Help with Rear wheel,( with pics)
Old 01-19-10, 05:34 AM
Brandon286
Ive been tinkering with this old fuji bike for the last couple weeks. Yesterday it was finally nice enough to go for a test ride. 2 things i noticed immediately were the front and rear wheels felt off. The front quick close on the front doesnt seem to want to close tightly and lock, any idea what could cause this? and second my rear wheel felt off balance, so when i took a closer look i found that on one side there appears to be a chain tensioner? but on the other side there is nothing just a regular drop out. i took the little tensioner thing off got the rear wheel lined up straight and it works fine. Is there supposed to be 1 of these on each side? and also i noticed shifting was slightly off after i took the tensioner off, i guess thats normal?
Brandon286 is offline
Old 01-19-10, 05:50 AM
Metzinger
Primate
Metzinger's Avatar
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
Liked 5 Times in 5 Posts
The clamping facets of the front quick release should start to press against the fork dropouts when the lever is about halfway closed (90 degrees). Push it the rest of the way to clamp it securely. If this doesn't fix it, go see the guys at the local bike shop. They should show you how to do it, or suggest a different skewer.
The rear spacer helps to locate the axle in the rear dropouts. They make for faster rear wheel installation. Some bikes have bolts that bear against the axle from the rear and allow fine tuning of the wheel position in the frame. I've ridden for the last 6 years without them. Again, make sure skewers are tight.
You can play with the position of the back wheel in the dropouts to see if there's a best position for the rear wheel in relation to the derailleur.
Metzinger is offline
Old 01-19-10, 05:58 AM
griftereck
Bikes: Grifter BSA 20
I had a frame where the driveside drop out shorter slot than the other side.
I think its so that the pulley wheels on the gear mech are at a better place relative to where the chain comes off the freewheel
That looks like a Suntour VX mech. Have you tried screwing in the adjuster that makes the mech pivot round the fitting bolt. Then making it go further back.
Also since that might be a 1980s bike. The fork drop outs overlock nut gap might be narrower than modern wheels are. Its 100mm nowadays. was around 90mm before. So if youve fitted a new axle it might be flush with the outside of the drop outs. there supposed to be in a little bit. so the QR ends are gripping on the drop out. not the end of the axle. If its a new axle. you could file a bit off the ends.
If its an old axle. is the bearings and all the locknuts in good order.
griftereck is offline
Old 01-19-10, 09:40 AM
Brandon286
everything is original, the problem im seeing is that the skewer is only clamping on a very small portion of the rear dropout, hardly any at that. thats what cause the rear wheel to wobble and almost come off on me. since i took that little adjuster off it seems to have a better fit and is steady. I was concerned that the piece was of some significance so i didnt want to screw it up by taking it off.
Old 01-19-10, 02:05 PM
BCRider
BCRider's Avatar
Bikes: Norco (2), Miyata, Canondale, Soma, Redline
Quoted: 45 Post(s)
Liked 49 Times in 38 Posts
The piece you took out is a spacer as the others have mentioned. The one you removed is just as important as the one you left in. They are typically used as a set to position the axle where the derrailleur wants it to sit while holding the axle square to the bike's center line. It sounds like you took the one side out and pushed the axle in further on that side. If so then your rear wheel is no longer in alignment with the center line of the bike. That may be why it feels funny now.
I hear you about the lack of contact area. And like griftereck I've seen a frame where the slot on the NDS is shorter than on the DS. Why they would do something like that defies logic. And if the setup has chewed at the frame from being pulled out a few times already then it becomes triply hard to ensure a good mounting. And it does look like they are barely into the slots. To get the best possible hold the inner flange nut and QR skewer should be in contact over the entire length of the slot edges. If not then I would say that something needs to be moved to make this the case. I wonder if someone in the past swapped out the quick release (QR) and the present QR isn't letting the wheel sit back far enough? Or perhaps the spacers are installed wrong and so the spacers aren't letting the axle sit back far enough? Or perhaps someone put in the wrong spacers at some point? It's often hard to determine stuff like this.
Then there's the issue that pulling the axle out of the dropouts may have damaged the metal to where there is no way to get a good hold even if you can shift it back a hair. In that case you don't have a lot of options, at least not cheap ones, but to move the axle position back to where the inner flange nut and QR can sit against undamaged metal for their entire contact surface. If that means removing the spacers to allow this shift either due to damage or to a badly set up original configuration then so be it. Note that the shifting may require some fixing up or may end up with some habits that you'll need to become acustomed to dealing with. But anything will be better than dealing with a wheel that is trying to leap away to freedom...
On the front fork I think griftereck hit the nail on the head again. I once had to file out and deepen the fork dropouts to allow a larger axle to fit correctly on a buildup using newer wheels. Without it the metal engagement of the QR and inner flange nuts looked really iffy. I carefully filed the slots until I saw I had a full surround contact for the QR and then I centered the wheel at the fork crown by touching up the "wide" side with a few short strokes of the file to trim the depth and center the wheel. It sounds like you may require that as well. If the dropouts don't stick down slightly past the QR edge and the edge of the axle flange nuts then it's time to mark the fork dropouts with a sharp pencil for some guide lines and start filing.
BCRider is offline
TakingMyTime
Bicycle Mechanics
57
04-21-18 07:34 PM
loimpact
Bicycle Mechanics
23
04-26-15 03:06 PM
rms13
Bicycle Mechanics
15
12-19-14 08:46 AM
jyl
Bicycle Mechanics
7
07-03-14 05:05 PM
pavalon12
Bicycle Mechanics
11
07-24-11 09:29 PM
