Go Back  Bike Forums > Bike Forums > Recumbent
Converting from USS to OSS Superman-style
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Old 08-05-09, 02:10 PM
yangmusa
Bikes: Brompton H6, Schwinn Mirada, Cruzbike Sofrider. Used to own: ICE B1, 2 F-frame Moultons, Koga Myata Elevation 5000 mtb, Challenge Hurricane, Riese & Mueller Birdy Silver, Actionbent Tidalwave 3
Quoted: 14 Post(s)
I recently wrote about my experiences testing some high racers. While I really loved the bikes I tested, I think I've decided that I can't quite justify the upgrade (yet). But I very much liked the superman-style open cockpit setup and have been thinking about ways to convert my bike.
As you can see from this picture, my bike has a fairly short wheelbase and the fork stem is fairly close to the seat in relation to my legs.
I've been thinking of getting a RANS Flip-It, stem (or this stem) and adjustable open cockpit handlebars.
So my questions are:
  1. Can the Flip-It be locked at any angle?
  2. Do you think the handlebars will need to be too far ahead of the steering column for this to work?
  3. Any better solutions?
I suppose it would be much easier to convert to "praying hamster" style bars. I had these on my previous bike and found them to be ok - quite aero and good bike control. However, I found that I tended to very very sweaty armpits with that closed position - and based on my brief test rides it seems like open cockpit would not have the same problem.
yangmusa is offline
Old 08-05-09, 02:32 PM
jeffh129
If you do follow through with the conversion check out the flipit and bars here
https://www.terracycle.com/
Better quality than Rans.
Actually talk to the folks at Terracycle. They can probably answer
your questions. You may want to e mail them that photo first. They are good people. They'll help you out.
Let us know how it goes.
jeffh129 is offline
Old 08-05-09, 02:38 PM
yangmusa
Quoted: 14 Post(s)
It had better be - there's quite a cost differential too...
Good idea. Their knowledge might make the additional cost worth it.
yangmusa is offline
Old 08-05-09, 06:01 PM
PaPa
PaPa's Avatar
The potential problem here, is whether or not your revised grip location will fall rearward of the steering axis (the red line), and by how far. And, whether or not you can tolerate the reach. Ideally, 4" (101mm) to 6" (152mm) of positive (aft of steering axis) tiller would be nice. Otherwise the bike's steering will feel overly sensitive and self-centering attributes will be reduced. This was one of the problems with the 'nervous' Sun Speedster - zero or negative tiller, depending on the rider.
PaPa is offline
Old 08-05-09, 06:08 PM
yangmusa
Quoted: 14 Post(s)
Oh, my hands will be at least 5" forward of the line... The open cockpit setup is intended to be with arms more or less straight out in front, right? I think it would be quite cramped if my arms were to be behind the steering axis.
That very interesting. On upright bikes, especially road bikes, the grip is over very far forward of the steering axis. My impression from riding lots of different upright bikes is that it increases stability. But of course recumbents are different, and so it doesn't surprise me that the dynamics should be different.
Hmmm, maybe the lesson from all this is that my bike's geometry just wasn't designed in a way that will accept open cockpit handlebars.
yangmusa is offline
Old 08-05-09, 06:16 PM
PaPa
PaPa's Avatar
Not good - I can assure you, you won't like the handling with that much negative tiller.
On an upright, the rider is usually weighting and pushing forward on the grips. But when seated on most recumbents, the weight of the arms are effectively pulling the grips rearward - just the opposite.
PaPa is offline
Old 08-05-09, 06:55 PM
PaPa
PaPa's Avatar
Correct. Because of two issues:
1.) the wheelbase is too short. (this places the head tube (steering axis) too close to the rider's shoulders, inhibiting or eliminating the use of positive tiller).
2.) the head tube angle is too shallow. (again, placing the steering axis too close to the rider's shoulders).
PaPa is offline
Old 08-05-09, 10:52 PM
yangmusa
Quoted: 14 Post(s)
Ah well. When it comes down to it, I rather like that nobody can work out how my bike steers
Now they'll stay in the dark...
yangmusa is offline
Old 08-05-09, 11:54 PM
PaPa
PaPa's Avatar
Not mine - a Google find.
PaPa is offline
Old 08-06-09, 12:03 AM
yangmusa
Quoted: 14 Post(s)
I'm not very keen on the look of the Actionbent OSS handlebars. Looks-wise, I had been hoping to achieve something more like this:
I think I'll stick to USS for now. I might reconsider praying hamster, as Actionbent has done that too and I used to have one of these and suppose I could live with that setup again.
Otherwise I'll aim to ride more and worry less
yangmusa is offline
Old 08-06-09, 09:58 AM
jeffh129
Boy, I don't know. The OSS on the Speedmachine looks very uncomfortable. Take a look at the Bacchetta Giro 20 or the Giro 26. That's what you'd need.
jeffh129 is offline
Old 08-06-09, 10:41 AM
yangmusa
Quoted: 14 Post(s)
Agreed, the Bacchetta system looks ok too. But if you look at the relationship between seat, steering axis and hand position, you will see that PaPa is right - it won't work on my bike because my seat and steering axis are too close together.
yangmusa is offline
Old 08-06-09, 01:57 PM
jeffh129
I didn't mean an upgrade to your current bent.....I meant a whole NEW Bacchetta
jeffh129 is offline
Old 08-06-09, 01:59 PM
yangmusa
Quoted: 14 Post(s)
He he. The Giro 26 is one of the highracers I've tried, and I'd have to say I was quite impressed...
yangmusa is offline
