Will this affect the integrityof the helmet?
Bikes: Vision R40 Recumbent
I have an Specialized Airforce helmet. Love it, only a few years old, do not need a new one, will not buy a new one for a while. I use the visor. Mainly because it is what I attach my helmet mirror to. Attaching it to my glasses is NOT an option and something I WILL NOT do. Riding with out the helmet IS NOT an option either.
Yesterday the tab that holds the visor on the helemt broke. I tried super glue and it did not work. I could "drill" a small hole through the front of the helmet and use a cable tie to keep the helmet in place. But I am wondering if this will affect the integrity of the helmet or how much. I suppose if I had an impact to that small specific area it could affect it. Typically impacts to the front of the helmet are in the arear aboove the immediate front, which is where the visor attaches to.
Any suggestions? Before you answer let me make clear again:
1. Attaching the mirror to my glasses is NOT an option. Tried it and did not like it and it damaged a previous pair.
2. Replacing the helmet is NOT an option. Nothing wrong with this one, except the issue with the visor.
3. Riding with out the helmet is NOT an option. Don't think I need to explain this one, it should be obvious.
Thanks.
Thanks.
I have no idea if it would affect the integrity of the helmet. But I would try other options before drilling.
Have you considered buying a new mirror - one that is designed to attach directly to the helmet? That is what I use. Works great.
Also, have you tried RTV / silicone to attach your current mirror - or maybe 3M foam double-stick tape? I'd be hesitant to recommend 5-minute epoxy because it may affect the surface of the helmet - but another possible option. I'm not familiar with the visor attachment so don't know if that is feasible.
Bikes: Univega Gran Turismo, Guerciotti, Bridgestone MB2, Bike Friday New World Tourist, Serotta Ti
I'm not an expert, but I would think that a small hole drilled through the helmet would not radically effect its performance. The helmet works in a crash by having the foam collapse allowing the deceleration of your head take place over enough space and time to limit the maximum acceleration experienced. Removing a small amount of material should only change that by a small amount.
(edit) I'd try the glue suggestions first though.(/edit)
Speedo
Speedo
The integrity of the helmet will be shot. It will start lying to you, it will be worn by anyone, and it will practice 'creative' accounting.
Suggest you strap one of these over the helmet
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Try gorilla glue. It worked for me when I couldn't get anything else to stick to helmet plastic. Ideally you can rough the surface up a bit with some sandpaper first to give a better grip, and be sure to wet the surface first; gorilla glue requires moisture to react to. It'll work a bit with just moisture in the air, but a little more on the surface helps a lot.
Work: the 8 hours that separates bike rides.
When I say "drill" I mean use a small nail or screw to punch or poke a hole, not use a dril and drill bit.
Thanks for the gorilla glue idea. I'll try that first. If it doen't work I'll poke a small hole in and use the ties to attacht he visor to the helmet.
Bikes: too many
I'll second orrilla glue, strong stuff. Make sure you have a way of clamping it in position. Gorrilla glue works so well because it expands so you don't have unglued voids between surfaces.
A small hole won't efect the integrity of the helmet, make sure you go through a thick section and not right along an edge to make sure there is enough strength in the surrounding area.
As for the instructable image above (haven't followed link) putting bolts and metal in something designed to protect you, would make me a bit nervous.
Ken.
Ken.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
If you are worried about a couple of small holes in the styrofoam, note the large holes already there.
"He who serves all, best serves himself" Jack London
But you do bring up an excellent point - adding metal/other that could essentially turn into a projectile during an impact to the helmet is a really bad idea.
Mounting metal chunks, like a headlight or a camera, will certainly negate any small benefits a helmet provides as well. they don't test them with metal chunks attached. metal chunks increase the liklihood of a snag, or rotational injuries to the neck. If you hit one of those pointy little pieces directly in a fall, what do you think the local forces would be on the helmet underneath?
Seconded. It's amazing stuff. I wouldn't be surprised if Gorilla Tape was adequate to the job.
If I was going to make a hole in a helmet, then I'd probably be inclined to make it with a hot needle instead of drilling: helmets are very vulnerable and the thin shell is both delicate and critical to successful operation. Drilling might damage the helmet shell or it might not.
I suppose I could replace the visor. Here is the one I need: https://www.specialized.com/us/en/bc/...=9301&eid=4952
It is kind of hard to seebecause it blends in with the rest of the helmet in this photo, even in the enlarged pic, but the tab that broke is the top one. There is a little knob piece that snaps into an indention on the front of the helmet in the center most vent in the front of the helmet.
Bikes: Specialized Hardrock Mountain (Stolen); Giant Seek 2 (Stolen); Diamondback Ascent mid 1980 - 1997
Quoted: 62 Post(s)
Thanks.
Thanks.
Dogs like me.
Yeesh, it's not like the helmet provides much protection anyway. I think you are mistaken when you assume that there is some sort of complex structural interaction going on. It's just a wad of molded foam.
So, drill away, glue up, and don't worry about it.
This is true.
But this isn't. Helmet operation depends on the foam liner compressing against the thin outer shell, but shell failures are common and shell strength is marginal - because the shell is heavy, it is made as thin as possible.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,563 Times
I'm rather sure a bicycle helmet will provide just as much (i.e. just as little) significant risk reduction/protection to its wearer, whether it is intact, or drilled, zip tied or duct tapped to a mirror.
I'd try and talk to Specialized about the failure of the visor peg. Why did it happen? On the other hand, if it's normal wear and tear, exposure to ultraviolet light and so forth, a no-charge replacement might not be approved. If the helmet hasn't seen much of that in its 2-3 year life, as some have helmets haven't, maybe there's a problem with materials or production quality.
I use a cheap Bell Solar...it doesn't have a visor. Kind of wanted a helmet with a visor, but one reason I didn't get one is because it seemed to me that the whole arrangement of visor design and its means of attachment to the helmet...just simple holes drilled into the helmet shell...was weak. As it turns out, I don't need a visor anyway...the lip of the helmet edge mostly gives me enough protection from the sun's direct rays.
Re; the helmet shell's function: One of the really beneficial things a helmet shell with a smooth surface does is allow the helmet wearers head to slide away from the impacted surface rather than grab it, bringing everything to a sudden stop. I figure this has got to be better than hair and skull hitting the pavement, or one of the little cotton cycling caps between the head and pavement. Also, the best helmet shape minimizing twisting forces on the wearers anatomy is said to be the round shape, rather than any of those that have the elongated shape for style or aerodynamics.
