craziest brake (un) lever i have ever seen
do-over...
Bikes: 69 paramount, 52 bauer stunt, , 30's Appelhans track,06 Bianchi pista, 80's Lotus,Pinarello track, Kalavinka track
weird... what a terrible shape!
do-over...
https://cgi.ebay.com/Profile-Design-A...QQcmdZViewItem
if you want one..hahaahha. all the cool kids have one..
left treadle forward
Bikes: <strikethrough>BFSSFG IRO</strikethrough>, 197X Raleigh Record Ltd conversion, Java SS
Originally Posted by roughrider504
They should of just made an oversized bar end shifter, I would think it would work better.
It's a speed modulator, not a brake. IIRC you actually set the amount of brake like a friction shifter, you don't pull it. It's for time trials.
https://blicksbags.com/
do-over...
huh?
70mm4$!n!
Bikes: Sworks E5, ritte Bosberg
those things are total crap, no braking power is applied, nashbar was selling them for way cheap a couple of months ago, but the people who bought them just used them as buttplugs
pompous windbag
I just keep two cork pads (as not to mess up my non-machined deep Vs) cuffed up in my capri pants, pull em out when needed, lean over the bars one-footed style, apply brake pressure with said cork pads....but making it look like I'm lighting an unfiltered/hand rolled cigarette.
do-over...
i just carry a satchel of squirrels with me to ram in the front spokes, but i am going to upgrade to one of those.
pompous windbag
Permission to copy your squirrel technique. Granted I'll have to catch them initially, but I'll have so much pelt leftover...
do-over...
permission granted..
LF for the accentdeprived
Speed modulator for TT's... sounds like a winner idea. We'll just torque it to the max for Tyler Hamilton because of *certain considerations* etc. and we have a level playing field!
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I use grip-shifters as brake levers... perfectly indexed braking.
white men cant jump
idiot
I don't think thats how it works. You never really slow down for long distances in tts or tris.
Tandems do use a regular bar end shifter to set a constant braking sometimes though.
From Nashbar's Website...
"Eek precious tenths of a second off your next time trial by sporting a set of these ultra aero brake levers. These levers are super aero, but leave a little to be desired as far as stopping power goes, but they can scrub off speed to set up for your next tight turn or slow you down after crossing the finish line. Ultra low profile design slices through the air. Return spring positively snaps levers back to their aero position when you’re not slowing. Aircraft aluminum construction. Fits most standard bullhorn/wing bars. 2.5mm set-screw mounting design means these are for use on metal handlebars only. Brake cables and housing included."
Originally Posted by megatron
yes im sure....
idiot
idiot
These brakes have been brought up several times on the road cycling forum (which I used to frequent). They were described as such. Someone even mentioned the phrase "set it and forget it" because they are meant for downhill courses and whatnot. The description on Nashbar's site seems slightly contradictory but perhaps not (friction engages the harder you brake?).
I haven't used these brakes (nor anyone else in this thread) so we're all just being speculative.
That might be where the confusion began...it makes more sense that people thought they were tandem brakes (these tandems have drum brakes don't they?).
shot
I have held these "brakes" in my hand. They are NOT "set and forget", they do indeed snap back and release the braking pressure when you let go.
Oh, and they are awful.
They answer a question that nobody asked.
They are a solution looking for a problem.
