Proper form in a tailwind
Shuckin' and Jivin'
Bikes: Giant OCR3
Proper form in a tailwind?
Is it better to sit more upright with a decent tailwind to take advantage of the wind like a sail or best to still stay in an aero position?
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
I don't know, but everyone guesses so...
Probably depends if you are going faster or slower than the tailwind. A 25mph tailwind you are probably going over 30mph, so aero helps. A 50mph tailwind you are probably going less than 50 so sail up.
Shuckin' and Jivin'
Bikes: Giant OCR3
If the tailwind is less than your speed I figured you should stay aero but if greater than your speed sit up but I'm just an amateur and wasn't sure.
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
ride like normal.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
Shuckin' and Jivin'
Bikes: Giant OCR3
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
As long as your airspeed is positive, it makes the most sense to minimize your frontal area.
Upgrading my engine
Quoted: 125 Post(s)
I wonder how fast you really could go with a 50mph tailwind. The most wind I've ridden in was somewhere between 25-30mph, and I was easily cruising along at 30mph. I almost crashed in the crosswind a couple times, but it was worth it.
Of course you would need a big-ass gear and spin like mad too.
If you think about it another way, the speed record is over 150mph, drafting a special vehicle that sheltered the rider completely from the wind.
Arizona Dessert
Liked 2,169 Times
There are very few times when your relative airspeed is negative and it would be advantageous to sit up. Most of the time, a tailwind simply lowers your relative airspeed, or rather, you raise your ground speed to match what your normally encountered airspeed.
The only times I've traveled at the same speed as the tailwind have been on climbs. That's because gravity is the main force I am fighting, as opposed to air resistance. Otherwise, if I'm putting out enough power to go 20mph in still air, with a 5mph wind at my back I'd be cruising at 25mph and still have 20mph wind in my face.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
pan y agua
Quoted: 1483 Post(s)
Liked 767 Times
But if the wind is a few degrees off from a perfect tailwind, then it's going to still make sense to get aero, even with windspeed above your riding speed.
This calculator demonstrates that.
https://www.hedcycling.com/aerodynami...calculator.asp
You could get lost and die.
You could hit a tree and die.
Arizona Dessert
Liked 2,169 Times
Certifiable Bike "Expert"
You Know!? For Kids!
I find it easier to ease the main sheet and watch the tell tales if I sit up when sailing, I mean riding with a tail wind.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Tell me about it. Last time I experienced this was on a hot day at about 4:00 in the afternoon in a race in eastern OR (why the organizers thought starting a race at 2:00 in the afternoon on a 90+ degree day was a good idea, I'll never know). I was off the back after getting dropped for the second time, pushing 250-300W up the hill. Felt like I was working the trainer in an oven. I actually started getting chills ... which I think means the start of heat exhaustion. Not good.
Hills hurt.. Couches kill
Bikes: 1991 Specialized Sirrus Triple, 2010 Trek Madone 6.5 Project One, 2012 Cannondale Caad10, 2013 Trek Crockett
If you don't feel like there is a headwind, you're not going fast enough.
I don't have my post up (it's been in draft for a year or something). I rode in the Key Biscayne area just as Hurricane George hit. When we went out it was steady 50 mph winds, gusts to 80 mph. Since we went down there to do the Coconut Grove race, I had just TriSpoke/HED3 tubulars. I coaxed my teammate and his then gf to go out and ride with me. We struggled in our bottom gears going south but coming back... sitting up and coasting we'd go almost 20 mph. 54x14 up the Key Biscayne causeway bridge thing, going easy.
I told my friend I had to do a sprint with the tailwind. So I took off as hard as I could, spun my 54x11 as fast as I could. Did 60 mph for about a minute, limited by my ability to spin really fast for a long time. Passed a car on the road next to me.
Tons of fun.
cdr
Tons of fun.
cdr
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i only notice headwinds. maybe i've ridden in tailwinds but i would rather assume it was my enormous legs making me go faster
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
They were sketchy to say the least. We were all friends, rode together a lot. They used to do Thursday Night Sprints with me, he was my leadout man when we raced. We really knew each other well. So we and we rode in pretty tight formation going south. I remember a few times going sideways pretty hard. Since even a slight angle meant a vicious echelon (due to the high wind speeds) I'd usually be staggered in the safe direction off the next wheel. At times we were riding pretty much right next to each other.
I also had a pretty hard grip on the bars, much more so than normal. "Death grip" comes to mind.
When I was sprinting I remember wondering if the front wheel would take off sideways. I tried to keep my weight on the front of the bike. I basically jumped out of the saddle for only a couple downstrokes then sat down and spun.
I guess I'd do it again, with bigger gears, if I had a chance.
cdr
cdr
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Tons of fun.
cdr
Tons of fun.
cdr
Hey CDR,
I think I've heard that story somewhere before.
