VDO Computer OK on Rear Wheel?
Huachuca Rider
Bikes: Fuji CCR1, Specialized Roubaix
Picked up a VDO c3 DS Computer with a Cadence Option this weekend. Was so impressed by the price and the inclusion of a cadence option, I overlooked the fact that I was seeking a rear wheel mountable computer in order to track indoor miles this winter as well as my outdoor work. I think I assumed that a wireless computer could be mounted on either wheel. The instructions however, do not directly offer that option.
Anyone here have experience with this brand of computer? May I place it on the rear wheel? Any special considerations?
Thanks.
Thanks.
Just Peddlin' Around
semifreddo amartuerer
Bikes: several
Originally Posted by Stacey
I don't see why not, especially if it's wireless. If not, then it's dependent on cable length. I'm not familiar with the model. Try it and see.
Nevertheless, trying it to see is probably the best way to end the mystery in your particular case.
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Originally Posted by 'nother
Well, some wireless computers have a very short range, which would be one reason why not. I have a Sigma wireless that just barely works on the front....forget the rear.
Huachuca Rider
Bikes: several
Really! I'd think if it will pick up cadence, it should pick up rear wheel too. Gotta love wires
As for trying it/returning it: first, double-check the return policy & procedure. You should be able to find out very quickly whether it's going to work or not. Just use electrician's tape or something like that for a temporary/test mount, then you don't have to worry about using the cable ties.
yes... You're on my left
Bikes: Specialized FSR XC/Trek 930
For indoor use (on the trainer) mount the sensor on the rear wheel, and the computer on either the seat tube, or the top tube. It will work, you just might not be able to see it while you're riding.
Bikes: Fuji Grand Fondo 2.0
The CS line of the VDO computers has a transmission range of about 50 inches as I recall. That was the primary reason for me buying one. I was tired of sporadic results with most other wireless computers. They almost all only have a range of under 24".
