cannondale r1000 or Giant TCR 3
Allum traditional frame with killer components/wheel set versus carbon compact frame and 105 group. I think the price is about the same. Entry level racing and rec riding would be the general use. Anyone have any expereicne riding both? Thanks.
haven't been on that c'dale, but have plenty experience with a cannondale 2.8 (i would assume it's far from the same ride).
just got a tcr comp 0, and i'm very happy with it, although it won't get any real road time until spring.
don't know the specs on the c'dale, but have you checked the tcr 1 alu w/ultegra.
while cannondale is far from a newcomer, i wouldn't use the term 'traditional' when describing it.
Pegger
Bikes: devinci chicane, 80's Fuji, 2006 Cannondale R1000, Cannondale Six13 Team Campy
Double Secret Probation
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
The Cannondale of course. Ride both and pic your fav, while the Cannondale may not ride as smooth as the Giant, it's a SUPER bike, US built frame, great components, and awesome ride.
John
John
Time to Ride...
Time to Ride...
Bikes: Giant OCR3,Gary Fisher Tassajara
Cannondale definitely, The Giant has much inferior components. It is a nice frame, but after that your getting less bike for the $$$.
OK, apart from supposedly having better components how is the c'dale "far superior"?
that's a pretty sweeping statement.
are you speaking from experience, having raced on both the R1000 and a tcr comp, or are you just blowing smoke because you have a c'dale?
Originally Posted by james_robert
with an ultegra drivetrain, more aggressive geometry, a stiffer frame, and just generally best overall components and performance, the R1000 is far superior for racing
Bike Curious....
I'll dissent - I'd go for the Giant. To me the frame is the important thing - you'll most likely be wanting to swap components as go you anyhow. A good CF frame will be the basis of a great ride for many years to come. But as others mentioned, riding both may help you decide....
Bikes: Surley LHT, Cannondale R1000, IBEX Ignition, Bianchi Boardwalk, KHS Milano Tandem
I have been riding an 05 R1000 since March.
I have to disagree with the 3+ hours comment above, I have ridden 6+ hours centuries with it and did not feel the stiffness of the frame because it ain't. Cannondales frames have come a long way from their earlier models (I own one I used to ride).
If you decide to go for the R1000, look for the following component swap/upgrade:
1. Saddle: the fizik poggio that came with the bike made it back to the shop on the second day, (ouch ), the lbs trade it in for an Arione, wonderful saddle. If I am not mistaken, the 06 model should come with an Arione, not sure.
2. Depending on the choice of crankset you are getting, double or triple, the double comes with a rather agressive cassette range (11-25), I swapped this for an 11-27 which is better for climbing. This may not be an issue with the triple, but check it out.
3. The Hutchinson tires that came stock were crap, did less than 500K with them.
Other than that, everything else remained stock, wonderful bike. The wheels are bombproof. Bike came with lifetime free tuning (not sure whose life this refers to ), not all lbs/brands do that, huge savings.
I haven't riden the GT but in the purchase process I rode "softer" frames than the CAAD8 and did not like them, I guess that is really a personal preference.
One thing you may want to consider while chosing an 105 or Utegra equipped bike is the replacement cost of components, Ultegra 10 cassettes and chains are much more expensive.
Stop it.
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
Are they new?
If they are, then buy the 'Dale for one reason.
WARRANTY.
Cannondale's warranty rocks.
Giant's is garbage.
WARRANTY.
Giant's is garbage.
wannabe cycling nerd
Bikes: Giant TCR Comp 3
I'd go for the Giant (i'm biased) based on the fact that frame material is superior. When you get the money, you can always spend a little money here and there to upgrade to the components that you want. Keep in mind, that the Giant frame by itself retails for over $1500.
I owned a CAAD5 bike for a week before returning and buying the Giant. I liked the look and the value of the cannondale, but when I was riding it, it was too stiff for my enjoyment. You can swap out saddles or tires, but nothing will make more of a difference for the "feel" of the bike than the frame. Keep in mind that the Cannondale has a very aggressive geometry coupled with a stiff aluminum frame. The Giant TCR also has a relatively aggressive geometry but the carbon helps out a lot with comfort and vibratioin reduction.
