Considering 700x28c rear tire
Bikes: None at the moment
I own a Specialized Secteur Elite. Currently I ride on 700x25c both front and rear. I weigh around 240 lbs. I inflate my rear tire to 125 psi (max on the sidewall). According to the famous 15% drop chart this isn't enough. Should I change the rear tire to 700x28c? I don't get any pinch flats with the current setup.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
There is room for 700x28c, if I've done my research correctly.
The chart I'm referring to is this one: https://www.bikequarterly.com/images/TireDrop.pdf
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1356 Post(s)
Liked 1,253 Times
Get one and try it.
I have a 700 X 28 Michelin tire that measures as 30 when on the rim.
Fred "The Real Fred"
Descends like a rock
If you're not getting pinch flats now then no need to change. However, you might find you like 28s.
Thanks for the answers so far. Since you don't think it's necessary, maybe I'll try it when it's time to change the rear tire. Or if I find a spare 28 for free...
Retired dabbler
Location: Acton, MA (20 miles west of Boston) - GORGEOUS cycling territory!
Bikes: 2007 Specialized Roubaix Elite Triple - 1st ride = century 9/19/2010 , Ultegra
Quoted: 46 Post(s)
At 237# (4 months ago & before) I found the venerable Continental GP4000 700x25 tires worked well. Lots of miles, zero flats until the sidewall failed. I run about 100 PSI up front and 115 in the rear. Unfortunately ProBikeKit.com is out, but that's the place to buy them (delivery takes 5-7 days, IIRC).
Good luck.
Good luck.
Quoted: 3428 Post(s)
Liked 5,642 Times
I have bikes with 25mm, 28mm, and 32mm.
My favorite is the 28mm, and I do use the 15% drop method for inflation pressure.
I weigh 185#.
And btw a 28mm Gatorskin on a 23mm rim actually measures 27mm.
I weigh 185#.
Liked 5,642 Times
pan y agua
Quoted: 1483 Post(s)
Liked 768 Times
Imho, those charts are rough guides at best. We run 25mm tires on the tandem with a team weight of 350lbs at 110-115 psi with no problems, which is way off what the chart would suggest.
You could get lost and die.
You could hit a tree and die.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
I rode a set of 28 for the first several years after returning to cycling. I was new back to the sport, and with the "newly" acquired prosthesis, didn't want to take any chances with flats of any kind. I used a set of hard case tires, which I am sure had some impact on the feel, and turning was very slow and cumbersome feeling compared to the 23 that came on, and that I later switched back to.
With that said, I NEVER had a flat with those tires of any kind.
I am a 210~#, and have weighed considerably more. I swapped back to 23 Conti's, run them at about 100PSI and have had no out of the ordinary issues with them as far as tire or rim are concerned. If you aren't having issue now (but second the idea that you lower pressure some) then I don't suspect you have any real reason to change to a larger tire unless you just want to.
shut up and ride
Bikes: supersix hi-mod,burley duet tandem,woodrup track,cannondale cross,specialized road
am running the rubino pro 28s on my caad9 right now, i love 'em, takes the edge off the stiff aluminum nicely. won't fit a lot of bikes. a lot less cuts than the michelin pro race 2 and 3 that i've run for years. not as nice as the vittoria open cx but then what is?
why does everyone overthink all the little stuff? it's only a relatively inexpensive set of tires, if you know they fit, buy'em and try 'em and decide for yourself, if you don't like them buy something else and put them on the shelf as spares
Overthinking little stuff? U know this little stuff costs 50 bucks, right? I'm a student and I don't have any income on my own...
novemberhotel
13
03-03-16 03:34 PM
hobkirk
31
06-26-10 12:11 AM
