Compact bars or traditional bend??
Quoted: 63 Post(s)
I currently have anatomic bend bars and they suck. The part that my hands should fall on in the drops is nearly vertical then there is a sharp bend with a 2" or so flat part parallel to the ground. Horrible design all the way around.
I'm looking for something with a few good hand positions. At least a comfortable bend at the front for sprinting/descending and a decent flat for comfort when I want to get a little lower when I'm on the front pulling. I'm sort of looking at the FSA Pro Wing Compact and the 3T Rotunda right now. What would you suggest for a non racer who is just looking for something that works better for him.
Bikes: 2012 Parlee Z5
I used to have a set of ergo bars like the ones you are describing. They were Salsa Poco bars and had a weird bump kind of thing which I never really got used to. I recently replaced them with Ergonovas and really like them.
Old Bars:
Old Bars:
Over the hill
Quoted: 1011 Post(s)
Liked 1,236 Times
The one good thing about traditional bends is that they don't dictate where you grab the bar. I recently switched back to a traditional bend after years of never quite getting used to anatomical ones. I like to grab deep in the drops, and the shallow angle most anatomical bars have make me rotate the bars up a lot. In order to make my round bars as comfortable as an ergo bar, I just wrap one strip of bar tape around the part my hands go on before I wrap the bars.
It's like riding a bicycle
Properly installed, there is no anatomic bar that I am aware of with a nearly vertical drop section. Some are swept back more than others and some require an absolutely level position near the ends. I set the angle in the drop section to be comfortable first. If something else is off, then the bars are a reject before they are ever used.
Only get compact if you need the shorter reach or shallower drop. I use a large 11cm drop from the saddle to the bars, and I need a short reach, so the short and shallow Easton EC90-SLX3 works for me.
It's ALL base...
Also consider Deda Newtons, shallow or deep drop. I particularly like having lots of hand room on the drops.
https://www.dedaelementi.com/En/Produ...ctIDMaster=365
Quoted: 63 Post(s)
Bikes: CAAD9-1, Windsor Cliff 29er
I love the anatomical bars. I find if I put it to where the bump in in the middle of my palm it leads to a much more comfortable position. From that position I can reach the levers to shift and brake comfortably from the drops. My other bike has traditional bars and when I'm in the drops I have to put my hands on the level section at the end, where I can't reach the levers. To each his own.
Iconoclast
Bikes: Colnago Super, Fuji Opus III, Specialized Rockhopper, Specialized Sirrus (road)
I love Ergo bars too, but it is very difficult to find one with the right bend. One that I like right now is the Deda Elementi Nera (26.0mm) The bend is one of the better I've come across. As I understand it, the Newton is essentially the same bend; not sure about the 215. For reference: the Colnago in my signature sports the bar (Nera) in question.
Using an Easton EC90 SLX3 Handlebar now and love the fill no mater were I place my hands on the bars I like the way the bend is in them.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
3t Ergosum Pro. Shallow drop / compact shape, but not too short on the reach - which means there is plenty of room on the ramps for average to large hands. (I find FSA compact bars have too little on the ramps for larger hands.) I believe a lot of guys on the Tour used the 3t and not the carbon version.
