Nooob Tubeless Question
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 187 Post(s)
Liked 110 Times
I'm going to give tubeless tires a try, but I'm not wild about the sticky tire sealant.
I bought a wheel on eBay for a great price and there is dried on sealant all over the rim. So far, it has resisted soap & water, acetone, WD-40 and a degreaser. Anyone know of a magic solvent to remove it? Other than the dried sealant, the wheel is in great shape, so I don't want to use an abrasive material and scratch the rim.
Cheers, Mike
Cheers, Mike
Quoted: 5899 Post(s)
Liked 2,762 Times
Toluene is a common solvent for rubber based compounds. If that's what was in the solution, commercial paint thinner should help remove it. In any case, as you try stuff, be aware to NOT USE any caustics like lye, oven cleaner, etc, since these will attack aluminum rims.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 187 Post(s)
Liked 110 Times
Thanks!
Cheers, Mike
Cheers, Mike
Quoted: 511 Post(s)
Liked 650 Times
Toluene should work, but might not be readily available. I have found xylene at my local hardware store, and its solvent power is close to toluene (because it is close in chemical structure).
Quoted: 187 Post(s)
Liked 110 Times
Thanks. Yeah, I'm in California and it doesn't seem to be available here. I'll try to find that.
Cheers, Mike
Cheers, Mike
Quoted: 7084 Post(s)
Liked 11,187 Times
Tubeless tire sealant is generally water-soluble. Are you sure that's what you're dealing with?
Likes For Koyote:
Quoted: 187 Post(s)
Liked 110 Times
Habitual User
Quoted: 5043 Post(s)
Liked 8,291 Times
I've found that a moderately-stiff dry brush works pretty well, in most cases. I haven't yet found a situation where I've needed to resort to solvents. Maybe I've been lucky.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
I saw on the web so it must be true to use a natural latex eraser for adhesive removal. I have not tried it yet. Demo showed it removing from a tire. May work on the rim bead.
Searched with. latex adhesive eraser
https://a.co/d/7aacQ7f
Quoted: 546 Post(s)
Liked 479 Times
That hasn't been my experience. Water works well enough before the sealant has set, but I've had a tough time getting dried sealant off the frame of my mountain bike. I know now to deal with it immediately if I've had a puncture - although, of course, one doesn't necessarily realise.
Quoted: 511 Post(s)
Liked 650 Times
Likes For KerryIrons:
Quoted: 187 Post(s)
Liked 110 Times
This sounds right. I think I'm going to put the wheel on a rim brake bike and see if that scrubs it off.
Cheers, Mike
Cheers, Mike
Liked 2,762 Times
Agreed, and this is an excellent analogy. The OP would be well served by a visit to a hardware store, looking for a (dried) latex paint stripper. There are plenty, so odds are he'll find something both affordable and effective.store
FB
Chain-L site
FB
Chain-L site
Quoted: 187 Post(s)
Liked 110 Times
Another nooob question.
I put a tubeless valve stem in the rim last night and installed a tire. I wasn't entirely clear about how the valve should be installed (after watching 4 YouTube videos - none of which actually showed the valve and seals.....), so I pumped up the tire without sealant to see what would happen, as I didn't want to deal with the mess if I put in the valve stem incorrectly. The tire seated and pumped up to 95#. It seemed to hold pressure, but within a hour or so was completely flat.
Anyone hazard a guess as to whether the problem was the valve stem installation or the lack of sealant?
Also, anyone have any favorite stems?
Cheers, Mike
Cheers, Mike
Liked 2,762 Times
Only you know how diligent you were installing the valve, but since it held for a while, it's fairly safe to assume that any leak there would have been sealed. Likewise the bead. Also, make sure the rim strip is pressed down all the way around.
But, you'll never know until you add rhe sealant.
Quoted: 1110 Post(s)
Liked 1,048 Times
Likes For Russ Roth:
Quoted: 187 Post(s)
Liked 110 Times
I can say with some confidence that it was either or both. Unless it bled out under the rim strip.
Cheers, Mike
Cheers, Mike
Quoted: 187 Post(s)
Liked 110 Times
If you newly taped it I highly recommend installing a tube before going tubeless to press the tape into place. No matter how much I try to manipulate the tape and stretch it to make it sit flat in the rim, it never fully seems to do so and I can often feel air between the two layers of tape. A tube inflated to 80-90psi usually gets everything flat, take it for a spin around the block if you're concerned the job isn't good enough. Then toss in a valve stem and inflate. The rim its self can be damaged if the tape isn't properly seated. Without sealant, the best I've had just sitting was about 6 hours but that was a mtb and only inflated to 25psi so not a lot of pressure. Any of the treks I built that came tubeless the tires didn't hold for more than an hour or two, air under pressure will find the tiniest of imperfections to leak out, the sealant really matters.
Cheers, Mike
Cheers, Mike