Also, you won't feel a huge difference in different components if you're new to road biking. You'll feel the biggest difference with a carbon frame.
I would opt for the 10 speed 105 of the 06' TCR vs the 9 speed 05' though. Sheldon brown says that it is very likely that the 06 105 groupo will outperform higher groups because of newer technology.
Ride both, see how they fit. Don't forget to take it to some uneven pavement... that's where the carbon will stand out.
Bike Curious....
Originally Posted by 56/12 and 22/28
Giant's is garbage.
Giant Bicycle, Inc. ("Giant") warrants the frame and rigid fork of each new Giant brand bicycle and Giant brand frameset to be free from defects in material and workmanship for as long as the original purchaser owns the bicycle. Paint finish and all other original components, and all Giant brand repair parts, replacement parts, and accessories, are warranted to be free from defects in material or workmanship for a period of one year from the original date of purchase. This warranty applies only to bicycles and framesets purchased new from, and assembled by, an Authorized Giant Dealer.
From Cannondale:
FRAMES (frame, fork structure, swing arm): Cannondale frames (except freeride, see below) are warranted by Cannondale Bicycle Corporation, 16 Trowbridge Drive, Bethel, CT 06801 against manufacturing defects in materials and/or workmanship for the lifetime of the original owner.
Components: All other components, including HeadShok forks, suspension parts, frame fixtures and finishes (paint and decals) are warranted against manufacturing defects in materials and/or workmanship for a period of one year from the date of original retail purchase. Suspension forks (other than those made by Cannondale) are not covered by this warranty, but are separately covered by the stated warranty of their manufacturer.
once again i ask - is this based on personal experience?
giant has a lifetime warranty.
Are they new?
WARRANTY.
Giant's is garbage.
WARRANTY.
Giant's is garbage.
Stop it.
Giant takes a very long time to replace a frame if you wreck it. If they want to replace it at all.
Cannondale will ship you a new one, even you the only thing wrong with it is was that it is the wrong size.
Sensible shoes.
Bikes: A few.
In either case you could do much worse. Go with what floats your boat.
Personally, I favor the C-dale. Not for the warranty, but because you don't hear from many C-dale Caad8 owners who aren't totally happy with the bike as a whole. It's probably about the best sub $2k race bike out of the box available.
Go Titans!!
Bikes: '04 Eddy Merckx Team SC - Record - Rolf Prima Vigor; Andy Hampsten Cinghiale - Dura Ace 7800 - Rolf Elan Aero
For your entry-level racing goals, I would go with the Cannondale for the better components and more aggressive frame geometry.
You can always save up and buy a CF bike later for more casual riding (like century or charity rides) from the likes of Giant, Look, Colnago, Trek, etc.
One must live the way one thinks or end up thinking the way one has lived.
--Paul Bourget
--Paul Bourget
Stop it.
Originally Posted by bobby c
From Giant:
From Cannondale:
From Cannondale:
Go Titans!!
Also, I wouldn't want to worry about crashing during a race or training ride and wondering if there might be any structural damage (invisible to the eye) within the CF frame, especially since you are just starting out.
--Paul Bourget
--Paul Bourget
Stop it.
Originally Posted by sunninho
Also, I wouldn't want to worry about crashing during a race or training ride and wondering if there might be any structural damage (invisible to the eye) within the CF frame.
Not that Cannondale's CAAD 8 frames are over-built, but they are more beef-y than Giant's composite frames.
Plus, the CAAD 8 comes in a staight-up CLEARCOAT with decals.
Bike Curious....
From Giant:
From Cannondale:
From Cannondale:
There's another great reason.
are you sure you want to drop $1500 on an ALUMINUM frame? You think all the pros ride carbon fiber because it's a fad? BTW, the frame on the TCR C3 is the same one on the $5000 TCR C0.
Pegger
Pegger
