getting frustrated
Bikes: big block
getting frustrated
I got some used schwalbe marathon plus tires from a friend at the lbs and I just can't get them onto my rim. I have one side on but I can't get the other side to get hooked in the inside of the rim. It's a dp18 and the tires are only 28's. Any tips or anything?
all-weather commuter
Get it close and start pumping. If it doesn't seat once you've got 80 psi in it, push on the tire perpendicular to the wheel and it should pop on.
Constant tinkerer
That's a good way to blow up a tube. If the tube is pinched under the tire, it'll probably explode once you get that much pressure in it. If the tire is on the rim but the bead just isn't seated, put like 10-20 psi in and work it around. Some tires are just a pain.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
...that's why it's there.
Your cog is slipping.
This is one of the best.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
I have 4 tire levers, 2 of them are really thin that help me mount a tire, 1 that has a really really U shaped bezel that helps me grab beads really easily, and one that is longer and fatter that helps me slip a really tight tire on at the edge.
Kool stop tire bead jack is the one the LBS uses so if you can get your hands on one of those +1
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
Does OP mean he can't get both sides of the tire to the inside of the rim, or that he can't get the bead to seat? Those are two totally different things.
I broke two sets of Pedro's levers mounting a set of Rando's on my bike a few years ago, my thumbs still hurt from it. I went to the LBS and bought a set of Bontrager levers which feel almost like a really hard plastic but won't damage the rim. I have yet to find a tire I can't mount or remove with these. What you need is leverage so get the longest one you can find to help until you become a man and start growing muscles! I keed I keed!
coasterbrakelockup
Things you can try, that may or may not work:
-liquid soap on the rim
-bigger/better lever
-run tire through clothes dryer to soften it
my bike Owns me+my wallet
Bikes: Px-10 singeld, 2007 KHS filte 100
Tire leavers are for women and communists, men use their brain and muscles.
Follow the Sheldon Brown instructions, and it's a no go, do Finger push-ups until you can.
Pedro's tire levers are good, but are 100% plastic, but if you break em they'll warranty them.
