Helmet cover
Helmet cover
Old 11-06-12, 11:07 AM
jrickards
jrickards's Avatar
Bikes: 2012 Kona Sutra, 2002 Look AL 384, 2018 Moose Fat bike
Quoted: 133 Post(s)
Liked 6 Times in 5 Posts
Helmet cover
Currently, I'm wearing a medium thickness fleece balaclava under a ventilated helmet. This morning, I felt the cold on my bald head (under the balaclava of course), especially on downhill runouts where I can be travelling up to 45km/h. I'm thinking of getting a helmet cover which will virtually eliminate wind through the helmet vents but also will cause my head to heat up more so maybe I'll wear a thinner balaclava and a buff or similar setup.
Does anyone else wear a helmet cover at this time of year and how do they like it?
jrickards is offline
Old 11-06-12, 11:30 AM
hyhuu
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
How cold was it?
hyhuu is offline
Old 11-06-12, 12:27 PM
jrickards
jrickards's Avatar
Quoted: 133 Post(s)
-4C, with a wind chill of course because I was moving, winds were 9km/h E.
Old 11-06-12, 12:35 PM
Notso_fastLane
Notso_fastLane's Avatar
Quoted: 626 Post(s)
Liked 701 Times in 418 Posts
-4C? Damn, the roads around here don't dry very well when it gets that cold, I'd be driving.
Notso_fastLane is offline
Old 11-06-12, 12:53 PM
ckaspar
Originally Posted by jrickards
-4C
I didn't even know it could get into the negatives. lol
ckaspar is offline
Old 11-06-12, 12:56 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
I use a J&G helmet cover. Bright yellow, waterproof and has a loop in the back for a blinkie. Works great. Keeps head dry and warmer.
Leebo is offline
Old 11-06-12, 01:07 PM
thorsteno
wannabe
I'm also a bald helmet cover user. The only negative I can think of is possible interference with a helmet mounted headlight. No overheating issues with my setup.
thorsteno is offline
Old 11-06-12, 01:45 PM
jrickards
jrickards's Avatar
Quoted: 133 Post(s)
Kelvin doesn't go below zero, 0Kelvin is -273C, it's not quite that cold here, EVER!
Old 11-06-12, 01:56 PM
canyoneagle
canyoneagle's Avatar
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times in 75 Posts
When things get below freezing, I dispense with the uber ventilated summer helmet and wear this over a thin Pearl Izumi beanie. When things drop below -7C or so I add a polar fleece headband and thin balaclava.
canyoneagle is offline
Old 11-06-12, 02:32 PM
fasthair
Quoted: 51 Post(s)
Liked 15 Times in 10 Posts
I use one and love it.
fasthair
fasthair is offline
Old 11-06-12, 04:06 PM
dramiscram
ouate de phoque
dramiscram's Avatar
Bikes: Bianchi, Nakamura,Opus
I will use a cover only in cold rain. If it's too cold I'll just wear a thicker wool hat.
Or you could try this :https://www.hairtransplantnetwork.com/
dramiscram is offline
Old 11-06-12, 06:03 PM
cyclefreaksix
cyclefreaksix's Avatar
Liked 4 Times in 4 Posts
I use a helmet light so a helmet cover won't work. I also live in Texas so it doesn't get that cold here. But the few times that it does, I just wear a fleece skull cap under my helmet.
cyclefreaksix is offline
Old 11-06-12, 07:50 PM
bubbagrannygear
just ride
Bikes: specialized roubaix, dawes sst ( steel single speed)
Quoted: 5 Post(s)
I pretty much hop from the shower to the bike in the morning so I usually have damp/wet hair. When it gets to mid twenties
fahrenheit I use the goretex helmet cover and a thin pearl izumi head band. Very happy with the combo. Also during the warmer weather I keep the helmet cover in my bag for when I get caught in a downpour.
bubbagrannygear is offline
Old 11-06-12, 08:09 PM
rogerstg
Fred-ish
rogerstg's Avatar
I use strips of painters tape to block the front vents when it gets cold. The beauty of that system is that you can remove some tape when it gets warmer during a ride.
rogerstg is offline
Old 11-06-12, 08:38 PM
David Bierbaum
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
Quoted: 26 Post(s)
Liked 35 Times in 19 Posts
You could always try stuffing kleenex in some of the more forward-facing vent-holes! I use the cover from my old helmet, which has netting over the top and solid weave on the sides. If that get's too cold, I can put a paper towel between the helmet and netting to whatever extent I'll need.
