What defines a TRUE CYCLO CROSS FRAME?
I see bikes all over called cyclo cross, or cross this, or that cross with frames that do not seem like cyclo cross frames to me.
For those that are interested in CX, what in your mind are the elements of a frame being a True Cyclo Cross frame? Which design features must be present to keep the frame from just being a hybrid or touring frame with shorter stays?
I have been involved in CX since the 1970s; so my ideas on the pure cx frame maybe too strick. Wondering what others think
thanks
Mike
thanks
Mike
https://www.bikesdirect.com
"First they ignore you, then they ridicule you, then they fight you, then you win." – Mahatma Gandhi
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
Canti mounts, clearance for wide tires, top mounted cables and non compact geometry are the big ones for me.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
big ring
yes that's the logic but in practice there are plenty of cross bikes which are bottom mounted. i prefer to not have cables weakening my grip over the top tube.
uberNEWB
Bikes: Haro V2 [rip / stolen], PEUGEOT '93 SELECT
something that you can sling over your shoulder quickly. robust enough to take a hit.
something that you are ballsy enough to take out on a day that you wouldn't even take out your beater bike on.
assonfire
thanks
Mike
thanks
Mike
The top mounted cable guides also help (slightly) keep the crap off your cables.
My Yeti has no rack/fender eyelets so I guess it's more of a racer but the eyelets are nice to have on CX bikes because they are so versatile.
I don't prefer it, but some manufacturers make semi-compact, compact and even super-compact CX frames. Their reasoning: for step-over mounting clearance.
Cross remount is over the back of the saddle, not step-through.
Smallest frame sizes (i.e. sub 50) might have slopier top tube, just to fit 700C wheels.
That said, I agree on preferring non-compact geometry, even though 95% of my carries are suitcase rather than shoulder... the top tube is that much closer to my hand. Also agree that the top tube plays no role in dismount-remount... my leg comes around the back for dismount, and I jump on the back of the saddle for remount.
assonfire
Yes, a lot of makers use a sloping top tube, but the idea that it's to make mounting the bike easier is ludicrous, regardless of what some alleged "manufacturer" says.
A sloping top tube is probably easier to suitcase, because your right hand doesn't need to go as high while carrying.
That Leader frame's top tube, in addition to being sloping, also has a cable running under it, make of that what you will. I don't think people consider Leader frames to be "true" anything, cyclocross or otherwise.
I do realize it's atypical, but I can only remember one true run-up out of 5 different courses I raced on last fall. Almost everything else was the high-speed, middle-of-straight double barrier kind of thing where suitcasing was more appropriate. We only had one wet race too, for what it's worth.
Bikes: Lynskey R210, Miyata 610, Anchor PCD3
Instead of top-mounting the cables, why not just put cable housing over the entire length of cable so that they don't get gummed up (I haven't done this, but I was just wondering)?
I don't have too much of a problem with compact frames, I think having a lower grip on your frame means you don't have to lift it quite as far up to get it over stuff - so there is a bit of a trade-off.
In practice, I don't find that I lift my bike very far at all. It's more of a lift and then use the left hand on the bars to tilt the whole bike out, enough to clear the barriers.
Obviously, in a crowded field this becomes less of an option.
I've been told it's bad form to tilt the bike outwards because it's less likely to be stable when you put it back down.
My bike is compact geo with downtube cable routing, oh well.
dork. yup.
Bikes: Trek xo2, Fuji Cross Pro, Schwinn Traveler cross-conversion, Concours, Trek 2300, Takara, Specialized Hard Rock, Bianchi Campione D'Italia, GT LTS Team issue, BikeE, Miyata 110, and some others. Somewhere.
[QUOTE=akatsuki;6871417]Instead of top-mounting the cables, why not just put cable housing over the entire length of cable so that they don't get gummed up (I haven't done this, but I was just wondering)?
...QUOTE]
I thought of this immediately when I started monkeying around with my Concours frame - it had no cable stops, just braze ons for cable routing, so the cable housing makes the full run from shifter to derailer. I do suppose some people will say that there is the extra drag on the cable and sluggish performance but with teflon cables and modern housings I find it a non-issue. On top of that I managed to have some "extra" krytox for the cable housing extis/entances.
As for the original question posed, cyclocross began as bikes made up from old frames hanging around and whatever was in your parts box. Modern 'cross bikes as one can tell, have several different preferences. But in general, higher bottom bracket, lower-trail geometry for quick handling, clearance for wider tires of course, and gearing a bit lower than what is used for standard "road" bikes, and handlebars are typically a bit wider and higher. After that I think you start getting into preferences more than definitions.
...QUOTE]
antisocialite
the leader cross frame is in my mind the perfect example of a company just slapping canti mounts on a crit frame and calling it a cross bike. and by starting this thread that seems to be the sort of thing that mike's trying to avoid.
assonfire
LEADER doesn't sell the "CX" bike any longer so perhaps this is why.
Bikes: SS Surly Crosscheck; '91 Cannondale 3.0
Higher BB, lower trail, clearance for wider tires, disc or canti mounts, top routed cabling, more upright geometry in general (i.e. shorter TT for a given effective ST length).
I'm not picky, either compact or not, I can get both up and over barriers.
Fails at being impressed
For the really nit-picky stuff:
chainstay bridge undrilled and no bottle cage bosses. (No room for a bottle when you're putting your arm through the main triangle, nor will you be installing caliper brakes.)
antisocialite
^agreed that those are hallmarks of a race frame.
still, i don't think a drilled bridge or bottle mounts (or rack, fender and disc mounts, for that matter) make the frame any less raceworthy.
as someone who uses his cross race bike for other purposes, i'd rather have em. if it were something that somehow inhibited my ability to race on the bike, i'd probably rather not.
iPwn.
Location: Sackville (School)/Saint John, New Brunswick, Canada
Bikes: 2004 Norco Wolverine (Blue) set up with Semi-Slicks. Mid-1970's Raleigh, converted to single seed, (soon to be) all white.
...anything that can get yer *** across a finish line?
Tiocfáidh ár Lá
For me shouldering is very important. I'd rather shoulder a bike for stairs or long run ups rather than roll it through the mud. So compact geo is out. Top mounting cables I like too. And one of the best and imo most important braze ons that I have ever seen was a bottle cap opener on the chain stay.
Some frames have no braze ons not even for water bottles but I say go ahead and put everything on it I mean why not make the bike versatile? Your not going to race cross on that bike for ever so some day you may want to make it a commuter and or it makes it more resellable.
Bikes: Sanwa road bike with SunTour components. Gary Fisher Joshua F1 with XTR
Why canti brakes? Nothing else still uses that method right?
