Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Anyone for physics? (article on banking...)
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 05-14-12, 10:25 AM
joshpants
joshpants's Avatar
https://www.theaftermatter.com/2012/0...elodromes.html
Enjoy.
-josh
joshpants is offline
Old 05-14-12, 10:58 AM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
This means that a cyclist can only go at about 45.5 km/h around a [flat] corner without losing grip
I always wondered about that.
carleton is offline
Old 05-14-12, 01:08 PM
Speedskater
Speedskater's Avatar
Bikes: Bob Jackson, Trek & Sampson
Quoted: 56 Post(s)
Liked 24 Times in 14 Posts
That calculation only works when:
The radius of a turn on a Olympic velodrome is around 20 meters,
Now Short Track Ice Speedskaters with lots more traction on flat ice can corner way faster!
Speedskater is offline
Old 05-14-12, 04:33 PM
bitingduck
bitingduck's Avatar
Quoted: 43 Post(s)
Speedskates have long sharp edges that dig into the ice in one axis and slide nicely across it on the other.
The article leaves out a lot of interesting physics about why the turns generally aren't semicircles, as well as some interesting angular momentum effects.
Track - the other off-road
https://www.lavelodrome.org
bitingduck is offline
Old 05-15-12, 11:07 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
So, what are the other interesting bits of physics, and why are velodrome turns not a constant radius?
chas58 is offline
Old 05-16-12, 10:43 AM
Dolamite02
Dolamite02's Avatar
Bikes: Bianchi Pista, Bianchi via Nirone 7, GT Zaskar 9r Sport
Note too, that this is only on a wood surface, not concrete.
Dolamite02 is offline
Old 05-16-12, 11:21 AM
bitingduck
bitingduck's Avatar
Quoted: 43 Post(s)
If you go from the straightaway into a constant radius turn you go instantly from no centripetal acceleration to V^2/R, and it would be instant changes from no "compression" to max compression and then suddenly back. Instead they're a cycloid (or close to it) so the centripetal acceleration comes on slow, hits a max at the middle of the turn, and decreases slowly as you exit.
Another thing that's fun is conservation of angular momentum-- it helps in the paceline transitions in the corners (in addition to the elevation change effects).
Old 06-11-12, 07:32 PM
San Rensho
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
But you are going to strike a pedal way before 45 kph.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
San Rensho is offline
Old 07-04-12, 09:19 AM
KrautFed
cars are fun
It is a good start to the basics. The coefficient of friction is a variable on a bicycle. The author's first equation assumes that turning a bicycle is flat. Turning a bicycle on flat ground requires a lean which changes force vectors and friction. He/She doesn't come back to this until the end of the article where a correction is added.
I think there should have been material on the basics of superelevation.
KrautFed is offline
Old 07-04-12, 09:28 AM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Is it a cycloid? I always thought it was some form of Euler curve. I've never thought if a cycloid in being used for a banking. They both make sense to me in some respects, but not being a rocket surgeon, I wouldn't know which is best.
taras0000 is offline
Old 07-04-12, 11:45 AM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Also found this if anyone is interested
https://en.wikipedia.org/wiki/Track_transition_curve
Old 07-04-12, 07:06 PM
David Broon
Sqrl
I'm a simplistic kind of guy. The kind who rides bikes in a circle. Fast.
Somebody want to explain to us ordinary mortals what's going on?
Doing one-legged squats while holding chickens in each hand will make someone strong...that doesn't mean it's the best way to train for track racing.
Originally Posted by Nagrom_
That would be spectacular. A trail of blood and sealant.
David Broon is offline
Old 07-05-12, 04:44 PM
KrautFed
cars are fun
To turn fast, you must lean. To go (X) amount of speed, you must lean (C) amount of degrees. (C) amount of degrees is already farther than a bike can lean (A). So to get to the (C) degree angle needed, the track must me leaned as well (B). Therefore (A)+(B) = (C) and we can turn while going (X) amount of speed.
KrautFed is offline
BikeAlmanac
Winter Cycling
16
02-23-18 09:31 PM
orange leader
Winter Cycling
5
09-15-16 05:57 PM
max5480
Singlespeed & Fixed Gear
22
01-12-11 03:37 PM
