Shimano Freewheel with Suntour Drivetrain?
Old 07-27-10, 03:09 PM
khatfull
FBoD Member at Large
khatfull's Avatar
Liked 7 Times in 7 Posts
All,
I got my Fuji Touring Series III from eBay today (will start a separate thread since lots of folks seemingly like my cleaning exploits ). Very dirty, reminiscent of the 85 Club Fuji I worked over, but otherwise in fine shape.
It has a Suntour 6 speed drivetrain (Mountech FD/RD, 6 speed cluster, 50/45/28 crank). I've read that some folks have used Shimano Hyperglide freewheels to improve the shifting performance over the straight toothed Suntour freewheels. Also, I read that 6 to 7 speed generally isn't a problem, in friction mode of course. I'm 90% sure I'll be using Suntour ratcheting barcons.
Any truth to this? And yeah, this might be putting the cart before the horse but since I'll be going back to my co-op treasure trove either today or tomorrow I figured I might look for a nice Shimano freewheel is there's any truth to this.
Oh, and yes, RD alternatives have been examined and explored although the Mountech currently installed is smooth as buttah, for now right?
khatfull is offline
Old 07-27-10, 03:21 PM
Old Fat Guy
Liked 13 Times in 9 Posts
Of course you can swap a Shimano for a Suntour, and a six for a seven, if you feel it's needed. Since you haven't ridden the bike yet, I presume, you may find the shifting is just fine. I believe it's set up with triggers and a flatbar, so you have some work cut out for you before you can actually tell how it works with barcons.
Both freewheels are suitable for a 126 spacing. Depending on the wheel & frame, you may have to add a spacer or two to the axle so that the freewheel clears the frame, you may have to redish the wheel as well. Trying is the only way to know for sure.
Old Fat Guy is offline
Old 07-27-10, 03:30 PM
Grim
Grim's Avatar
Bikes: Cannondale T700s and a few others
Liked 3 Times in 3 Posts
You can do it but that bike has a half step crank. You are going to need to pay attention to the gearing if you want to actually half step shift. Otherwise you may have some gears that and near duplicates. Play around with Sheldon's calculator some. https://www.sheldonbrown.com/gears/
Grim is offline
Old 07-27-10, 03:33 PM
beech333
Fuji Fan
beech333's Avatar
Bikes: Was Fuji and got my grails (Pro, Pro SR, Design Series, & Ti). Now I hunt 50's and older road bikes.
Liked 179 Times in 114 Posts
+1 Try the bike as is, other than the flat bar setup. I've never had an issue with Suntour freewheels.
beech333 is offline
Old 07-27-10, 03:38 PM
soonerbills
soonerbills
soonerbills's Avatar
Bikes: 25 at last count. One day I'll make a list
Here is a cool video on Hyperglide
https://bike.shimano.com/publish/cont...echnology.html
soonerbills is offline
Old 07-27-10, 03:41 PM
khatfull
khatfull's Avatar
Of course you can swap a Shimano for a Suntour, and a six for a seven, if you feel it's needed. Since you haven't ridden the bike yet, I presume, you may find the shifting is just fine. I believe it's set up with triggers and a flatbar, so you have some work cut out for you before you can actually tell how it works with barcons. Both freewheels are suitable for a 126 spacing. Depending on the wheel & frame, you may have to add a spacer or two to the axle so that the freewheel clears the frame, you may have to redish the wheel as well. Trying is the only way to know for sure.
Yep, most of the parts are already assembled or in transit...bars being the last and I think I have a line on them too. I'll have everything by the time I'm through cleaning it up.
I've never ridden with half step and my plan is to go to Biopace rings (yeah, I'm a freak who likes them and thinks there's a difference, even if it is psychological ) so I might ultimately end up with a 48/38/28 or a 52/42/28 after I spend an evening with Sheldon's gear calculator.
Agreed, I will do so. I just like to plan ahead (and have another excuse to go to the co-op and dig through bins). Check this out:
That's one of two bins of RDs...there's also one or two bins of about every other drivetrain component you can think of.
Wouldn't you like any excuse to go dig around down there?
khatfull is offline
Old 07-27-10, 03:43 PM
Zaphod Beeblebrox
PanGalacticGargleBlaster
Zaphod Beeblebrox's Avatar
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Liked 8 Times in 6 Posts
I use hyperglide freehweels on both my 7 speed setups (one indexed, one friction w/ Suntour racheting Barcons) and they are fine.
6 to 7 speed should be fine in your case since the bike has at least 126mm spacing. I'll put in a good word for Shimano SL indexed shifters. They work great with those HG cassettes. The mountech derailleur could even be made to index with a 7 speed if its got a barrell adjuster on the derailleur body.
--Don't Panic.
Zaphod Beeblebrox is offline
Old 07-27-10, 03:55 PM
Old Fat Guy
I think I have a couple of sets of Suntour barcons laying around.
The co-op looks like a less organized version of my garage.
Old 07-27-10, 03:58 PM
soonerbills
soonerbills
Those Mountech drails, ain't they the ones I heard are bad on the jockey wheels or pivot spring go bad fast or something?
How might a Hyperglide work with a old style Crane derail? I'm running a Suntour 6 speed with one now and wonder if it might behoove me to swap to the Hyper!
Old 07-27-10, 04:00 PM
khatfull
khatfull's Avatar
I have two sets myself...found both on local CL...cleaned in the ultrasonic, relubed, and nicely refinished.
