23.8mm Seatpost Dilemma
Bikes: 2011 Long Haul Trucker, 2015 Seven Evergreen, 2000 KHS Tandemania Sport, early 90s Trek Antelope, 2013 Surly Krampus
Hi All,
I recently bought a 1987 Peugeot Corbier Frame which came with fork, stem, and crankset. I am pretty much set restoring this bike, although I just realized after searching the net for hours that the seatpost size (23.8mm) is abnormal and very hard to find. I've come across many posts of people with the same problem, but not any solutions that seem feasible. The best solution I found was the 24mm post custom made on yellowjersey.org, but this costs $70, and I'm really trying to keep this a budget project (paid 25 bucks for the frame).
Many people seem to say shimming a 22.2mm is the best solution, but even those posts with a rail mount on top seem tough to find, and shims that fit this also don't seem to exist. The soda can shim solution seems to be popular, but is this safe, and will it hold up to daily aggressive riding? Any other safe budget solutions are welcome.
Thanks in Advance,
Zach
Thanks in Advance,
Zach
One solution is to pull an aluminum alloy 24.0 post off another old French bike and file it down to 23.8, which entails removing just .1mm off the radius, easy to do by hand in about 1/2 hr.
If you've got a local resource with a lot of cast off seat posts that would be where I'd look.
Bikes: NOYB
Requests for weird-sized French seatposts are a common occurance around here.
I'm a little surprised some enterprising machinist with a lathe somewhere hasn't decided to whip off some 22.0, 23.4, 23.8, and 24.0 posts from some aluminum round bar stock, send them off for clear anodizing with their other stuff, and flog them on their website. It's not a difficult project, and sales would be coming in from all over the place. Guess their insurance company wouldn't like it though.
It's got electrolytes!
Bikes: Self-designed carbon fiber highracer, BikesDirect Kilo WT5, Pacific Cycles Carryme, Dahon Boardwalk with custom Sturmey Archer wheelset
Just make sure you have plenty of extra post in the seat tube and use a shim.
It's perfectly safe. For proof just take a look at some of the seat posts on folding bikes.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
Bikes: 79 Peugeot UO8, 89 Peugeot Triathlon, 170$ Possibly a Raliegh Cross bike that I can kick your ass on...
Great State of Varmint
Liked 15 Times
QBP doesn't even come close to a 23.8mm seatpost. 22mm to 25.4 is blank. Use a shim. there is no way you could open the seat-tube wide enough to swallow a 25.4mm. And unless you have some old bike-shops around with lots of old parts in dusty boxes - good luck finding an old Francaise model to match/file. So I suggest 22mm and thin aluminum. You'll have fun fitting it - so prepare for experiments.
Need a QR seatpost-clamp?
https://www.loosescrews.com/index.cgi...&id=6279015687
I checked all the usual suspects - no one carries a ready-made shim for your purpose.
Thanks all, I have alot of lbs's around here but none that save any older french stuff. I'll have to try shimming, does anywhere know a place i could get a good 22mm post that supports rails?
Call me The Breeze
why don't you just use a separate clamp?
Quoted: 443 Post(s)
Liked 28 Times
Both of these have been sanded to fit:
Quoted: 443 Post(s)
Liked 28 Times
I don't remember what sizes were involved, but the top one was taken down quite a bit and it took along time. The bottom one is a 26.6 in a 26.4 hole and it didn't take long at all. The idea is to keep it round by sanding it equally all the way around. Turn it constantly. Both posts need repolishing in the pictures. A few seconds with some Mother's and they'll be beautiful again. They were both used posts and the resizing eliminated the scratches.
If I could get my hands on a 24mm post I definitely would sand it down like you described, but from my understanding, such posts are about as rare as 23.8 mm.
Bikes: Grifter BSA 20
Ive got a 24mm post, but its got a rusty bolt holding it together.
Also Im in Scotland. So not much use to you.
would reaming out the frame not work?
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
