Handlebar won't stay tight
I had to buy a new stem for my bike. I have an oversized, extra wide in the center, handlebar.
The top and bottom clamp sides of the stem (where the handlebar is attached) do not touch after tightening. I have tried "locktite", and adding "padding" --- but when I ride the hoods and extert extreme pressure (when breaking at the end of a steep downhill, the bars rotate downwards.
Its easy enough to tighten, but it is a pain.
Does anyone have any ideas?
Thanks,
glenna
Thanks,
glenna
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Loctite will only keep a fastener in place. "Padding" is a vague term. You either need to get a stem from the same people who made your handlebar or find a proper shim to take up the open space between the stem clamp and the faceplate.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
It sounds like your handlebars are 31.8mm (oversized). Are you sure you got the appropriate stem? Also, most faceplates will exhibit a small bit of gap even when tight. If there's a very large gap (bigger than a 1/16") then you probably have the wrong size handlebar clamp on your stem. As others have said, grease the threads and if it's an open-face multi-bolt faceplate make sure you are tightening everything evenly. Also make sure the gap is equal at all the interfaces. A torque wrench is a good idea. Another idea would be to go to a stem with four bolts as opposed to just two if you haven't done so.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
About the shim, are you saying there should be NO open space between the top and bottom of the clamp?
i.e. top and bottom of clamp do not touch, therefore the bolt threads are partly visible. Use the shim to cover the bolt threads?
My padding is a few layers of velcro (I am not using the sticky side).
Originally Posted by shaq-d
what is padding? anyway, grease the threads.
sd
sd
What will greasing the threads do?
DEADBEEF
Liked 6 Times
I will grease the threads, get rid of the velcro.
The gaps are about even and pretty small.
If that does not work I will look for a 4 bolt stem.
The handle bars are oversized. The stem was obtained by a local bike shop that really does know its stuff. I had to bring the bike in before they bought it for me...and they installed it.
The problem is, it is a hard fit. The stem rise is 45 degrees! I needed to get my seat level with my handlebar because of my back. Not many companies make a stem with this rise for oversized handlebars, however.
I will post back after the weekend with the results.
Thanks, all.
Thanks, all.
DEADBEEF
Liked 6 Times
If you want to use something to add a little more friction between the clamp and handlebars, try a small slip of sandpaper.
hello
So what does your LBS say about the slippage? If they sold you the stem for an oversized bar, I'm sure they gave you the right stuff. Something's not right here. Oversized bar and clamp combo make for a very secure solid setup.
New to bikeforùms.net
All you need to do is tighten it more.
No need for and of this crap these idiots are talking about.....grease......shims.....**********????
Tighten it...........
Use the torque specs and tighten it within them.
It's amazing to me that we spend amazing amounts of $ on bikes and associated parts only to disregard the instruction sheet and its wisdom. Torque specifications are from the manufatcurer who has spent a lot more $ than any of us making sure it will hold properly.
I have NO idea why anyone would shim and/or grease the threads on perfectly usable parts that were ordered specifically for this setup. Would you suggest I jam a stick in bewteen the brake pads and rim when the pads wear a little?
Sorry, but you need to trust the manufacturer with regard to torque...and USE a torque wrench. They go on sale at Sears every few months and are well worth the $60.
A torque wrench alleviates the gueswork of tightening a bolt. Sometimes it will "feel" too tight but not be even close to what it should be.
Tight is tight and too tight is broken.
PJ
PJ
DEADBEEF
Liked 6 Times
I stand corrected.
Although (I'm guessing it's because I'm not an engineer) I don't totally understand why a little grease will distribute a load on a threaded part. The fact that the threads engage should already do that shouldn't it? I could see the grease allowing the threads to be seperated later on though.
PJ
PJ
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
You grease the threads so the bolt can be removed later. As you ride, you sweat, and that can corrode steel and aluminum parts.
Take the velcro padding out. If you need to shim the stem to the bar, cut an old coke can and use that.
DEADBEEF
Liked 6 Times
I stand corrected.
Likes For khuon:
Quoted: 2368 Post(s)
Liked 1,762 Times
You would need the shim if it were the other way 'round, that is, an oversize stem with a bar that's too small for it. If that were the case, the allen bolts would "bottom ou" but the stem would not be tight over the bar. As it stands, the stem isn't even all the way 'round the bar, so it can't be too loose/big for it. As has been stated, just tighten the allen bolts some more, until the bar stops rotating in the stem.
Quoted: 11 Post(s)
He may have a stem that was milled out just a bit too much where the bolts bottom out before it clamps the bar tight. OR, the bar was not formed correctly, and the stem doesn't clamp down enough.
Can I drop a bolt in to stop rotating handlebars?
I have a set of ape-hangers on my fun bike, and a similar problem to the poster's.
If I yank hard when biking, like climbing a hill, the bars will move. I know, you don't like ape-hangers, but I'm reliving my pre-teen years.
I've tried tightening, over-tightening, and pounded out a beer can as an extra shim.
I think I'm going to drill a hole and drop a bolt in. I suspect this might be a bad idea in a fall or crash, but IDK.
Any thoughts or advice?
Quoted: 443 Post(s)
Liked 1,038 Times
The hole will eventually wear and develop slop from the same force that causes the handlebar to rotate. Get a stem with a faceplate that tightens with at least 2 bolts.
Also this thread is almost 20 years old - next time just start a new thread.
Quoted: 572 Post(s)
Liked 512 Times
Likes For grumpus:
Advocatus Diaboli
Quoted: 4821 Post(s)
Liked 1,556 Times
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
,,,thread from 2004, and Glenna gave up after 7 posts. I don't think this helped much.
