Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Clarify NY law about reflectors
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Old 10-31-12, 11:19 AM
vol
Liked 18 Times in 12 Posts
Originally posted on the Northeast forum since it concerns NY:
Originally Posted by vol
"(e) Every bicycle when in use during the period from one-half hour after sunset to one-half hour before sunrise shall be equipped with reflective devices or material meeting the standards established by rules and regulations promulgated by the commissioner; provided, however, that such standards shall not be inconsistent with or otherwise conflict with the requirements of subdivisions (a) and (d) of this Section."
Just would like to clarify: If I have white reflectors on the wheels, but no red tail reflector, will I meet this requirement? (It doesn't say which part of the bike to equip reflectors)
Also, why does it require both a taillight-on and a tail reflector at the same time between dusk and dawn? "(e) Bicycles must have a white headlight, a red taillight and reflectors between dusk and dawn." If the taillight is on, what's the point of tail reflector?
(am not sure which of the quoted "(e)" overrides the other)
vol is offline
Old 10-31-12, 11:38 AM
spivonious
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
vtl § 1236 – lamps and other equipment on bicycles: (a) every bicycle when in use during the period from one-half hour after sunset to one-half hour before sunrise shall be equipped with a lamp on the front which shall emit a white light visible during hours of darkness from a distance of at least five hundred feet to the front and with a red or amber light visible to the rear for three hundred feet. (b) no person shall operate a bicycle unless it is equipped with a bell or other device capable of giving a signal audible for a distance of at least one hundred feet. (c) every bicycle shall be equipped with a brake which will enable the operator to make the braked wheels skid on dry, level, clean pavement. (d) every new bicycle shall be equipped with reflective tires or, alternately, a reflex reflector mounted on the spokes of each wheel. (e) every bicycle when in use during the period from one-half hour after sunset to one-half hour before sunrise shall be equipped with reflective devices or material.
(e) doesn't require specific reflectors, just that the bicycle has some reflective devices or material.
spivonious is offline
Old 10-31-12, 12:56 PM
DieselDan
DieselDan's Avatar
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
There is a CPSC standard for reflectors, which the law maybe alluding to, but is a bit vague about. If you use reflective tape to US DOT standards, that would exceed the CPSC standard. The bit about having a tail light and reflector is mirroring the same for automobiles.
DieselDan is offline
Old 10-31-12, 02:18 PM
cplager
The Recumbent Quant
cplager's Avatar
Bikes: 2012 Cruzbike Sofrider, 2013 Cruzigami Mantis, 2016 Folding CruziTandem
Quoted: 28 Post(s)
Liked 8 Times in 6 Posts
For what it's worth, I highly suggest powered lights if riding in non-optimal lighting conditions. For that matter, I recommend powered lights all the time (most cars have running lights, why not bicycles).
cplager is offline
Old 10-31-12, 04:38 PM
vol
I always use lights when dark. What I'd like to know is, if I use lights, is it ok if I don't have a tail reflector? The reason I needed to clarify about this is, I don't have tail reflector (removed by the LBS when they installed the rear rack for me; they forgot to put it back.). I also hardly have room for it: on the seatpost it would be invisible and useless. Rack, seat stays, I use for my lights. But this law keeps bothering me. What kind of a cop would ticket someone who has the taillight on during the dark but is without a tail reflector?
On another note of the (un)usefulness of reflectors: since they are so directional, why don't they make it ball-shaped, so it will reflect in every direction?
vol is offline
Old 10-31-12, 06:43 PM
CB HI
Cycle Year Round
CB HI's Avatar
Quoted: 1316 Post(s)
Liked 92 Times in 59 Posts
It looks like you are legally good to go.
A NYPD jack boot.
Land of the Free, Because of the Brave.
CB HI is offline
Old 10-31-12, 08:50 PM
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
Looks like you're fine in NY with just the rear light. I still prefer to supplement my rear lights with some reflective material since 1) just in case one or both lights fail and I don't notice right away, 2) reflectors are cheap and light - so why not, and 3) the ones on my pedals/shoes move up and down as I pedal and make it clear that I'm on a bicycle.
As to the directionality, cube reflectors and the materials using that principle are indeed very directional but the direction is always right back at the source of the light. That gives you the best visibility to any driver who has his lights shining in your general direction. It's very different from the directionality of a mirror surface which would have to be carefully positioned to be perpendicular to the incoming light in order for it to be reflected back to the source. A corner-cube reflector works the same as if you throw an elastic ball into the cube corner formed at the intersection of two walls and the ceiling - no matter where you stand in the room, if you throw the ball into that corner it'll bounce out coming back to you (at least if thrown hard enough so it travels in fairly straight lines).
prathmann is offline
rachel120
Advocacy & Safety
59
09-07-17 04:51 PM
Archery_Queen
Commuting
19
04-17-14 11:58 AM
TheRealWolf
Advocacy & Safety
17
04-22-13 08:21 PM
no1mad
Commuting
25
05-14-12 01:20 PM
jputnam
Advocacy & Safety
181
03-03-12 01:59 PM
