What do your SSFG bikes weigh?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
Just out of idle curiosity I decided to weigh all my SSFG bikes just as I ride them with all accessories (fenders, rack, lights etc.) and tools, spare tires / tubes, inflator etc. The results are shown in ascending order:
1) Bianchi Pista Concept FG with tubular wheels - 15.7 lbs
2) Schwinn Paramount P14 FG with tubular wheels - 16.8 lbs
3) VISP TRX 790 FG with tubular wheels - 20.6 lbs
4) Motobecane Messenger FG with clincher wheels - 21.6 lbs
5) Salsa Casseroll SS with clincher wheels - 24.0 lbs
6) Mercier Model 100 SS conversion with tubular wheels - 26.2 lbs
7) Mercier Kilo WT FG with clincher wheels - 26.6 lbs
What I find most striking is that the steel Paramount is only 1 lb heavier than the aluminum frame / carbon fork Concept, whereas the all aluminum VISP is 5 lbs heavier. The tool bag w/spares, front brake and road tubulars add at most 2 lbs to VISP, so its frame / fork must be a whopping 3 lbs heavier. Since I'm very short, all my bikes sport the smallest frames available, and would weigh more with midsize frames.
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
56cm Presto NJS (Dura-Ace to Open Pro wheels, SG75 crankset, Dura Ace seatpost, Cinelli bars/stem)
18.0 lbs
18.0 lbs
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
More than my Tarmac, less than my Hollowpoint?
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
My bike is a 57cm and it's 17.2lbs with race wheels.
Those Pista Concepts can get to be super light! I had a 57cm one with Mavic Ellipse wheels and MTB pedals and it was 16lbs.
my experience has shown that cheap carbon is heavier than good aluminum and cheap aluminum is heavier than good steel.
for a while i had a 60cm steel road bike with full campagnolo 10spd that came in under 20lbs and that was without the use of extra light parts and clincher wheels. the components are now on an aluminum frame and the steel bike was built with period correct parts (it still comes in under 21)
back on topic, my conversion was about 17.5lbs (60cm) but has been parted out.
nashcommguy
Bikes: Commuters: Fuji Delray road, Fuji Discovery mtb...Touring: Softride Traveler...Road: C-dale SR300
Fuji Del Rey conversion 23" frame is 24 lbs w/toolbag, framepump, lights, etc.
i smell bacon
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
Motobecane Track - 20.67 lbs
Girlfriend's Mercier Kilo TT - just a hair over 20 lbs
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
last wheel set, cut riser bars, and no fenders or accessories, 19#
59cm IRO mark V
59cm IRO mark V
Bikes: 1990 Waterford Paramount, 1986 Pinarello Pista 195? Raleigh 3sp, 2001 Surly 1x1, 2014 Canfield N9, 2015 Canfield Balance, 2013 Rocky Mtn Flatline, 2012 Intense SS2, 2014 Transition Klunker, + more!
Pinarello with clinchers = 18 and change
Pake with clinchers and wooden bars and seat bag = 20 and change
Bikes: 2010 Wabi Lightning, 2014 Brompton S2L-X
The Wabi website claimed a 55cm frame bike is 16.3 lbs, so I am estimating that my 52cm frame from my stock Lightning is at 16 lbs. Future plan is to get down to 15 lbs.
Miller Mantovanelli
Bikes: 1985 Miyata 5 twelve, 1998 GTS MTB
1985 Miyata 512, corima tubular wheels 58 frame when it was single speed 17lbs, w/ gears under 19lbs.
single
after gears
single
after gears
Zen Student
Bikes: Colnago Crystal road, Lotus road, Dawes SST-AL fixed gear
My original SST-Al came in at about 20.5 pounds when I first set it up. I'll have to re-weigh it now that I've swapped the fork from the stock steel to carbon fiber, and switched to bullhorns.
1989 Lotus Unique, 1999 Colnago Crystal with full Campy, 2009 Dawes SST-AL fixed gear
Elitist
Liked 92 Times
- Weighing without pedals
- Weighing without grip tape
- Weighting the bike with the smallest frame in the size range which has the smallest stem and shortest cranks
- etc...
For example: https://weightweenies.starbike.com/li...ype=roadframes
Real weights are what you get by using a scale. Maybe a fish scale or weigh yourself with a bathroom scale with and without your bike and note the difference.
Fresh Garbage
err it has been a while since I weighted it and I've made a few changes. I believe my bike came in at about 23-24 lbs. Pretty good for 67cm, low end lugged, cro-mo/high-ten. It was about 30 with my rack and pannier. If I can do a lateral raise with it then it's good
Constant tinkerer
Steel 1984 Trek 460 FG conversion: 19lbs (w/front brake and 36 spoke wheels)
"Metal matrix composite" aluminum 1994 Specialized Stumpjumper SS conversion: 19lbs! (with knobby 2.10s and front suspension!)
Aluminum 1989 Trek 1500 geared roadie: 20lbs
Hi-Ten FG/SS commuter mountain bike: 25-30lbs? Haven't put this one on the bathroom scale yet.
My name is Alex
Bikes: Mercier Kilo TT Stripper in RAW, Schwinn Madison 2008 Blue, Leader 725tr, Brassknuckle, Leader 722, Traitor Ruben
my kilo weighted 19.44lbs and im not sure how much the madison weights
