Giving up on GP 4000s - crappy sidewalls?
Fantastic rolling, great quality ride, great flat protection, but after having 3 sidewall cuts on 3 tyres, all within 500km, just not worth the heart burn.
Threw away one tyre at 170km and 2 within 500kms. Though 1 set is going fine now for about 4000, just cant trust these tyres anymore.
Anyone with similar experiences? Or do you think I got a bad batch?
It sounds like your roads must be too bad for lightweight road tyres. Sidewall cuts should be very rare. If your roads have enough glass or road debris to regularly reach up the side of the tyre and cut the wall, you probably should be considering a heavier duty tyre. None of the lightweight racing tyres like GP4000s or PR3 have kevlar belts in the sidewalls, only in the main tread, so almost anything will cut the sidewalls.
Yeah, maybe you're right. friends have had great experiences with Rubino Pros. Are they with thicker sidewalls? Just ordered a pair of Ultremos. I know they are also light weight, but I'll try my luck.
Rubino Pros have side walls as thin as paper. What sort of pressures are you using. If you are pumping up your tires to hard for your body weight that can easily lead to more frequent side wall cuts.
Fly on the wall
Bikes: a few
https://www.vittoria.com/tech/recom-tyre-pressure/
I'm no expert, but you may be running your tire pressure too high. Someone on this forum threw out a great equation for determining tire pressure (maybe PSMIT?), but i'm too lazy to search.
FWIW, I'm 170 ish and I run 100 in front, and 110 in rear. Just switched from Gatorskins to GP4K and have only had one sidewall issue (on a rear Gatorskin with ~4000mi on it... was time for the little guy to go anyway).
Bikes: MTB: Stumpjumper FSR, Road: De Rosa King 3
I've been using GP4000s for several years now, and believe it not, I've never had an in-ride flat on them (I've had one or two punctures that resulted in really slow leaks that manifested the next day.) Never had a sidewall issue either.
Now I will cross my fingers and hope I don't break my winning streak on my ride tomorrow.
Gr8 day 4 hill repeats
I don't think you got a bad batch. I have had similar experience when I do frequent rides in the local mountain roads where there is a fair amount of scree and small rock debris on the roads, particularly after storms. If that's the source of your problem, I doubt, as others have mentioned, that you will have a better experience by changing to a different light weight tire, although I noticed today that Bontrager seems to have more rubber in the sidewall. I've been using the GP4K since they replaced the 3K, and am considering a change for other reasons, but sidewall vulnerability is certainly an issue.
Portland Fred
But I agree that the Conti 4 Seasons is a good all rounder tire with decent flat and sidewall cut resistance.
Quoted: 24 Post(s)
I have tried them all. I have come to the conclusion that they are all about the same, as far as flats. I think it's more about air pressure, road condition, and luck!
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
23s: 100f, 110r
25s: 90f, 100r
I am 180lb/82kg and that is what I run.
Btw, Deepak - I've used GP4000s on our island roads that are orders of magnitude worse than what you guys have in Bangalore. No problems with sidewall cuts or flats. But then, I also use PR3s as my daily riding tire and have only had 2 flats in >5000km of riding, so maybe I'm lucky when it comes to flats.
V.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1272 Post(s)
Liked 1,322 Times
But to the OP, it sounds like you're underequipping yourself for the types of roads you're no doubt encountering. I've been riding Conti GP4000S on my main road bike since they were first introduced, and I've found them to be no more (or less) prone to sidewall problems than any of the other tires (Hutchinson, Specialized, Michelin, & Conti Attack/Force) I've used over the years.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I did some research and finally went with Grand Prix 4 Season tires. The sidewall construction is slightly different from the GP4000.
No flats yet. Got my fingers crossed.
Beefcake the Mighty
Same here. I'm 2/2 with the sidewall bulge. was running pressure at 100 psi and don't even recall running over anything, just started hearing rubbing against my frame. recently decided to give them one more shot, chalking that up to a bad batch maybe.
Should Be More Popular
Quoted: 22732 Post(s)
Liked 9,099 Times
Bikes: 2011 Cannondale CAAD10
I also weigh 170 and run 100/110, based on the same formula, i'm sure. It's hard for me to imagine that an extra 10 and 20 psi would be causing that much of a problem, tho.
Live to ride ride to live
Bikes: Calfee Tetra Pro
I have only used two different tires. I have had GP 4 Seasons which are durable and then GP 4000s. I have had a few 4000s destroyed because of side wall damage but I still love the way they ride. They are a ***** to install when new though. I had some suggest that I should try Michelins.
Bikes: Parlee Z5 SL Ltd | Seven Odonata
Bad roads and a heap of debris. What you might try is using a rubber anti-flat sealant in the tube, or a Kevlar band glued inside your sidewalks with tubular adhesive. Both of these are heavy, messy solutions and would be a right old pain if you did flat and have to change the tyre. Otherwise, taller stronger tyres like Continental Gator Ultraskins in 25 or 27mm might puncture less often.
Bikes: are better than yours.
Duranos would probably have been a better choice for Schwalbes.
Telemachus has, indeed, sneezed.
Bikes: 2010 Jamis Xenith Comp
