Tektro 720 Cantis
Tektro 720 Cantis
Anyone here try the Tektro 720's? I've heard some but not a lot of feedback. They're about as much as Shimano BR550's. I know they're not Pauls but how good are they for the money?
Don't smoke, Mike.
Bikes: Devinci Tosca, IRO Rob Roy
I just installed a pair of those a few nights ago ...
They're seriously great brakes, even moreso because of how little they cost. There are set screws to adjust the spring tension of each arm, you can offset the yoke of the straddle cable to either side or perfectly centered and then bolt it in place. What else ... pads with dome washers (included) make toe-in/out a breeze. I also like how wide they are and that they're pretty light.
If I had a con it's that w/ so many different adjustments possible you really need to ensure that those tiny nuts/bolts aren't going to work loose. Blue loctite is your friend.
Bikes: Bianchi Axis (commuter), Specialized Tricross S-Works, BMC Team Machine SLT01, Mercier Kilo TT
I recently switched to them as well. They are great for the price.. I didnt like the stock pads.. switched to kool stop mountain pads and they are perfect.
Share the road.
I used them for my Cross Check build. The stock pads were ok for a while then I opted for the Kool Stop Mountain pads.
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
I too run one in the front with kool stop pads. I haven't tried many others but I do like these better than the avid shorty 4 I had previously (with the same pads).
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I'm getting these for my Cannondale build with the IRD Cafams in the rear. NAD now the 720 come in a polished silver to match the IRD's.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
10 Speed
I just replaced the POS Avids with these Tektro's on my Jake. For $26 I'm now able to stop relatively well in mud, muck and snow. I like the adjustability and wide yoke. IMO, cantis will never measure up to good calipers, but for the crosser the Tektros are a good deal.
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I'm trying to avoid heel strikes but I'm not sure that's really an issue. Technically the 720's have more power by design but you really don't need as much power on the rear. According to Paul, there is an approximately 10% reduction in power between the neo-retro's and the touring calipers. I'm assuming that the difference would be the same for my planned setup.
I'm running the cafams on both front and rear on my poprad and they are outstanding. I tried to use 720's but I had problems with the spring not fitting the canti bosses. I guess the 05 poprads had a weird front canti boss.
Last edited by Cynikal; 03-06-09 at 12:35 PM. Reason: painkiller are messing with my brain
I'm trying to avoid heel strikes but I'm sure that really and issue. Technically the 720's have more power by design but you really don't need as much power on the rear. According to Paul, there is an approximately 10% reduction in power between the neo-retro's and the touring calipers. I'm assuming that the difference would be the same for my planned setup.
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I talked to my lbs about the issue and he had never heard of anything like it before. On the poprad canti bosses the spring hole is not closed and the spring would pop out. I tried several other cantis in my parts box including older XT's and nothing else had the issue. If you are deciding between the XT's you have and 720's, they should both be fine but the 720's (or new canti's that use vbrake pads) are significantly easier to set up and adjust. Just my 2 cents.
Body By Nintendo
Location: Videogames ruined my life. Good thing i have 2 extra lives.
Bikes: Giant TCR2, Giant TCX, IRO BFSSFG SE, Salsa Casseroll, IRO Rob Roy.
I switched to them on my IRO Rob Roy for the back brakes because they allowed for more adjustability when positioning the wheel in horizontal trackends.
[i picked a second set for the front because i liked them so much, just haven't gotten around to installing them yet...
One of the things that's drawing me to the 720's are the pads. I'm really satisfied with my vintage Shimano brakes but really don't like the pads.
Fax Transport Specialist
Which koolstop salmon pads do I get for the 720, the ones that come with a threaded post? or the shimano dura-ace/ultegra/105 style replacement pad? is that a little metal clip that I pry upwards to remove them? I didn't see instructions for pad replacement on tektro's website.
You can get just the replacement pads for v-brakes. Looks like they're call 'Thinline Cantilever' on the kool stop web site. https://www.koolstop.com/brakes/index...chor-Also-6785
Just removed the clip, slide out the old pads, slide in the new ones and replace the clip.
Bikes: Yes
Quoted: 3282 Post(s)
Liked 4,029 Times
The ones with a threaded post would also work if you happen to have those already.
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
i have the cr720s. I didn't like the screw together yoke that came with it. I ended up using my old yoke.. one less screw to come apart.
Mitcholo
Bikes: 2010 Mitcholo w/ Sram Force/Red
I just bought some in silver for my Guerciotti and per your instructions, I'm using some salmon Koolstops on them.
Thanks for the advice!
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
I have some. I've used them in a bunch of races already. They have great mud clearance, but I'm not super happy with their braking force yet. They are better than the brakes they replaced (frogslegs and avids), but I don't think I have the set up right yet. Mud clearance was great in the muddy race I did. I got a remount wrong today, and I bashed my knee on the rear brake which necessitate stopping to fix it...
Quoted: 2953 Post(s)
Liked 3,106 Times
I don't have much experience with canti brakes, but I bought these based on the price and the good reviews. Once I got them set up, they work great. I can't imagine that the brakes I've seen for 3 or 4 times as expensive would work much better.
Bikes: 2005 Fuji Cross Pro, 2006 Allez Sport, Mid 70's French Bike named 'Pierre'
They are inexpensive, $50 total for both front and rear including shipping. I've used them for 3 races now. Love them. MUCH better than the crappy Avid Shorty 4s I used to have. No toe in, no squeal at all. I get some fork shudder, but only when I am going slow ( SUPER SLOW, like 2 miles an hour) across the parking lot trying not hit people after I finish a race.
