Floor pump recommendations
Old 06-30-06, 11:19 AM
Delta
Delta's Avatar
Bikes: N/A
I need to replace my current pump. It's starting to release air in places it shouldn't. Any pumps out there that are reliable for high pressure with a gauge. Let me know. Thanks.
Delta is offline
Old 06-30-06, 09:22 PM
Grand Bois
Grand Bois's Avatar
Quoted: 443 Post(s)
Liked 28 Times in 26 Posts
https://www.bikepro.com/products/pumps/medai.html
I've been using mine for 30 years.
Grand Bois is offline
Old 06-30-06, 09:42 PM
N_C
N_C's Avatar
If your pump is worth fixing & able to be fixed maybe just replacing the seals will be enough, that is guessing the seals are the problem. Otherwise this is a good pump: https://www.parktool.com/products/det...17&item=PFP-3#
It is the one I have & use. Works great.
N_C is offline
Old 07-01-06, 10:09 PM
ericgu
I have a blue nashbar one that works nicely.
Eric
2005 Trek 5.2 Madone, Red with Yellow Flames (Beauty)
199x Lemond Tourmalet, Yellow with fenders (Beast)
Read my cycling blog at https://riderx.info/blogs/riderx
Like climbing? Goto https://www.bicycleclimbs.com
ericgu is offline
Old 07-01-06, 10:18 PM
Wil Davis
Curmudgeon
Wil Davis's Avatar
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Liked 4 Times in 4 Posts
I've been very happy with my Park Tool PFP-2. The spring-clip retainer thingie looks as if it might cut into the hose over time so I replaced mine with a Velcro™ strap.
- Wil
Wil Davis is offline
Old 07-02-06, 04:17 AM
gear
gear's Avatar
Liked 3 Times in 1 Post
joe blow
gear is offline
Old 07-02-06, 05:40 AM
CommuterRun
Conservative Hippie
- Wil
This is the pump I have and I've been very happy with it.
CommuterRun is offline
Old 07-02-06, 06:25 AM
RonH
Life is good
RonH's Avatar
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times in 10 Posts
Originally Posted by gear
joe blow
+1
RonH is offline
Old 07-06-06, 05:14 PM
Delta
Delta's Avatar
Bikes: N/A
Thanks for all your advice. I got one called "Wrench Force". It came with a life time warranty and I noticed that it was the one they used at my LBS.
Delta is offline
Old 07-07-06, 09:44 AM
foehn
Location: The Alta Loma area of Rancho Cucamonga. About 45 miles east of Los Angeles, California. Uphill, downhill and across hill riding; not too level!
Yep, this is a good'un. We have been using ours for about 20+ years.
We also use a Serfas FP100 which is nice, but the Medai so far has much more stayin power. The Serfas is only about 2 years old.
foehn is offline
Old 07-07-06, 10:03 AM
NoRacer
Isaias
NoRacer's Avatar
Bikes: Ridley X-Fire (carbon, white)
Quoted: 7 Post(s)
joe blow or silca pista if you need to get up to 200 psi.
NoRacer is offline
Old 07-07-06, 11:06 AM
HardyWeinberg
GATC
Quoted: 464 Post(s)
Liked 49 Times in 27 Posts
We have a bell floor pump called 'the jury' which sounds kind of creepy. I gave up on it last night, switched to topeak frame pump to make sure I got up to 100psi (not easy but easier than that bell pump).
HardyWeinberg is offline
