cross bike ?
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
A cx bike is not the best all arounder. A 29er mtb is and I just built a Ti hardtail. Best all arounder I have owned. It is also pretty fast on hardtop with skinny slicks...within a mph or so of a roadbike...aerodynamics and weight keeping its speed down fractionally. Same wheel diameter as a cx and road bike but with wider rims and available with front and/or rear shock and taller rubber than a cx bike. They are also popular with rigid forks and single speed. Cx bikes beat you up for trail riding and jumping curbs in the city and their wheels are not as robust. 29ers have come into popularity because of their exceptional ride quality in particular compared to a 26er mtb and certainly compared to a cx or road bike on less than smooth surfaces. A good combo to own is a road bike and 29er.
I'm not trying to be snarky, but I think it would depend on what you mean by an all around bike and what you see yourself doing most with the bike. Like most things, there are compromises with each type of bike, and it's going to depend wholly on what you can and cannot compromise on.
Personally, I don't mountain bike or go on technical trails, so a cross bike (with multiple gearing and tire/wheel options) would be fine for most of what I use a bike for.
Quoted: 19 Post(s)
It depends entirely on what you do most. I have a CX bike and a 26er mountain bike. Used to be great but my priorities are shifting so I'm planning when I have the money to move to a proper road bike and a different 26er MTB.
Bikes: 2010 S1, 2011 F75X
CX bike (Spec. Tricross) and 26'er MTB here. CX bike is perfect for commuting and training. No issues with using it as a dedicated road bike.
Quoted: 2953 Post(s)
Liked 3,106 Times
I think if I could only have one bike, it would be a CX bike. You could swap wheels (or even just tires) and go from pavement to trail easily.
Quoted: 63 Post(s)
I use a CX bike as my main ride and the only thing slowing it down is me. Road tires and a compact crank and its a nice all around ride.
Bikes: Kona Jake (2006)
I've come to believe that if you can only have 1 bike, a cross bike is probably the way to go. But having gone from having 2 cx bikes to 1 and a road bike, I've also come around to the realization that (on the road) the drop-off from a road bike to a cyclocross rig is bigger than people think.
Quoted: 353 Post(s)
Liked 92 Times
I use a cross bike as my main bike right now. I swap out between 25s and 32s for road and dirt. The bike with 25s is plenty fast on the road and right now the engine is holding everything back more than the bike. I am going to be buying a road bike next year which then my cross will go to dirt duty full time.
A cross bike is a great first bike when you don't know what you want to do yet since it can do it all.
Danger to Himself
Bikes: 2008 Specialized Roubaix Elite, 2008 Trek 4300, 2006 Surly Cross Check
If you're only going to have one bike, a cyclocross bike is the way no way to go. You can throw road bikes tires on there and use it as a road bike. You could put commuter tires on there and use it as a commuter bike. Obviously you can use it as a cyclocross bike. Some cross bikes can accept larger tires, which will be fine for moderate level single track mountain bike.
A 29er is nice, but it can't be made into an effective road bike as much as a cyclocross bike. The cyclocross bike has the same disadvantage when it comes to converting it to a mountain bike. I'd rather have my bike cause me to be slow while mountain biking than road biking.
Bikes: Specialized Roubaix Comp, Soma ES
Demented internet tail wagging imbicile.
I am wondering if the speed difference could be related to the difference in chain rings or is the geo that much different ?
For example caad9 road and cx9 doesn't seen that much different except the the BB height ... or am I missing somthing
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
A cross bike is a great all around bike. I used one for racing and commuting and the commute was a 50 mile round-trip. I had road tires on it for the main commuting season and then switched back to cross tires during cross season. I ride it during early season as well.
If you plan on racing road though I would seriously consider getting a road specific frame/bike. The handling and brakes would be worth it.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
hi everyone
I'm pretty much new at all this so i have a question, I've recently bought a kona jake cx bike to be my one and only. I mostly drive on roads and i average about 15 mph. Now jake has "Continental SpeedKing Cross 700x35C" tires which are knobby and a bit wide. So my question is - how much difference would some decent 700x25 slick tires make?
I eat carbide.
Liked 1,307 Times
hi everyone
Nice 700x25 road specific tires will make a great difference to the feel and speed of the bike. Definitely worth the money.
Quoted: 353 Post(s)
Liked 92 Times
hi everyone
If you are driving mostly on roads I say get yourself a pair of 25s. Some Continental GP4000S in 25 would be a nice tire. If you want to go cheaper I recently got a pair of Vredestein Fiammante for $20/ea and have turned out to be a great cheap tire. They are heavier than Conti's though.
The 700x25 will definitely make a difference because they are much smaller and not knobby. You'll probably feel faster on the road, but it may be a little harsher ride. They'll be less vibration because of the lack of knobs on the tires.
Depends on the frame. Some cross frames have nearly the same geometry as you stated above. Others have a much longer head tube providing a more upright position. My Tricross is more similar to a touring bike geometry than a pure road bike. This makes it more stable but turns like a truck. Long rides and casual rides, this is great. Road racing, I'd rather have something with quicker handling and more sensitive brakes.
The Weird Beard
As far as tires go, mine came with 700x30. Check Sheldon's tire size guide by using the inside width of your specific rim to determine how low/high you can go in tire size. I run the 30's when on trails and 25's on the road.
I like beans
Bikes: Tarmac Pro, Bianchi Zurigo, Raleigh Gran Sport, Fuji Del Rey, Ironman Centurion
I use a cross bike for my do everything bike and use it for commuting as well as riding trails. I don't really see it as a replacement for my road bike because it's heavy as ****. When I got it, I thought I wanted a smooth steel ride that would be different from my Tarmac, but I've come to realize that part of the reason that I love my Tarmac is because I love a stiff, light ride. So I'm getting rid of my steel Masi in favor of an aluminum cross bike with tighter geometry like the Colnago World Cup or the Santa Cruz Stigmata.
Tete de Couch
hi everyone
Put some good Koolstop brake pads on there and you'll hardly notice the difference compared to a caliper brake.
