoing the others here, it sounds more like a headset or assembly problem than a fork problem.
FWIW the frame and headset only care about the fork from the crown up. What's below, rigid, suspension or otherwise doesn't factor. except for blade/stanchion length to preserve overall geometry.
Quoted: 523 Post(s)
Liked 684 Times
The squishy rubber things are seals, they may not fit the rigid fork properly, also, unless you are sure they are the same, you have to move over all the headset parts.
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Caged Bearings right side up?
Likes For dedhed:
Liked 1,697 Times
Hey, maybe the crown race didn't get moved.
