Hammering my rim back in place?
I recently crashed, and my front rim has spot that is compressed inward by 2-3mm, no amount of spoke tightening can get this inward "bump" right, can I hammer it using a mallet back in place? The rim in question is Alex DM18.
Bikes: like 15. my favorite a 1951 schwinn spitfire cruiser. also have a 1959 amf roadmaster, 1962 jch deluxe cruiser among others.
id love to see exactly what it looks like, but i have "fixed" rims in this manner before, usually cheaper ones. if the bump is inward, wouldn't you rather use a pair of channel locks or something like with a rag between the device and the rim to bend it back out. and how long is the spot vs just how deep it is? if you try to fix it, just do little at a time and get it as close as possible without doing harm to the braking surface if so equipt.
The good looking one
Bikes: gary fisher, Schwinn Woodland
I have used a adj. wrench, and very very carefuly, bend the rim
back.Try going a little bit at a time, and again go slow.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Always consider rim "manipulation" as a last resort. If equal spoke tension does give you a straight rim, be prepared to replace that rim sometime. Any rim that is not held true by even spoke tension is a rim that is going to give you trouble.
The perfect solution is to pull the rim off there and see what you have to work with. And that will probably mean replacing it.
But, if money or time are precious, then go ahead and try to move it back in place and see if you can steal more mileage out of it. I have done it. Many of us have. Sometimes it starts to go wonky again on the first ride. Sometime, mysteriously, it lasts forever.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
The centre of the red highlight is compressed inward by about 2 to 3 mm. This rim is available cheap ($20 at LBS), but I like to savage it if I can, I have to relace it anyway should I need to buy a new one.
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
Let's say the dent is at spokes #9 & #10. You can loosen 8, 9, 10 and 11. Then tighten 6,7,12,13. This will help force the dent back out. This works for minor dents.
You can also use a rim puller, but they cost more than your rim unless you can borrow one. If you can, you loosen 6-13, pull the dent, then re-tighten.
If you decide to replace the rim and can get one almost the same so you can reuse the spokes, then tape the new rim next to the old rim, lining up the holes. Unscrew each spoke and put it into the new rim, true it up, and off you go.
Loosen the spokes in the dented-in area fully. Lay a 2-ft long 2x4 through the spokes. Hammer the 2x4 using the spokes to guide it. Shouldn't need more than 1-2 hits on an alloy rim. I've had to pound chrome-plated steel rims quite hard many times to get them to conform. But it eventually worked.
The plastic deformation in the aluminum rim makes that area weaker.
I would invest my resources in a new rim (DM18) and replace it, making sure you get the tension correct.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
Forget trying to "bend" it back. Waste of time, effort and will not work properly. You have an unexpensive rim that is cheap and easy to replace.
