Ghost or Phantom Chain ring vs adjustable tensioner. Which is more efficient?
Legs; OK! Lungs; not!
Bikes: ''09 Motobecane Immortal Pro (Yellow), '02 Diamondback Hybrid, '09 Lamborghini Viaggio, ''11 Cervelo P2
Liked 9 Times
My tandem does not have an eccentric BB it has a chain tensioner on the sync chain. I've seen some posts and threads regarding the use of "Ghost" or "Phantom" chain rings in lieu of a chain tensioner.
Certainly it is a bit more eye catching, but on the MTB forums there is some discussion, and mention of them popping out. I suppose on a road bike that is much more unlikely, but still a possibility.
From the assembled wisdom of the experienced tandemistas that frequent this forum, what are your opinions on these vs the tensioner?
I got an old D.A. RD and salvaged and idler wheel with bearing to replace the stock wheel in my tensioner. I'm wondering if a Ghost wheel might be more efficient.
What are your thoughts?
NOTE: a few of the posts in the MTB forum mentioned that the rings should be rings with out ramps. What are your thoughts on that? That will limit the selection a little.
Quoted: 77 Post(s)
Liked 19 Times
Several decades ago we use a ghost chainring on one of our custom tandems.
The ghost ring has to be a few teeth larger than the crossover rings; you may have to try several rings to have proper fit.
Yes, the ring floats nicely and is an eye catcher.
Makes a great conversation starter!
Pedal on TWOgether!
Rudy and Kay/zonatandem
Pedal on TWOgether!
Clipless in Coeur d'Alene
rings with ramped teeth are designed to help shifting btwn rings, whereas a single speed ring will keep a chain tracking on it a bit better.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
With no force on the ghost ring it shoul last a very long time. It might be worth getting a ring that is best at the job should you go that route. New very inexpensive flat rings are easy to find.
TKramer
Bikes: Paketa V2r, Co-motion Equator Co-pilot, Bingham BUILT. tandem
Quoted: 14 Post(s)
Ghost ring would likely be more efficient and elegant in my estimation. No friction at a high RPM idler bearing generating heat. No alignment with the chain and chainwheels to worry about. If it turns out that an even tooth count will work, you can use one of those narrow/wide chainrings made for single-speed crank setups. That might increase the security factor of the ring staying put.
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
i use both on my tandem the timing chain kept dropping even with the idler pulley tensioner so i stuck a ghost ring in there too.. haven't dropped a chain since. whole thing is kinda noisy though
I have an old beater tandem running a ghost ring. It's been in there for many miles and many bumpy hauls up and down stairs transporting the bike with no issues. I've also run a ghost ring on a SS MTB(ramped cassette cog) with no issues, though I haven't run that one off road so no crazy MTB worthy terrain.
Quoted: 23 Post(s)
pan y agua
Quoted: 1470 Post(s)
Liked 752 Times
correct:
You could get lost and die.
You could hit a tree and die.
Quoted: 169 Post(s)
Liked 84 Times
I just picked up a cheap tandem with an idler wheel and might try going this route. The idler wheel works ok but is a bit noisy. Thanks for the good tip.
