Go Back  Bike Forums > Bike Forums > Utility Cycling
Best kickstand for BOB Trailers
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 06-19-12, 12:33 PM
CabezaShok
CabezaShok's Avatar
Anyone ever make or buy a stout kickstand that holds the BOB and bike upright? Pics/links?
IMO the missing kickstand is the biggest reason people ignore the BOB as a worthy utility trailer.
thanks!
CabezaShok is offline
Old 06-19-12, 01:55 PM
thestoutdog
Non sibi sed patriae
thestoutdog's Avatar
Bikes: 2012 Surly Ogre (Shrek), 1985 Raleigh Kodiak, 1995 Specialized Hard Rock, 2009 Citizen Miami
There's quite a few out there.
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
https://thestoutdog.blogspot.com/
https://www.facebook.com/TheStoutdog
thestoutdog is offline
Old 06-19-12, 03:16 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,359 Times in 865 Posts
Seen greenfields used, both the rear triangle type, on the tow fork,
and bolted thru the deck, with a reinforcing disc, conventional center mount,
just sawn shorter.
fietsbob is offline
Old 06-20-12, 05:24 AM
BeastRider
Beast Rider
BeastRider's Avatar
Bikes: Trek Transport
I made my own a few years ago with PVC and it worked just fine. Never had any problems with it and it held up to some 100+ pound loads. Although the rear PVC rack didn't stay on too long as it proved to be far too inadequate for anything even CLOSE to a load.....
But you get the idea for the centerstand.......
BeastRider is offline
Old 06-20-12, 07:31 AM
amit_shah25
Drunken Master
amit_shah25's Avatar
Bikes: Jamis Ranger 1.0 (Mutilated !!), Trek Portland
Click-Stand - https://www.click-stand.com/
I use this with my BOB. I have no affiliation with the maker of click-stand. Just find the product very useful and handy. They have "tiny bands" that you put around the break so the bike doesn't take off on you, and then you unfold the click-stand.
I have used it on my loaded bike with a loaded BOB and it holds pretty good. You do have to be a bit careful about the ground not being too soft, but that will be same with any stand.
Nothing to say !
amit_shah25 is offline
Old 06-20-12, 07:52 AM
CabezaShok
CabezaShok's Avatar
Thanks BeastRider. I found some detailed DIY instructions for building this PVC kick-stand. ive never worked with PVC so this will be good time to learn. I like the old tire as a fender/splash guard...i think ill do that too.
Amit-shah: thanks, i should have mentioned i want the BOB to support itself when not attached to a bike....so the PVC stand will be better IMO.... also a loaded BOB will be easier to attach/remove from the bike with the PVC stand. Attaching/removing the loaded BOB is another downside to owning a BOB..... i forgot to mention
Old 08-25-17, 03:02 PM
rholford
I am not seeing the pictures of this stand. Could someone direct me to a website or somewhere I could find the plans for this PVC stand? Thanks!
rholford is offline
Old 08-25-17, 05:18 PM
tramptrade
Some Canuck on a Bike
tramptrade's Avatar
Bikes: Cannondale, Brodie
Quoted: 24 Post(s)
Probably not the same one, but I found this with a quick search of Google images ...
B.O.B. modifications | Bike FL 2 CA
Should give you something to work from.
Here is the Google search itself ...
https://www.google.ca/search?biw=136...Nm0WKU#imgrc=_
Go confidently in the direction of your dreams. Live the life you have imagined. - Henry David Thoreau
tramptrade is offline
Old 08-25-17, 05:33 PM
rholford
Thank you!!!
rholford is offline
Old 09-19-17, 05:27 AM
amedias
Quoted: 42 Post(s)
Liked 116 Times in 38 Posts
need to get some kind of stand setup on my BOB too, been bugging me for years. Was going to try and bodge a normal kick stand on but a two legged one might be a better idea as can support the whole bike/trailer better.
amedias is offline
Old 09-23-17, 02:27 PM
fietsbob
Bikes: 8
Jacknifing the trailer holds the bike up, you know (?)
fietsbob is offline
riverdrifter
Recreational & Family
3
05-19-19 01:37 PM
Charlie_R
Living Car Free
15
07-23-14 03:20 AM
kiltedcelt
Recumbent
3
05-17-14 05:58 PM
syncro87
Utility Cycling
5
12-13-11 06:36 AM
realestvin7
Classic & Vintage
16
10-03-11 10:31 AM
