Which Kool Stop Pads?
Old 08-19-09, 05:48 AM
AModernDrunkard
But these go to 11.
Bikes: Charge Racer, Mars Spezial Klapprad, '36 Hawthorne, Sears Stingray
I see that everyone reccomends getting koolstop pads for their brakes. I have torn through my pads pretty fast and want to upgrade, but dont know which pads to get for my brakes. So which koolstop pads for tektro r536 brakes?
Thanks
AModernDrunkard is offline
Old 08-19-09, 08:28 AM
adriano
adriano's Avatar
Bikes: https://velospace.org/node/18951
get salmons or dual compounds in the duratype refill.
α
adriano is offline
Old 08-19-09, 03:12 PM
trelhak
Fails at being impressed
trelhak's Avatar
It depends on your rims.
The 'normal' black pads are for normal braking.
The salmon-colored ones are for improved braking in wet weather.
The green ones are for if your rim is ceramic coated.
The silvery-black ones, which are also twice as expensive as the others, are for carbon braking surfaces.
trelhak is offline
Old 08-19-09, 03:25 PM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times in 31 Posts
+1, I've used them (Kool Stops) for a few years and they still look new, now if your "skidding" and "doing tricks" and all that other stupid **** good luck finding anything beside asbestos that will stand up to that type of abuse.
VVV KoolStops VVV
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
ilikebikes is offline
Old 08-19-09, 03:28 PM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Quoted: 16 Post(s)
and the black and salom ones are for stopping normally and when your wheels get wet.
Old 08-20-09, 07:29 AM
elTwitcho
Live without dead time
I use just the salmon ones. Work great in dry weather and wet weather
elTwitcho is offline
Old 08-20-09, 07:54 AM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
Where can I get some of these wonderful brake pads?
Old 08-20-09, 08:02 AM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 130 Times in 97 Posts
Kool Stop pads are sold everywhere and come in a configuration for pretty much every type of brake made... the salmon pads are produced just like the old and legendary Matthauser brake pads.
They even come on old fashioned block style pads for vintage rides.
They stop well in every kind of weather and are extremely rim friendly... being softer they do wear a little faster but better that than grinding your rims to dust.
Sixty Fiver is offline
Old 08-20-09, 09:11 AM
Vinci
If your Tektros don't use a cartridge pad (meaning that they are one piece molded), you will need the Dura kit. It comes with a pair of cartridge holders (clones of the Shimano 105/Ultegra/Dura-Ace holders) and 2 pairs of brake pads (1 pair of salmon, 1 pair of salmon/black). They run around $20 for the set and make a HUGE improvement over the Tektro pads. Since I swapped mine out, my wet stopping is a lot better (even the dual-color pads), the pads don't seem to pick up as much trash (and subsequently damage the rim), and they don't squeal anymore. Well-worth the $20, IMO.
Vinci is offline
Old 08-20-09, 09:13 AM
croscoe
Liked 5 Times in 4 Posts
+1 on the salmon pads.
croscoe is offline
Old 08-20-09, 09:16 AM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
So if I have the holders, which refills should I get?
Old 08-20-09, 09:57 AM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Quoted: 16 Post(s)
I don't know how true this is as I mentioned I've had a pair for about two years and they still look new? I also heard (before I bought mine) that the salmon color wears out quickly? but so far there seems to be no truth to it? with my pads anyways.
Old 08-20-09, 10:23 AM
elTwitcho
Mine have lasted a couple months but there's some wear on them. There's no way they'll last two years for me. I also ride about 200-300K per week and bomb a lot of hills which involve extended braking at the bottom so that may be part of it.
Old 08-20-09, 12:00 PM
croscoe
If you have the Tektro holders, you'll need the Shimano style, IIRC.
croscoe is offline
Old 08-20-09, 12:03 PM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
Right on, thanks.
Old 08-20-09, 12:52 PM
mander
Along with salmon, silver, greenish and black, Koolstop also make yellow, blue and red pads. Anyone know what the story is with these? Is the durometer different or are they just meant to look different? I couldn't get any info off the website.
I got some red ones on a deep discount and though I've never used that color, the salmon and black KS pads I've used have been excellent.
mander is offline
Old 08-20-09, 02:30 PM
shecky
shecky's Avatar
Bikes: Rustbuckets, the lot of them.
Salmon (not to be mistaken for red) pads are reputed to be the ones to get. They were especially recommended for vintage rides with steel rims. For aluminum rims, I find their advantages to be marginal. But they work fine with all types of rims in all conditions. I've had sets for years, and while dirty, they don't seem especially worn out.
shecky is offline
Old 08-20-09, 03:42 PM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Quoted: 16 Post(s)
Ahhhh! I ride maybe 20-40 miles a week!
Old 08-20-09, 03:46 PM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Quoted: 16 Post(s)
See the following link.
https://www.koolstop.com/brakes/index.php
Old 08-20-09, 06:25 PM
mander
Originally Posted by ilikebikes
mander is offline
Old 08-20-09, 07:23 PM
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Quoted: 16 Post(s)
So!
Old 08-20-09, 07:33 PM
trelhak
trelhak's Avatar
Note that if you use salmon pads with ceramic coated rims, they will wear down quite quickly.
trelhak is offline
Old 08-20-09, 08:10 PM
shecky
shecky's Avatar
This is interesting. I'm not familiar with the whys of coating rims with ceramic, but it seems that ceramics are better insulators than bare aluminum, and as such dissipate heat less efficiently. As a result, friction heat is concentrated in the braking surfaces. This would seem to contribute to cause increased pad wear, as higher heat translates into softening pad material. This behavior is associated with brake pads on steel rims.
shecky is offline
Old 08-20-09, 08:16 PM
dayvan cowboy
Bikes: Fuji Track, Half built 70s Azuki
well i know what i'm buying for my bike next. I need new brake pads anyway.
dayvan cowboy is offline
Old 08-20-09, 08:20 PM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
Same here
This has been most helpful
