Question RE Hydraulic Disc Brakes
Old 09-16-11, 07:34 PM
s-words
So, I keep seeing these Rube Goldberg cable-to-hydraulic disc brake adapters in interbike coverage (see pic). I've also heard racers say that they don't run disc brakes because the only ones that work with road levers are the lower-end cable actuated ones.
My question is this: why not run flat bars and MTB shifters/levers? Somebody must have tried this--I just don't understand why I've never seen it on a top-level racer's bike.
I have never raced cyclocross, so I'm aware that this might be a stupid question. But think about it: with a slightly larger (longer top tube) frame and a long stem, the position would be right, and it might even be better for technical sections, etc. I don't see any disadvantage. It might even be lighter weight.
Can anyone lend some insight?
s-words is offline
Old 09-17-11, 01:05 AM
OnTheRivet
Not legal in UCI races which is why no elites. A "proper" cross course doesn't have technical sections that's what MTB racing is for. On a real cross course drop bars are a better setup.
OnTheRivet is offline
Old 09-17-11, 04:00 AM
s-words
Well, that just proves it's a better setup. :-P
s-words is offline
Old 09-18-11, 10:45 AM
flargle
IMO it's actually a better idea to have the oil reservoir separate from the shifters, rather than integrated, even if it means the compromise of have a short cable run between the two.
flargle is offline
Old 09-24-11, 02:59 PM
Chris_W
Likes to Ride Far
Chris_W's Avatar
Bikes: road+, gravel, commuter/tourer, tandem, e-cargo, folder
Quoted: 37 Post(s)
Liked 12 Times in 11 Posts
Why are so many companies going to so much trouble to setup cross bikes with hydraulic discs? Cable-actuated disc brakes work great, and don't require these conversion boxes or any messy maintenance. Avid BB-7 brakes are the current standard model of cable disc brakes, which I've used successfully on a few different bikes. They are easy to setup and adjust. They are not so light, but hopefully Avid will launch a higher-end version which is better in that aspect.
Hydraulic discs are a pain to do any sort of maintenance on - who needs the hassle when cable discs work very well?
Chris_W is offline
Old 09-24-11, 10:26 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
So far I only saw shots of a Few Trade show exhibits.. hardly a groundswell
companies that sell at a premium price , ship around the world to find the well off buyer.
fietsbob is offline
Old 09-25-11, 12:17 AM
mr.smith.pdx
mr.smith.pdx's Avatar
Bikes: 2005 Fuji Cross Pro, 2006 Allez Sport, Mid 70's French Bike named 'Pierre'
I put a BB7 on the front of my cross bike as the fork had mounts for them and I weigh a lot.
I love these brakes. 2,000 times easier to set up than any cantilever brake anywhere.
CX courses in Oregon HAVE technical parts. Sometimes I feel like half the CX courses are really just Short Track MTB courses, with beer and cowbells.
mr.smith.pdx is offline
Old 09-26-11, 06:43 AM
holychipotle
Bikes: Ridley X-fire (Chris King tubies/Rival), Specialized Tarmac (Zipps/Dura-ace)
Cantilevers are still lighter
holychipotle is offline
Old 09-26-11, 05:00 PM
flargle
Sure, mechanical discs work fine, but there are multiple advantages to hydraulic, especially on a bike that will see lots of dirt, mud, and sand.
To reiterate my previous post, I think the parabox paradigm might win out over integrating hydraulic into the lever. Putting the hydraulics into the hoods would add a lot of bulk and make servicing difficult. And with parabox, you can still use top-mount levers. (And if you're running Di2, you might as well add auxiliary shifters to the bartops. )
It may seem kludgey, but aren't cantilevers the definition of kludgey?
flargle is offline
Old 09-26-11, 05:05 PM
qmsdc15
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Liked 5 Times in 5 Posts
Is this true? I couldn't find a rule against using flat bars, only against bar ends. I don't race but am curious. A rule prohibiting the use of bar ends seems to imply that the bars on which bar ends might be installed are OK.
qmsdc15 is offline
Old 09-26-11, 05:51 PM
flargle
It's not stated explicitly in the cyclocross section, but is part of the general rules. I forget the exact wording, but there's a drawing of a bike with drop bars.
Frischknecht rocked flat bars until it was forbidden. I think 1998 was when he won a sprint for second in Worlds on flat bars in Montreal.
flargle is offline
Old 09-27-11, 07:29 PM
zac102
Yeah, hydraulic brakes can be a pain to work on, but they also require near zero maintenance.
Also, my cross bike is heavy enough that I'm not really worried about the weight of the braking system, I just want something that's less of a pain to deal with than Canti's or V-brakes.
zac102 is offline
Old 09-28-11, 12:11 PM
Rumpled
Decided to look it up, actually took a while to find
1.3.022 d) Structure
In competitions other than those covered by article 1.3.023, only the traditional type of handlebars
(see diagram «structure 1») may be used.
It goes on a bit, but no flat bars in UCI mass start road and CX races.
And elsewhere
Comments on Article 1.3.022:
Only the traditional type of handlebars is authorised for use in massed-start road races, cyclo-cross and track
competitions (except for individual and team pursuit, kilometer and 500 time trials). The attachment of any
additional handlebar component or extension is prohibited. The area of the point of support of the hands on
the handlebars is defined by the diagram below:
Rumpled is offline
Old 09-28-11, 12:24 PM
RobertFrapples
all-weather commuter
Do bicycle hydraulic brakes have a reservoir above the master cylinder piston like a car does to automatically adjust for pad/rotor wear? The only maintenance my BB7s require is occasional pad depth adjustment.
RobertFrapples is offline
Old 09-28-11, 06:08 PM
qmsdc15
How do you explain the rule against the use of bar ends?
qmsdc15 is offline
Old 09-28-11, 06:24 PM
flargle
As far as I can tell, USAC rules do not restrict bar-ends. After all, they are allowed in mass-start XC races, right? But it's a tradition to say that mountain bikes are allowed in cross races as long as you don't use bar-ends; I think it hearkens back to the day when bar-ends were huge and pointed out pretty far.
flargle is offline
Farmstar
Bicycle Mechanics
10
07-11-18 12:53 PM
spectastic
26
11-04-16 02:28 PM
Plow13
Bicycle Mechanics
2
08-21-12 10:43 AM
Jack93
Bicycle Mechanics
3
08-20-11 06:42 AM
brianbeech
17
12-02-10 07:53 PM
