Lithium grease -- what to shop for?
Can anyone suggest any specifics on what to look for, in terms of brand, characteristics, applications, etc? Thanks
edit: for a cog, specifically
Bikes: '04 fisher 29er, NYC Bikes CityFixed
It doesn't matter. Lithium Grease, PW Grease, Park PolyLube or whatever you get at an autoparts store will work fine.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
I just get the can o white lithium fromace hardware and it works great for me
white lithium has a high flash point is water resistant and very smooth works on almost any material nylon teflon steel alu ti what have you
Bikes: Giant OCR3, Schwinn Sierra GS, Fuji Track
I feel P B power blaster clear cable and hinge lube is better. It is a clear spray grease that dries clear and does not attract dust. It is a heaver Boeing lube.
Paste Taster
for greasign the threads on a cog right because if you are trying to lube your drivetrain use a dry lube I like pedros
