Bent Brompton rear rim
Old 08-22-12, 11:23 AM
maidenvoyage
Human
I went for my first long(ish) ride on my new brompton this past weekend and towards the end I noticed the rear rim was bent and needed to be trued. I took it to the shop and they "straightened it as best as humanly possible" but it still isn't ideal, and there is a slight wobble. Should I push for a replacement? I have only ridden the bike about 30 miles total. Would this be covered under warranty?
maidenvoyage is offline
Old 08-22-12, 12:38 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
still rather vague terminology..
Noted: there are people apparently with OCD posting here ,
they often seem to seek an unrealistic Ideal.
slight wobble ? radial or lateral? , how many mm? ..
If you hit something riding, and damaged the rim, it is not a material defect.
it is accidental damage. you fix it.. ,
probably don't have to buy new spokes , though..
the rear ones are pretty thick.
But generally Mass produced 'machine built' wheels
benefit from some individual hand tensioning and truing ,
checked at the local level ..
perhaps you just did that and are good to go for a while.
fietsbob is offline
Old 08-22-12, 01:31 PM
maidenvoyage
Human
The 'wobble' is lateral an I haven't measured but it's noticeable when riding. I'm confident that I didn't hit something to damage the rim, I've been riding for years and this has never happened with other bikes. I'm a very cautious and aware rider.
Old 08-22-12, 01:55 PM
fietsbob
Bikes: 8
If the rim runs round , judging by the way it passes the brake pads ,
neither rising or falling in relationship to the pads.
then the issue may be the Tire, or the mounting of it,
or you feel the imbalance of a big relatively heavy spoke mounted reflector.
probably just a conversation , on the topic, blind guesses are the best Offering.. from way out here..
you got a warrantee statement when you got the bike ?
Perhaps the dealer will replace or rebuild the wheel IDK.
fietsbob is offline
Old 08-22-12, 03:52 PM
chagzuki
Bikes: Brompton, Dahon Vitesse D5
Quoted: 55 Post(s)
A properly built 20" or smaller wheel ought to be near indestructible, particularly the 28 spoke variety. Absolutely make sure it's replaced under warranty.
chagzuki is offline
srjones1989
Folding Bikes
2
03-19-19 06:37 PM
Deontologist
General Cycling Discussion
11
02-04-15 08:13 PM
sknhgy
Bicycle Mechanics
6
10-10-10 03:36 PM
Yst
Bicycle Mechanics
2
06-09-10 08:40 AM
Roy G. Biv
Singlespeed & Fixed Gear
1
06-07-10 10:55 AM
