Bead repair in tubed tire
Liked 6 Times
I recently had a tube blow out and when replacing it I noticed the tire bead was in quite rough shape. The tube failure didn’t appear to be near the bead failure and afaik the tube was quite old.
Seeing as the tire is tubed and the bead doesn’t need to hold air (just not pop the tube) it seems like it would be viable to repair the bead with tape/stitching.
Has anyone made a repair like this before?
A new tire would cost about 30% of the total value of the bike.
Images are attached in imgur
imgur .com/a/ r7bw6ZM (remove spaces)
Sorry if this breaks the rules but this post is pretty useless without them.
Thanks for the help.
Quoted: 860 Post(s)
Liked 1,103 Times
It looks iffy to me. Even if the bead stays intact the tire wall may separate from it. I wouldn't use it as it looks like too much of a risk of a blowout failure which at the very least will cost you a new tube and walk/lift home.
Quoted: 423 Post(s)
Liked 994 Times
Tires are wear items. If a new tire is truly 30 percent of the bike’s value, assuming you mean what you paid for it, consider yourself lucky you have a bike you’ve put so little money into. Even a free bike needs maintenance and parts replaced occasionally.
Likes For bboy314:
Clark W. Griswold
Quoted: 4491 Post(s)
Liked 4,169 Times
Just get a new tire. If you have such a bike that is so cheap that even a really cheap $30 tire is a large amount of the bikes worth, then the tires on it are not worth repair and are likely to fail more. Tires are a part of the safety of the bike and a failing tire is something that needs to be replaced. Sadly yes sometimes tires blowout but the bead is integral part and there is really no real fix for it otherwise it would be well known and well employed.
Quoted: 646 Post(s)
Liked 412 Times
I purchased a used Schwinn Paramount equipted with a Dura-Ace group in the early 2000s while living in Florida. I Paid $63.45 after tax. I replaced tubes, tires and cables for around $130. I used it to commute to work and on weekend rides with a bicycle club on the weekwnds for near 5 years. I didn't feel bad about spending more than the bicycle to make it useful.
Likes For Rick:
Quoted: 1006 Post(s)
Liked 1,687 Times
Yep... Its headed for the trash.
I have seen a few brand new tires with separating beads. Be sure to inspect your new tiers bead closely. And thats regardless of their manufacturer or make...
Liked 6 Times
Ok, thanks for the advice. I bit the bullet and bought a new set of tires. Figure it’s worth it to not have to worry about the whole thing failing unexpectedly. Appreciating more that what its worth is what you get out of it, just a bit of sticker shock after trying not the break the bank on the bike itself.
Likes For Mozzd:
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
And after looking at that imgur.com post I think you're lucky to be able to buy new tires for your two-wheeler! Surprised they held up as long as they have under you.
Cantilever believer
Quoted: 566 Post(s)
Liked 1,956 Times
Tire beads may not see a lot of road wear, but they are stressed far higher than most other parts of the tire. Where the cords meet the bead is where all the huge amount of outward force from the air pressure is transferred to the bead wires/cords. Any weakness at the bead or poor bead seating often results in a big ol' kaboom.
Likes For RCMoeur:
Mad bike riding scientist
Quoted: 6275 Post(s)
Liked 4,301 Times
Photo assist. Yup. The tire is toast. When you see metal bead, there is nothing to hold the tire on the rim anymore. It is headed for a blowout. Get a new tire.
Stuart Black
Stuart Black
Likes For cyccommute:
(above) Wow, that's worse than I expected. I thought perhaps just wire exposed on the edge side, but the wire has completely separated from the sidewall. I'm surprised the tube wasn't bulging out the side, maybe it was. Yep, toast.
By the way, if there was a cut in the sidewall of the tire, also requires replacing, but you can often limp home by putting a folded $1 bill between the tube and sidewall there, US paper money is tough. I helped someone on the road with that, a hole through the tread large enough for the tube to be bulging out, it got him home.
Likes For Duragrouch:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
When the casing starts to separate from the bead, it's only a matter of time before it turns into a blow-out. Time for a new tire.
Quoted: 525 Post(s)
Liked 690 Times
If the tube "blows out" it's not an issue with the tube, it's a problem with the tire, the rim, or improper mounting (seating). No, there is no repair to be done to that tire other than in a get me home emergency, and even then only as a last resort
Likes For wheelreason:
Quoted: 555 Post(s)
Liked 498 Times
Quoted: 6345 Post(s)
Liked 4,946 Times
I'd put it back on to ride back home if I was more than a comfortable walk to the house. But I'd replace it before the next ride.
Cantilever believer
Quoted: 566 Post(s)
Liked 1,956 Times
Even this would only hold less than 10 psi and only lasted less than an hour. And no, no matter how hard I worked at it, I could not get it to seat deeper on the rim.
Expired Member
Quoted: 3784 Post(s)
Liked 5,774 Times
Likes For shelbyfv:
Quoted: 555 Post(s)
Liked 498 Times
Compounded by the fact that bead failures are ones that are the hardest to boot or temporarily fix due to the stress concentration. This happened to me without warning in the fall of 2022 on my Bike Friday. No brake pad wear into the sidewall, no signs of obvious distress - just a tire that had seen a lot of revolutions on this bike.
