Campy Freehub Interchangeability
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 226 Post(s)
Liked 141 Times
I found a set of Campagnolo wheels with a 9/10/11/12 speed freehub.
Is there a way to change the freehub to a shimano spline format?
I know there is a thread on BF about this, but it is 15 years old.
Also, is there an available reference to Campy standards (maybe starting with freehubs to current stuff) somewhere?
Cheers, Mike
Cheers, Mike
Quoted: 226 Post(s)
Liked 141 Times
Sometimes I get to thinking there is a compatibility team in these companies that ensures minimal compatibility across years and brands......
Cheers, Mike
Cheers, Mike
Quoted: 5932 Post(s)
Liked 2,828 Times
+1
Campy offered many of their wheels in Shimano versions, so freehub rotors exist for most wheels.
FB
Chain-L site
FB
Chain-L site
Quoted: 226 Post(s)
Liked 141 Times
My hub is an Athena 9-speed.
Also, does Campagnolo have a web based compatibility chart like Shimano?
Cheers, Mike
Cheers, Mike
Liked 2,828 Times
I just did a quick search for Shimano freehub for Fulcrum and brought up a few, plus it also linked a search for same on Campy.
So finding some is easy. That said, knowing interchanges for specific models is trickier.
AFAIK (remember) they never made one for Athena hubs, but there's a chance that one made for one of the wheels may fit.
Try calling or emailing Campy USA and they might know which, if any, will fit.
Another option might be spacing a Campy cassette for Shimano.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 7396 Post(s)
Liked 2,564 Times
For about two years, I mixed components: Shimano shifters, and derailleurs with Campagnolo wheel and cassette. It did not work perfectly: on some shifts, I had to click twice. But it didn't make that grinding noise that came from being "between" gears on a friction system, so I didn't mind much. This may not satisfy you, but I thought I would mention it.
@FBinNY mentions spacing the cassette yourself. That sounds tricky, as you have to measure the spacers and cogs precisely, but I knew one person who succeeded at doing it.
Quoted: 226 Post(s)
Liked 141 Times
Cheers, Mike
Cheers, Mike
Try searching the word "shimergo" and you'll go down the rabbit hole of mixing Shimano and Campy. I had 2 bikes successfully working with such a setup (9 and 10 spd) but I believe the effort to get them working properly is too much, especially now that you can get cheap shifters from the likes of Sensah, Microshift or LTwoo to get older 7,8,9 or 10 spd bikes upgraded to modern shifting.
Quoted: 243 Post(s)
Liked 234 Times
Likes For RGMN:
Quoted: 226 Post(s)
Liked 141 Times
Most Campag and Fulcrum wheels since 2007 can be converted to HG with the FH-BO015X1 freehub if they have a cutout alloy axle. If it doesn't have the cutout axle you will need one, FH-BO001. At this point it is probably less expensive to get some new wheels. Some of the newer wheels will require a different freehub, they are listed in the Campag spare parts catalogs https://support.campagnolo.com/media...rt_C_Rev00.pdf
Cheers, Mike
Cheers, Mike
Quoted: 226 Post(s)
Liked 141 Times
Liked 2,564 Times
Quoted: 243 Post(s)
Liked 234 Times
