*Shimano WH-R540 Road Wheels question
Bikes: Cervelo Soliost
Do these wheels have a sealed cartridge bearing or loose bearings? Is anyone using these wheels? Are they ok wheels?
The Shimano site says they are fully serviceable. Im guessing that means, that they arent sealed. Here is the link to the site.
https://bike.shimano.com/Wheels/index.asp
The Cycling Photographer
I have these wheels.. and so far with about 500 miles in the past 2 months on them.. I'm pretty impressed.. smooth ride... much lighter than my old crappy rims I had... I believe they are cartridge bearings.. but I'm not 100% sure
Jeff
Jeff
I have them and I think their great. I have a little over 1000 miles on them with all types of roads. They are still running true even hitting numerous potholes. I weigh around 205 lbs (for the first 600 miles, down to 188 now) and they seem to be really solid feeling in the turns. I was on a 400 mile tour in July where I lost it going down hill on a corner (hit sand) and ended up bouncing off the guard rail. They came through without a problem.
I was at Performance the other day and had their tech guy look thru their catalogs as I had a similiar question on R540's. Their catalog and Shimano's doesn't specify anything on the R540 hubs. You might try a shop/wheel guy who works on wheels or someone at Shimano. Good luck to ya!
Bring the tech
Check out
https://www.shimano-europe.com/cyclin.../WH-R540-F.pdf (front)
and
https://www.shimano-europe.com/cyclin.../WH-R540-R.pdf (rear)
Looks like standard loose bearings.
Andrew
and
Andrew
Zippy Engineer
Bikes: Bianchi 928, Bianchi Pista Concept 2004, Surly Steamroller, 1998 Schwinn Factory Team Homegrown, 1999 Schwinn Homegrown Factory, 2000 Schwinn Panther, Niner EMD9
All Shimano hubs are loose ball hubs. The guy at Performance isn't much of a tech guy-maybe I should look into a job transfer.
We drive on the left.
I hope their not meant to be sealed because I have pulled my front one apart to service it. Ball bearings every where!
I have the R535s, they are a robust rim and very good value for money. They do make a lot of noise when powering over small rises though. The back wheel sounds very fragile, like an aluminium can, but it has never needed truing.
CHEERS.
Mark
CHEERS.
Mark
Compulsive Upgrader
Bikes: 2002 Kona Deluxe (road), 2001 Cove Stiffee (mtb)
I know what you mean about the aluminum can sound from the rear wheel. I thought I was the only one. Everytime when I'm REALLY cranking up a climb I hear a popping sound coming from the rear. I can never figure it out what causes it. The first few times I inspected the wheel to make sure I didn't have a factory defect or something, but so far after 1000 k's they are still true and seem pretty solid to me.
I also second the notion that all Shimano wheels are ball bearing, they don't make cartridge hubs.
"No drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs. We should test them for stupidity, ignorance, greed, and love of power." -P.J. O'Rourke
that answers alot, i think i may go with the mavic cosmos elite. they are a bit more but i want the sealed cartridge bearings.
although for 299 - 20% performance coupon, $239.20 is a pretty good deal. Performance doesnt sell the mavic wheelset i was looking at, decisions decisions.
Do you mean Mavic Cosmos or Mavic Cosmic Elites? Take a look here for the latest deals on Mavics. They give you good sources on ebay deals and store web sites.
https://qbike.com/category/wheels-m.html
Hope this helps!
Hope this helps!
Zippy Engineer
Cosmos should cost somewhere around $300-$350, if memory serves. I'm no longer at a Mavic shop so I don't have current pricing. I'd go with the Shimano wheels over the Mavics...we didn't have much luck with those hubs, particularly the freehub bodies. Servicability is pretty much nonexistent-if you have a problem you send the wheel back to Mavic. Just MHO...
get the dura-ace open pro wheels from excel sports. they are light as all get up, and I have heard very good things about the durability of the open pros. I only have about 50 miles on my new wheels, but they are sweeeeeeet...
Plus they are only $300 bucks. less then the cosmos, better wheels then the R540s.
Originally posted by djbowen1
what should mavic cosmos elite cost on average??
-Dan the Man-
Actually,,,, the Cosmics are the taller aero rims that the pros have been using. They are more expensive than the Cosmos. They come in carbon, too. One of the two wheelsets should be called something else. It's too confusing.
i didnt even see the difference in names until now, i meant cosmic elite to begin with. How much are these wheels, i cant find a positive answer anywhere.
Bring the tech
These are Mavic Cosmic Carbone (16F/20R - deep section rim)- $1100-1200
These are Mavic Cosmic Elite (20F/20R) - $400
These are Mavic Cosmos (24F/28R) - $300
These are Mavic Ksyrium SSC (18F/20R) - $800
These are Mavic Ksyrium Elite (18F/20R) - $500
This is the Mavic Comete Route (Disc) - $1400
Andrew
Andrew
Bring the tech
The Zipp is nice, but the best value is still the Renn;
For a whopping price of $320 - https://www.rennmultisport.com
Andrew
Andrew
meh. whats the point. If you are going to discs, you are obviosly very into the sport meaning that you are very good, and you deserve the best...not the bargain bin.
