Tandem Front Wheel - Need Advice
Old 05-22-24, 11:28 AM
PromptCritical
PromptCritical's Avatar
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 269 Post(s)
Liked 184 Times in 119 Posts
I’m converting our tandem to a front disc brake and would like some advice on what folks have found works well.
700c either CLD or 6-bolt, but would prefer CLD.
Looking for a nice compromise between weight and durability (about 375# all in).
Thanks in advance!
Cheers, Mike
PromptCritical is offline
Old 05-22-24, 04:30 PM
joeruge
Quoted: 81 Post(s)
Liked 76 Times in 42 Posts
Tandem Rated Fork
First thing is you need to get a tandem rated fork - and there aren't a ton of choices. Look at reputable tandem dealers. Your local bike shop is not likely to have anything you could use and they may not even know it is a 'thing.' Tandems East, (NJ) House of Tandems (TX) or Rodreguiz Cycles (WA) are places to look, as well as most of the big tandem companies, like Co-motion. Don't try to go cheap by using a single bike fork. Your life may depend on it!
joeruge is offline
Old 05-22-24, 05:16 PM
bboy314
bboy314's Avatar
Quoted: 444 Post(s)
Liked 1,040 Times in 533 Posts
I would recommend contacting any of the above dealers for wheel options as well. Last I checked Velocity, White Industries and DT Swiss all had good 40 hole hub options, and I use Velocity Dyad rims. And of course quality spokes and a competent wheel builder make all the difference too.
bboy314 is offline
Likes For bboy314:
Old 05-23-24, 03:17 AM
CaliTexan
CaliTexan's Avatar
Bikes: 2019 Co-Motion Carrera (S&S) / 1998 Litespeed Tuscany / 2011 Wilier Cento 1 / 2024 Cervelo Rouvida
Quoted: 10 Post(s)
Liked 15 Times in 9 Posts
Your profile shows you’ve got two Santana’s. I’d start with the factory for their fork & brake recommendations. And go from there to the resources already mentioned.
CaliTexan is offline
Likes For CaliTexan:
Old 05-23-24, 07:16 AM
PromptCritical
Quoted: 269 Post(s)
Well, thanks, but I didn’t ask about forks. I have that covered with a custom fork built by a very respected frame builder.
Just trying to get some insight into what folks are running for wheels. I have a 40H DT Swiss tandem hub and Dyad are good rims so I’ll probably go with that, but looking for options.
Cheers, Mike
Old 05-23-24, 10:22 AM
CaliTexan
CaliTexan's Avatar
Quoted: 10 Post(s)
I guess from your reply that you're not interested in Santana's recommendations.
We run Rolf carbon tandem wheels with TRP Spyke mechanical disks, and have been happy with both.
Old 05-23-24, 02:37 PM
PromptCritical
Quoted: 269 Post(s)
Well, Santana’s advice was to not do it, so I’m looking for other advice and experience.
Thanks for letting me know what you’re using.
I have a call into Rolf.
Cheers, Mike
Old 05-23-24, 03:10 PM
TobyGadd
Quoted: 37 Post(s)
Liked 23 Times in 20 Posts
What, specifically, didn't Santana recommend--and why?
TobyGadd is offline
Old 05-23-24, 04:40 PM
joeruge
Quoted: 81 Post(s)
Mike, sorry! I read 'folks' as 'forks.' Should have had my glasses on. I do aopologize
joeruge is offline
Likes For joeruge:
Old 05-23-24, 05:13 PM
bboy314
bboy314's Avatar
Quoted: 444 Post(s)
I’m curious to hear this as well.
bboy314 is offline
Old 05-23-24, 06:03 PM
PromptCritical
Quoted: 269 Post(s)
I asked them if they had a fork that would accept a disc or any conversion parts. They said “no, they never use a disc except on the Evolve fork.” I asked why and they said they just don’t. It wasn’t the sort of conversation that was going to yield details.
I get the sense they are not very interested in supporting modifications. They pitched me on a new bike, which is fine, but I’m not a buyer at the moment.
Cheers, Mike
Old 05-23-24, 06:32 PM
bboy314
bboy314's Avatar
Quoted: 444 Post(s)
Sounds like they were just saying they don’t have a compatible fork for you. They may be able to help with wheels, but again, so can any of the other tandem specialty shops. I’ve personally had great dealings with CoMotion and House of Tandems in Houston.
bboy314 is offline
Old 05-23-24, 07:51 PM
PromptCritical
Quoted: 269 Post(s)
I can certainly call a shop and ask for advice, but I really don’t like doing that when I know I’m not going to buy. I’m going build it myself.
why the resistance for folks to tell me what they ride?
