Turning myself in for crimes against Bikes.
French threaded
Bikes: many
Or-
PX-10 reaches new lows
A French bike with Italian components
A race bike to be used for commuting
A vintage bike with modern parts
Built with a spreadsheet instead inspiration
What can I say? I am ashamed of this bike.
In all its 16.3 lbs of embarrassment.
I even tried to write an algorithm to decide my tires.
What do you folks think? Total do-over right?
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
Bloody Awful. In before the others with my address.
Do over the cable stops. I'm kinda baffled over the weight though, how'd you do that, or are you sure its accurate? I know those vitus frames are pretty light, but still.
Don't climb hard or sprint with that thing!
Bianchi Goddess
Quoted: 2957 Post(s)
Liked 3,024 Times
I kind of like it but, get rid of those awful black tires
Sugar "Kane" Kowalczyk
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 78 Times
Uhh... pretty cool, actually.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
Did you pump some hydrogen or helium into the tires or something??
Oops!......... I see some carbon on those brifters...and those brake calipers look pretty light from the front with the slotted arms.....maybe it is 16.3 pounds then!
Chombi
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 20 Post(s)
Liked 8 Times
what, no Carbon Fiber fork?
--Don't Panic.
--Don't Panic.
French threaded
Bikes: many
I'll be fair that the 16.3 is with a seat that is currently set to arrive on Monday, it is currently 60g heftier, but looks the same as it will next week.
Anyone interested in my spreadsheet? Gram weights of every part because I dont trust a hanging scale. It also includes my cost and source for building.
After winter I will build some low spoke count wheels with sapim CXrays and it will be at 16.0
Photographer
Quoted: 105 Post(s)
Liked 98 Times
BTW, nice photography, very well seen. Move along, no crime here ...
Scott
Scott
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
Ellensburg, WA
Bikes: See my signature
Quoted: 314 Post(s)
Liked 472 Times
Very, very nice criminal work.
1984 Gitane Tour de France; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1991 GT Karakoram, 1983 Vitus 979; Colnago Super, 1989 Spectrum Titanium,
Quoted: 150 Post(s)
Liked 33 Times
You will now be required to post clear HD photos of your bike as soon as the weenie stash arrives or is built and installed!
Oh, good idea from a previous poster about a carbon fork too!
BTW, it's looking real nice so far. Nice touch with the ergo bars not tilted too far up. Personally, that's what I think mostly ruins the looks of most new bikes today IMO, in addition to the compact "tail dragger" frames.
JMOs
Chombi
It's not really a crime if ya ask me... the only real crime is making a bicycle un-rideable
Personally, it doesn't do anything for me (in a fashion/looks sense) but it seems like it'd fun to ride. I grin like a kid anytime I ride a light-weight bike.
French threaded
Bikes: many
they function the same, the look can be distracting but this modern Campy stuff is just so finicky to tune that I have a few times had to pull a half turn as cable housings settle and other chain noise occurs. Now that its broken in I could switch it around but then I would have to re-tune it.
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
Really? That has never been my experience with the many Modern Campagnolo equipped bikes that I've built. What did you have problems with?
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Riding like its 1990
Yeah, if the bars need to be tilted up too much then you need a taller stem or shorter reach.
I honestly think many think the "ergo" part of the bar is right at the tip of the barend, instead of the nice flat right under the levers.
Looking good.
What wheels? I see no stickers (nice), how light are they?
Wow on the weight. I have 20# bikes right now. Ironman with Ultegra. Would love to get it to 17# range.
Looking good.
French threaded
Bikes: many
Twice I had to tighten the rear DR when i notices some chatter from the cogs and once I shifted the front too hard and pulled the DR down the ST by an 1/8", I gave the barrel a twist and rode to a safe place to fix it.
The ergolevers are brand new, Campy cables and housings. Both DRs are lightly used, but it shouldnt matter on that end. ...Unless a pivot is loose... BRB!
Quoted: 174 Post(s)
Liked 157 Times
I've only had one issue, but it was my own doing. I put a 130mm rear wheel with 8 speed record ergo onto an old C'Dale frame with 126mm rear end. The RD hanger angle was off by a smidge and the initial setup was a bit of a pain - bottom 4 gears would dial in, but would be off in the upper 4 and vice versa. Fixed that by replacing the frame with a Tommasini Tecno (no more issues) followed by 10 speed record. 8)
French threaded
Bikes: many
Frame-1364g
Fork-388g
Bottom Bracket-55g
Front Dérailleur-107g
Crankset-864g
Headset-90g
Stem-243g
Seatpost-163g
Brakes-339g
Rear Dérailleur-226g
Handlebars-225g Assumed, bars arrive monday
Seat-209g Assumed, seat arrives monday
Brifters-343g
Chain-234g
Cables and stops-199g
Tape-41g
Cassette-185g
Hubs-312g
Rims-776g
Rimtape-7g
Skewers-71g
Spokes-342g
Nipples-53g
Tubes-156g
Tires-417g
Total 7409g
X 0.00220462
16.33lbs
Fork-388g
Bottom Bracket-55g
Crankset-864g
Headset-90g
Stem-243g
Seatpost-163g
Brakes-339g
Brifters-343g
Chain-234g
Tape-41g
Cassette-185g
Hubs-312g
Rims-776g
Rimtape-7g
Skewers-71g
Spokes-342g
Nipples-53g
Tubes-156g
Tires-417g
Total 7409g
X 0.00220462
16.33lbs
Quoted: 7 Post(s)
That...that's absolutely beautiful. I wish my Campy-equipped bike looked that classy. Well, it does, but that frame look AWESOME.
Furthermore, a frame that large weighing in at only 2.9pounds? Holy crap...
Quoted: 174 Post(s)
Liked 157 Times
We share the same sense of aesthetic balance (which naturally eminates from a properly set up bicycle IMO).
I own a tail dragger and am planning to replace the frame one day. I don't mind sloping TT's on mountain bikes, but really do not like them on road bikes. I'm a tall guy and have a hard enough time finding a frame that fits me properly. My commuter is the largest frame available in that model, has a sloping TT and I have a frigging mile of seatpost on it.
aka: Mike J.
Nice list but I see no grease or oil on it. Also, are those weights spec'd or functionally individually weighed. Plus screws and washers vary so you would have had to weigh each of those items. Plus the as installed weights of cables and housings vary based on trim points. And was the bar wrap installed and cut and then calculated based upon trimmings subtracted from pre-installed gross weight. Then there is the finish tape on the bar wrap.
Apart from that I'm fine with the build except for that seat post. But what do I know, I don't really care about weights.
