Physics, motorcycles, and turning faster than everyone else.
Argh!someness
Bikes: GF Cobia
So how far can you lean off a road bike when taking a corner without toppling over?
I mean, that's how motorcycles turn. Would you be faster in a corner where you wouldn't lose much momentum without pedaling by dropping over and down to lower your center of gravity so you could make it through the turn faster than trying to pedal and leaning like normal?
I'm not talking about putting a knee down, but about getting the butt almost completely off the seat.
Bikes: Limongi custom road; GT Avalanche 1.0
I think the tread on racing motorbike tires are curved up into the sidewall to support the hard lean. A bicycle tire would probably just slide right out from under you if you leaned that far.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Pokemon Master
if you want to know how far you can lean a bicycle over, ask Menshov.
leaning off will allow more surface area for the tire during the turn, but i'm much more hesitant to test the limits of the road bike since there could be cars and the dinky helmet plus no gear kind of scares me. i do get my butt off the seat and put my weight on the outside pedal. with a motorcycle background i found that i do carry more speed through the turns than most of the other group riders i ride with. momentum FTW! it really helps on sharper turns that lead up to a hill.
oddly enough i don't have a problem on the race track with the motorcycle though
pan y agua
Quoted: 1483 Post(s)
Liked 767 Times
Incorrect. Read the various threads about countersteering. You turn a bicycle (at speeds above a walking pace) by countersteering to induce lean, which in turn, turns the bike.
So yes you turn the handlebars, but you turn the handlebars for the purpose of making the bike lean. The lean is not a side effect; it's what makes the bike turn.
You could get lost and die.
You could hit a tree and die.
Argh!someness
Bikes: GF Cobia
Leaning has everything to do with turning on a motorcycle when you're starting to push the limits. Leaning yourself off the bike towards the ground lowers your center of gravity and allows the bike to stay more upright, which in turn allows the bike to be able to lean farther while going faster.
Liked 5 Times
actually with the short wheel bases of road bikes, I wonder what the turning radius is.
Argh!someness
Bikes: GF Cobia
So why don't bicycle racers have suits and helmets that allow balls out without worrying about tearing yourself up too badly? They don't have to be as big and heavy as a full leather suit of course, just enough there to offer some protection.
Pokemon Master
i've ridden for 14 years, raced for 7, and i'm 19. you aren't explaining anything *correctly* to me.
because the tires won't handle it, and they can't go fast enough to counteract the force of gravity pulling them over when they lean past a certain point.
Argh!someness
Bikes: GF Cobia
yes, but let's see you lean a motorcycle with a fixed steering head. no really, let's see you do it.
turn the handlebars farther = lean farther.
go faster = don't fall over when you turn the handlebars farther, which means leaning farther.
i've raced motorcycles for 7 years and ridden for 14 (i'm 19), i think i know what's up.
Looks like I got 7 years on you if you want to count the little 50cc my dad had me on when we would hit up where he was teaching the MSF course at.
Liked 5 Times
any extra padding gets uncomfortable, sweaty and a source for chafing after a while.
well, there is an event like that. disc brake 29'er with drops or a disc CX bike, equipped with slicks, going as fast as you can downhill on a paved road, with full protection.
I can't remember the name of the event, unfortunately.
Pokemon Master
I didn't say that you could turn a motorcycle without turning the handlebars, I said that once you start to push the limits, than it has everything to do with the turning. Body position affects CoG which affects how far you can lean. Controlling lean angle lets you go faster by not leaning the bike as far and giving you more ground clearance vs. speed than if you were inline with the bike itself.
preach on, motorcycling god.
Argh!someness
Bikes: GF Cobia
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Two major reasons a motorcycle can almost always take a turn faster than a bicycle:
1) Tire contact patch with asphalt: A motorcycle is riding on two patches almost the size of dollar bills; whereas a typical road bike is riding on two contact patches about the size of nickels. Also the motorcycle contact patches are gooier and more compliant than the comparatively hard, inflexible contact patches on the road bike (which are better at reducing rolling resistance and more aerodynamic.)
2) Motorcycling gear. I passed a motorcycle (admittedly an older guy in jeans on a non-sport bike) and two cars my last time down Palomar on my Felt, but I would never take a hairpin at 50 on my bicycle like I do with my Kawasaki.
Bikes: 2015 Niner RLT9 / 2006 Felt F5C / 2012 Stumpjumper
Like already stated, motorcycles have a larger contact with the ground, and are stickier tires.
Motorcycles are heavier, which is more force pushing against the ground.
And you aren't going to lean very much unless you're going very fast on a very tight turn, which would not be very likely on a bicycle. It's simple mechanics.
Fuzzy logic
Bikes: 2002 Lemond Buenos Aires
If you watch some of the fast descents on the TDF you'll notice the riders sticking out their knee. I'm sure it helps keep the bike more upright to take the corner a little faster, but like everyone said, the tires just don't allow you to lean over too far.
Announcer
As far as my knowledge takes me, the trouble you'll have is with the constant loss of speed on the bicycle. With the motorcycle, you're accelerating halfway through the turn. Try pedaling the bike when you're butt is off to one side.
Quoted: 389 Post(s)
Liked 270 Times
For example: if you coast with your hands off the bars and stick out your left hand, your direction of travel will be altered to the left.
Quoted: 659 Post(s)
Liked 7 Times
Motorcycle tires are generally more optimized for traction whereas bicycle tires are more concerned with rolling resistance. But the maximum speed through a downhill turn isn't all that different with the motorcycle only having a slight edge. Both are limited to about 1G of lateral acceleration when on a flat road - i.e. the center-of-gravity will be at a lean angle of 45 degrees from the contact patch of the tires. Here's a picture of Jobst Brandt when he was testing tires for Avocet.
Two wheels, two skis...
Bikes: Tarmac SL4, Lemond Victoire, Titus Motolite
Quoted: 10 Post(s)
Because this is an unfortunate part of my nature, I thought I'd pop in to correct some of the arm chair physcis here.
Tire contact patch alone doesn't determine corning ability. The weight of the turning object plays as important a role. Yes, greater weight means greater normal force (to the ground) and greater static frictional force HOWEVER when an object is turning it is accelerating (changing velocity... yes, the velocity changes even if the speed is constant). To change velocity (accelerate) requires force. Newton's second law of motion tells us that a greater mass requires greater force to create the same acceleration.
So a bicycle does not necessary need tires the size of a motorcycle's to corner at the same rate as a motorcycle because it is so much lighter and thus requires less force to turn.
This does not mean I'm implying a bicycle can out corner a motorcycle. I'm just saying there is much more to the whole equation than contact patch size, or even the amount of static frictional force created.
Argh!someness
Bikes: GF Cobia
Quoted: 8435 Post(s)
Liked 9,378 Times
too hot.
Its hard to hang off a bicycle because your inside leg is all the way up and your outside leg is fully extended, so you can't get your center of mass over very far to the inside. With a motorcycle, you have both legs bent quite a bit at the knees, which lets you throw your weight way over the centerline of the bike.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