It really is like a dungeon down there...very dim lighting, water dripping from the odd pipe, smells musty...but there's a whole ton of C&V interesting stuff...and they charge really decent prices for things. I'm quite sure your garage is MUCH nicer
khatfull is offline
Old 07-27-10, 04:02 PM
khatfull
khatfull's Avatar
The rear yes, the front is pretty much like any front. I got a Mountech with a bent cage at the co-op for a buck just to disassemble it to see how unservicable they really are. The "advertised" problems are real. You'd have to keep it very clean I think for it to have any longevity at all.
khatfull is offline
Old 07-27-10, 04:25 PM
khatfull
khatfull's Avatar
I should add too...
The reason I wonder about this at all is when I went from a 6-speed Uniglide drivetrain to a 7-speed Hyperglide drivetrain on the Tiara it was like night and day in the smoothness and crispness of shifting. Both indexed but when I hit a click on the shifter now it just goes BANG into gear. Period. On the Uniglide there was always that tad of noise before the cogs grabbed the chain. The 6-speed shifting was accurate and I had no issue with it...it's just that the smoothness of the Hyperglide was very apparant to me right from the start.
khatfull is offline
Old 07-27-10, 05:42 PM
EjustE
sultan of schwinn
EjustE's Avatar
Liked 15 Times in 9 Posts
If you can pull it off (with your RD), a widely spaced hyperglide megarange 7sp would be great with that half step and granny. Hill eater
EjustE is offline
Old 07-27-10, 06:08 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Liked 3,675 Times in 2,077 Posts
Make sure your tetanus shot is up-to-date...
JohnDThompson is offline
Old 07-27-10, 07:40 PM
khatfull
khatfull's Avatar
Oddly, it is. My daughter owns a horse. Stabled in a barn. Stuff on floor. 'Nuff said...
khatfull is offline
Old 07-27-10, 08:26 PM
Grand Bois
Grand Bois's Avatar
Liked 30 Times in 28 Posts
I'm trying to figure out what information you were asking for in your original post. At first I thought that you wanted to know if Shimano HG actually works better than Suntour, but now you've said that you've used Shimano HG and you are aware of how well it works. I'm confused. Did you really just want to post pictures of your local co-op. If so, that's okay with me.
Grand Bois is offline
Old 07-27-10, 08:31 PM
top506
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Liked 706 Times in 317 Posts
Both my Biopace road triples are 50-38-28. You might have to scrounge a little to find the 50t. And it's a 110/74 BCD set-up.
Top
top506 is offline
Old 07-27-10, 10:18 PM
noglider
noglider's Avatar
Liked 3,015 Times in 1,710 Posts
Yes, I think a Hyperglide freewheel will be an improvement over a SunTour freewheel in any case. Also, get a Hyperglide chain.
noglider is offline
Old 07-27-10, 10:27 PM
khatfull
khatfull's Avatar
Well, the co-op pics are fun in any case, yes
But what I was asking (in an admittedly roundabout way) is can a HG freewheel be used with the Suntour DT and would I see as much difference as I did going from Uniglide to Hyperglide. I think the consensus is I'd see a difference but I should definitely try the Suntour freewheel first, which I will.
noglider: I have a NOS HG70 chain in hand that I got local on CL for $8. Have that covered.
top: Thanks, I forgot about the 50T 110BCD (I do have your PM about the Biopace rings, thanks). That would work very nicely. The 38 and 28 are easy to find. Do you see any difference between the steel and aluminum rings?
khatfull is offline
Old 07-28-10, 07:56 PM
Grim
Grim's Avatar
I need to hit my local CoOp (well not so local it is almost a 40 mile round trip) and see if I can find a few parts. I would LOVE to find some bar ends and a late 80's 105 rear brake. I think I am just going to service the bearings on the crusty Dave Scott and ride the crap out of it till something falls off (and hopefully that will not be me).
Grim is offline
Old 07-29-10, 07:09 AM
Grand Bois
Grand Bois's Avatar
The Hyperglide freewheel will be a big improvement even without the HG chain. All of my geared bikes now have Shimano freewheels and cassettes, but I don't think I own a single Shimano chain.
Old 07-29-10, 07:15 AM
noglider
noglider's Avatar
That's true, although I find that a Hyperglide chain (or, I suppose, any chain of a similar shape) makes a further improvement. I recently did an experiment which showed this. My Super Course had a Suntour freewheel and a Sedisport chain. I changed the freewheel to a Shimano and felt a dramatic improvement in shifting. Then I changed the chain to a Shimano and felt yet another improvement.
noglider is offline
Old 07-29-10, 07:41 AM
jimmuller
What??? Only 2 wheels?
jimmuller's Avatar
Liked 752 Times in 246 Posts
I've been using DuraAce DT levers with Vx derailleurs and a ProCompe freewheel for a long time and haven't had a matter/anti-matter reaction yet. Of course there is always the chance a stray neutrino might come through and stick, and then who knows what may happen?
Real cyclists use toe clips.
jimmuller
jimmuller is offline
Old 07-29-10, 09:11 AM
sokito
sokito's Avatar
Bikes: 1979(?) Centurion Super Elite
I've used 6speed shimano 600 freewheel (uniglide I think) with suntour alpha 6 speed index system. I noted that they used slightly different spacing (something like 0.3mm difference?) but it indexed just fine...
sokito is offline
Old 07-29-10, 02:53 PM
khatfull
khatfull's Avatar
Hey -E,
Were you thinking something like this:
13-15-17-19-21-24-34
Or like the more standard 14-28?
khatfull is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
