DT Shifters for First Race?
hey friends. so i'm wondering what you guys think about racing on downtube shifters? in about a month i'm looking to make my racing debut (crit). my bike is an allez steel.
shouldnt be a problem. especially i you are use to them. remeber they use to race on them back in the day and brifters arent going to make you win the race nor will DT shifters make you lose.
bikes dont win races riders do. good luck and be safe!
pan y agua
Quoted: 1469 Post(s)
Liked 749 Times
We did it for years. You'll be at an extremely slight disadvantage. Biggest thing is that you won't be able to upshift in a sprint ( unless you've mastered the technique of doing it with your knee). So you'll need to pick a gear for the sprint and stay with it.
Also, you'll tend to shift less in and out of corners, which may be slightly more fatiguing than being in the right gear all the time.
That said the advantage of integrated shifters is pretty small, and it's highly unlikely it will make any difference in your placing. So don't let the bike hold you back.
You could get lost and die.
You could hit a tree and die.
Quoted: 2953 Post(s)
Liked 3,106 Times
You'll be fine. Ride hard. Good luck!
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
No worries, but you'll have to race smarter. Think in advance.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Over the hill
Quoted: 1011 Post(s)
Liked 1,235 Times
No problem. The only time I felt hindered by downtube shifters was when I was in the final sprint and the 2 guys who beat me were able to shift while sprinting while I just threw the lever down and mashed. Of course, I got brifters the next season.
It's like riding a bicycle
For an inexpensive fix, get a right side bar end shifter. Cut the bar back just a touch so your bars are the same length. Or cut them down more so that you have a more usable bit of bar (I cut about 2 inches off the end of my bars).
https://sprinterdellacasa.blogspot.co...for-crits.html
But for use right now you'll be fine. As mentioned above you'll need to anticipate some of your shifts. Other times you'll have to deal with a short period of over- or under-gearing.
Good luck
cdr
Good luck
cdr
Go for it dude, besides, nobody has time for shifting in criteriums, once you are in a gear basically the whole race will be in the same gear, maybe one gear lighter but besides that, criteriums are like that. Race smart and in the front (1st 10 positions) all the time.
Now you will discover that from the 10 gears you will use no more than 4 or 3 all the time
I eat carbide.
Liked 1,307 Times
Remember - this is the OP's first race so it will be cat 5 and even worse.
OP - just race/ride within your ability. Riding nearer the front you will find there is less of a surge around every corner. Be smart, pick your lines and look at the riders around you. If you notice someone is grabbing a handful of brake in every corner than get away from them. Look for ways to carry speed through corners reducing your need to shift. That's good advice - integrated shifters or DT shifters.
Underdog
Bikes: Several.
Do it.
I've done it for the past two years with some success - no wins, but a couple top-10s. I'm not really a road racer, just a mountain biker throwing himself into collegiate road races for training purposes. This year, I upgraded to brifters, but there's no shame in racing with downtube shifters. I actually enjoyed the reaction of shock I would get from other racers when I would pull up next to someone and reach down to click into the next gear and proceed to stand up and drop them on a climb. It's a great feeling.
In fact, racing with DT shifters will make you a smarter racer and make you much more aware of what gear you are in and what gear you will need. It will also teach you to anticipate certain elements of races, such as sprints, jumps, etc.
Just go for it.
Just go for it.
cycle-dog spot
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
I was the last kid in the SoCal college racing scene to hold onto downtube. Really never felt at a disadvantage even for springs.
Spin out - sit down - shift - stand again. Really not a big deal.
I later changed to STI and was disappointed my results didn't appreciably improve.
- Z
- Z
Underdog
Bikes: Several.
Also, unless your derailleur hanger is severely bent or your cables are ridiculously gunked up... DT shifters usually always work.
"Chooch"
Bikes: Late 1990s Ciocc Titan
"Smart shifting" (anticipating your opponents' next move and shifting accordingly) is a powerful tool that will enable even an old-fart like me riding a "vintage" steel frame to beat someone at least 20 years my junior on a CF superbike to the line. The problem with modern brifters is that they often encourage those with more $ than common sense to shift more often than they need to. I'll usually upshift a wee bit early and pedal at a slightly lower cadence while sucking my mark's wheel, then hammer it in and blow by brifter-boy over the line. Doesn't always work, but it has worked enough.
Ultimately, its the MOTOR (that's you) that makes the difference. Not the bike.
Btw - I hate crits. Too many opportunities for a "demolition derby" when you're Cat V/IV - JMHO. Give me a road race or a time trial any day.
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
Once you the learn the art of the right knee shift, you will rock it during the sprints.. That is how we did in the 80's..
Underdog
Bikes: Several.
Originally Posted by clink83
Even better is indexed DTs shifters that can be turned to friction mode..
I wish I had thought of this myself or even heard of it before now... I might've hung onto my DT shifters a little longer.
neits
Seems like you'd have to finesse a knee shift or you'd end up with a bloody knee. Finesse is not synonymous with sprinting in my mind. A lost art I'm sure.
I don't feel much slower on my DT shifted bike btw, plus it's much more thrilling to ride for some reason.
Quoted: 14 Post(s)
Liked 11 Times
It was even trickier before Shimano came out with index shifting, with DA 6 speed.. When Campy Nuovo and Super Record dominated the fields of all races, shifting during crits required quite a bit of finesse..
More than finesse you need it to know what you were doing.
About the shifting, ex tracker here, never used more than 3 cogs out of the 6 i had in the clusters. What i been noticing lately it is a tendency for new comers and weekend warriors to shift like crazy monkeys when is not even that necessary some times. Well whatever
Certifiable Bike "Expert"
