Kilo WT freewheel replacement help
Quoted: 10 Post(s)
Hello all
I’m trying to replace the freewheel on my Kilo WT, bikes direct (https://www.bikesdirect.com/products.../kilott_wt.htm) says that the
Freewheel is a: 16 tooth Single speed freewheel in the parts box, 1/2x1/8
Questions:
1) What does the “1/2” mean?
2) Any recommendations on freewheel brands?
Thanks in advance!
Questions:
Thanks in advance!
Quoted: 5931 Post(s)
Liked 2,828 Times
1/2×1/8" is the standard chain for single speed.
The designation refers to the pitch and width respectively.
As for freewheel, I don't do brand recommendations, but have heard of issues with off brand units, so shop carefully and play it safe with a known brand.
Insane Bicycle Mechanic
Quoted: 815 Post(s)
Liked 748 Times
Jeff Wills
Jeff Wills
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12946 Post(s)
Liked 7,856 Times
Hello all
Questions:
Thanks in advance!
Questions:
Thanks in advance!
1/8" is the nominal width between inner plates of the chain. 1/8 is fairly popular on fixed/single speed setups. 3/32" is typical on geared bikes and also used on some singlespeeds. You can usually run 1/8" chain on 3/32 cogs/rings also
All else being equal, a 1/8" drivetrain should last a little longer.
And if you have massive power numbers and happen to loose a chainring bolt, most 1/8" chainrings will be less likely to fold on you than 3/32.
Clark W. Griswold
Quoted: 4488 Post(s)
Liked 4,161 Times
If looking for a good reliable long term freewheel White Industries is the way to go. If I am just looking for a cheap-o but known quantity and quality Shimano unit is good. Box also makes a decent freewheel just avoid the really cheap stuff and definitely avoid no-name stuff but that could go for most anything.
Bikes: everywhere
Liked 7,856 Times
ETA: remember you can put a 1/8" chain on a 3/32" freewheel but you can't put a 3/32" chain on a 1/8 freewheel
Liked 2,828 Times
That said, make sure that whichever one you're considering has a good provision for removal.
Some have no such provision, and others are prone to damage during removal because of poor design.
For what these cost, you might take the earlier advice and stay with Shimano, rather than try to save a few pennies and come out behind.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