Cheers, Mike
Old 05-24-24, 05:56 AM
merlinextraligh
pan y agua
merlinextraligh's Avatar
Quoted: 1483 Post(s)
Liked 768 Times in 395 Posts
You mean Bill McCready was not supportive of an idea that was not his own. Sounds “ proper” to me.
You could get lost and die.
You could hit a tree and die.
merlinextraligh is offline
Old 05-24-24, 06:04 AM
merlinextraligh
pan y agua
So, why not use an Evolve fork? I’m assuming that Santana’s current steerer diameter is different from your older Santana?
As for front hubs, we use DT240’s on several different sets of wheels with no issue. ( 2 with 100mm qr, and one with through axle).
The front hub doesn’t need to tandem specific
Old 05-24-24, 06:34 AM
bboy314
bboy314's Avatar
Quoted: 444 Post(s)
Ok, but you’ll need to buy the components to build the wheel somewhere. Why not from any of the above shops that specialize in tandem parts?
bboy314 is offline
Old 05-24-24, 08:45 AM
PromptCritical
Quoted: 269 Post(s)
Well, yes. And after the advice he gave about brakes on that tour in France (Mt. V….?) the last thing I’d take advice from him on is brakes.
That and they have incredibly unhelpful in dealing with the bankruptcy of one their tour operators, for which we have $8K tied up.
Cheers, Mike
Old 05-24-24, 09:15 AM
PromptCritical
Quoted: 269 Post(s)
I probably will. Right now I’m in the information gathering stage.
Cheers, Mike
Old 05-24-24, 12:48 PM
TobyGadd
Quoted: 37 Post(s)
Other than the wheels that have come with my bikes, I usually have my wheels custom-built to my specs. I've always had good luck with DT Swiss hubs, spokes, and rims. I also like Shimano hubs, which are a great value. Universal Cycles has built all of my custom wheelsets over the years, and they've always been excellent. Their configurator lets you select pretty much whatever hubs, spokes, nipples, and rims you like--so you can really tune the cost, performance, durability, etc. to your taste. Universal Cycles -- Custom Wheelset Builder.
If you also need new brakes, you'll likely have to decide of you want to change your brifters to hydraulic or not--which could end up requiring upgrading most of your groupset for big bucks. If you want to keep the existing cable-activated levers, then I'd recommend either Avid BB7 brakes or Paul Klampers. My Cannondale T2 came with BB7 brakes, and I anticipated needing to change them--but they've actually been great for riding steep stuff in Colorado like Mt. Blue Sky, Pikes Peak, etc. Klampers are very expensive, but excellent. If I decided to tour with a big load, I'd likely buy the Klampers, but BB7s have proven to be everything that I need for now (300-pound team plus bike, water, gear).
I'm still a little confused about the fork issue, though. If the fork is disc-compatible, why doesn't Santana want you to put a disc brake on it?
TobyGadd is offline
Old 05-24-24, 03:21 PM
PromptCritical
Quoted: 269 Post(s)
No problem. It was actually kinda funny.
Cheers, Mike
Old 05-24-24, 06:19 PM
PromptCritical
Quoted: 269 Post(s)
The Evolve fork is tapered, and they really weren’t interested in going down that road.
Thanks for letting me know your wheel specs.
Cheers, Mike
Old 05-24-24, 08:43 PM
headasunder
Quoted: 76 Post(s)
Liked 20 Times in 15 Posts
Dt Swiss hubs 350 hybrid front and rear both 32 hole and both laced into dt Swiss gr 531rims. Touring/ gravel rig with plenty of KMs on mixed terrain.
headasunder is offline
Old 05-25-24, 09:44 AM
Artmo
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 150 Post(s)
Liked 98 Times in 65 Posts
Thanks in advance!
I have a little-used Spinergy TX2 front tandem wheel, 6-bolt for disc for sale. Light and bomb proof!! Complete with tire and tube.
Artmo is offline
Likes For Artmo:
Old 05-25-24, 03:01 PM
PromptCritical
Quoted: 269 Post(s)
That’s a great at Universal Cycles, but there are very few QR disc hubs.
Thanks for the link.
Cheers, Mike
Old 05-25-24, 04:16 PM
TobyGadd
Quoted: 37 Post(s)
Yeah, the industry is definitely moving to TA hubs. Still some decent options there, though.
You could also try calling Tandems East. Mel has lots of QR hubs, and he laces up nice wheels.
TobyGadd is offline
Likes For TobyGadd:
