Avid Mtn BB7 arm not fully re-turning.
Old 02-23-10, 12:51 PM
corkscrew
We've run into an issue with my roomie's Cannondale F700.
It has Avid BB7's (mountain version) on it. The rear caliper arm doesn't retract all the way after the brake is applied, this leaves the cable loose enough to settle against the top tube. It doesn't regain tension until the caliper arm is manually reset.
We used Park Tool's guide to adjust them initially, but saw no mention of this.
corkscrew is offline
Old 02-23-10, 01:05 PM
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
My initial thought is friction either at the brake lever or in the cable/housing. Is the BB7 and/or bike new/used?
joejack951 is offline
Old 02-23-10, 01:09 PM
CastIron
Sensible shoes.
CastIron's Avatar
Bikes: A few.
If it's been exposed to the weather you should disassemble it and lubricate the area behind the piston. Both my BB5 and BB7 brakes suffered from corrosion in winter because they leave the factory dry.
Mike
Originally Posted by cedricbosch
It looks silly when you have quotes from other forum members in your signature. Nobody on this forum is that funny.
Why am I in your signature.
CastIron is offline
Old 02-23-10, 01:41 PM
joejack951
joejack951's Avatar
In contrast, my BB7 hasn't need any additional lubrication so far this winter during which time it's been exposed to plenty of moisture and road salt. YMMV.
Old 02-23-10, 05:41 PM
int19
There is a spring adjustment screw that you can adjust the return spring tension with as well. Its under "Fine Tuning" in the user manual:
https://www.sram.com/en/service/avid/...D=1&subcatID=1
int19 is offline
Old 02-23-10, 06:35 PM
bikinfool
I have senior moments...
bikinfool's Avatar
Bikes: Many
I'm also wondering about the cable/housing condition. Checking the spring tension on the caliper might help...
bikinfool is offline
Old 02-23-10, 09:35 PM
BCRider
BCRider's Avatar
Bikes: Norco (2), Miyata, Canondale, Soma, Redline
Quoted: 45 Post(s)
Liked 49 Times in 38 Posts
Yep, I'd first check the cable to housing friction on the section where it turns downwards at the seat tube. Also try disconnecting the cable from the caliper arm and see if it has a snappy return or if it is weak and maybe a little sticky.
It could be one of these things or it may be a combination of them adding up. If the bike is more than a few years old with lots of riding time start by changing out the cable and housings. That alone will really crispen up the brake lever feel. It won't STOP any faster but it'll feel a lot nicer. From there get in and clean and lube the caliper arm mechanism and adjust the spring from that point if needed. A few years of road grime can gum up the best of components.
BCRider is offline
Old 02-26-10, 04:34 PM
corkscrew
Thanks for the info guys - I'll pass this on to my room mate.
The bike has seen some abuse, but is at the tail end of a full rebuild. The brakes came with it. We replaced the cables/housings last summer, but I'm guessing we didn't smooth out the housing cuts well enough.
RVD72
Bicycle Mechanics
8
03-29-21 03:01 PM
Litespud
Bicycle Mechanics
8
11-06-18 09:54 AM
George
Bicycle Mechanics
9
11-04-16 07:41 PM
derekthelion
Bicycle Mechanics
4
07-21-10 11:48 PM
thegunner
Bicycle Mechanics
3
05-07-10 05:09 PM
