Best deal on a 10Ah36V LiFePo4 battery pack?
Oooooooofffff SALESMAN!
I'm looking on purchasing this battery for the E-zip bike.
The best deal I have found so far was $568 which includes: 10Ah36V LiFePo4 battery pack in bag+BMS+2A charger ( 6 hours).
I was wondering if anyone has found a better deal?
That's right around what I paid for my 20AH pack.
Someone else posted this link, they may be worth checking out.
https://www.falconev.com/batteries.html
P7 Fanboy
I noticed ping is selling several versions of this battery.
What is the main difference between the 10Ah, 12Ah, 16Ah and 20Ah 36V batteries as far as applications for the e-zip bike go?
P7 Fanboy
Now that I've read up a little more carefully about over-volting E-zip Trails bikes, I'd be cautious about using ping batteries to do so.
Too much current draw.
Where Ping recommends operating a 36V 12ah battery at a current discharge of 12 amps, with occasional spikes to 24 amps, that Ezip will want to draw more like 30 amps, with spikes up in the 40s.
The ping pack has over-current protection that kicks in somewhere around 25-30 amps.
You'll be tripping that battery during no pedal starts and going up hills on a regular basis and worse, the ping battery might be worked too hard on a day to day basis to live a long life to see 1000+ cycles.
Although a ping 36V 20ah battery would be better, still you'd be operating it beyond its rated discharge rate of 20 amps anytime you dig deep into the throttle.
Sorry I brought up Ping, probably not the ideal choice in your particular application.
Those falconev batteries look like they could handle the current, but the math seems to indicate, using a 36V 10ah, you'd only get about 10-15 minutes of distance, no pedaling, heavy throttle. A 36V 20ah should double that.
Bikes: Fuji Team Trek FX Bianchi MTB
P7 Fanboy
Not from firsthand experience, but this user saw these results:
Bike 2008 Ezip trailz mountain bike
36v 10ah lifePO4 battery pack
Tested twice over two days in hot weather to get a base line and averages
Day 1 94 degrees, Day 2 92 degrees
Total distance 12.98 miles
No peddling at all not even on starts
Started with fully charged cells, measured at 42v
Stopped 17 times for lights, stop signs
Tested on a 4 mile loop that is 50% down hill and 50% uphill
2 miles down, then 2 miles up, hill is mild nothing major
Speed down hill avg. 27 - 29 MPH
Speed uphill avg. 23 - 25MPH
Average amps 34, max amps 42
Quoted from this thread:
https://endless-sphere.com/forums/vie...it=Ezip+Trails
I hope I'm not mixing up bikes here.
P7 Fanboy
It's on the second page.
I was calculating using a falconEV 10ah battery, and figuring current draw 30-40 amps.
If it means 450 watt output (which is all I would really care about) and lets grant it 85% nominal efficiency, the power input would need to be about 530 watts, or 14.7 amperes at 36 volts, 22 amperes at 24 volts.
In this case we could imagine a 36 volt 12AH BMS-controlled pack to probably cutout from time to time, a 15AH pack may not.
Right now the only LiFePo4 battery pack I'd consider would be one from Ping.
36v/12ah $319
https://www.pingbattery.com/servlet/StoreFront
Nick
36v/12ah $319
Nick
Bikes: Electra townie 21, electic conversion kit, Dahon folder ,Customized Nashiki
try looking at www.itselectric.ca
the batteries are pretty good there
E-BikeKit™ Owner
https://www.e-bikekit.com/buybatteries.html
We have just started selling a new LiFePO4 pack we have been working on for months. A new USA "Dealer Friendly" 36v/500w kit that was made to go with the battery pack will be unveiled in the next week or so.
Liked 6 Times
yes i read the review last nite looks like my next pack
https://endless-sphere.com/forums/vie...php?f=4&t=8452
P7 Fanboy
Yeah it does look good. Too bad there are no 48V packs available yet, better yet, split in half for panniers.
I use one of the 48v packs from ItsElectric! and I have never had a problem with it. they arent that big either