So far, with temps in 40s and 50s (Fahrenheit) here, just the cover has been enough to protect my scalp from chilling in the breeze, even while battling a headwind.
David Bierbaum is offline
Old 11-06-12, 09:03 PM
david58
david58's Avatar
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
A cheap shower cap can do the job, you can cut a slit for the helmet lamp and still block the wind. Just don't let the fashion police see you...
david58 is offline
Old 11-06-12, 09:52 PM
silmarillion
silmarillion's Avatar
Bikes: 2012 Cinelli Mystic Rat, Nashbar CX
I always wear a Under Armor skullcap under my balaclava. Seems to do the trick, but I haven't experienced weather that cold yet..
silmarillion is offline
Old 11-07-12, 03:33 AM
acidfast7
Bikes: 2010 Cube Acid / 2013 Mango FGSS
Quoted: 1053 Post(s)
Liked 41 Times in 36 Posts
it was +4C this morning and my head was a little cold. a few people i saw riding had helmet covers and i may pick one up if it gets colder.
https://www.amazon.com/VAUDE-Helmet-r...e+helmet+cover
it was this one in fact ... only 10 USD for you guys, what a steal!
FWIW, it has great reviews on the german version of amazon
acidfast7 is offline
Old 11-07-12, 06:31 AM
hyhuu
Quoted: 12 Post(s)
I wear a thin skull cap in temp down to -8C. Once I get moving, I generate plenty of heat to keep my head warm. I think the key is windblock but breathable and a little insulation.
hyhuu is offline
Old 11-07-12, 07:51 AM
jrickards
jrickards's Avatar
Quoted: 133 Post(s)
Merino wool is not available, so I'll have to pass but thank you for the tip!!
Old 11-07-12, 10:55 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
Im OK with helmet covers on helmets
MEC and Showers Pass have a flap on the back
to keep rain from streaming down your collar and neck ..
fietsbob is offline
Old 11-07-12, 11:27 AM
MassCommuter
Bikes: 1984/85 Schwinn Voyageur SP; 1992 Trek 970; 1993 Burley Rock n' Roll tandem; 2007 Cannondale F5
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
I've utilized the Sheldon Brown method of packing tape. It does make a difference.
I also wear a headliner underneath my helmet.
MassCommuter is offline
Old 11-07-12, 06:45 PM
maidenfan
maidenfan's Avatar
These are caps that I've used and liked a lot:
Walz reg cap - https://www.walzcaps.com/caps_wool-threepanel.html
Walz winter cap - https://www.walzcaps.com/caps_wool-earflap.html
Assos Stinger 609 - https://assos.com/en/19/singleProduct...31,39&prod=403
Smartwool cuffed beanie - https://www.smartwool.com/mens/access...anie-1201.html
Mountain Hardwear Beta Beanie (nice, light one) - https://www.mountainhardwear.com/Men%...efault,pd.html
Gore Windstopper Beanie (prob my favorite cold cap) - https://www.goreapparel.com/GORE-BIKE...ories-headwear
I have a PI WxB helmet cover, but generally only wear it when its raining hard. It provides quite a bit of warmth as it cuts all the wind. I wear the Walz caps the most. The companys customer service and product quality are the best. For example, I have a big head and ordered the XL sized hats and they were just a tad too small. I called Walz and they told me to send them back and they made them bigger at no cost to me or shipping. In fact, I'm sending them back here soon to have the bills shortened a bit. Highly recommended.
maidenfan is offline
Old 11-08-12, 03:08 AM
Warbuff
Bikes: 2013 Trek 7.2 FX Disc
I bought this one in bright yellow and used it during the hurricane. Did its job https://www.amazon.com/Pearl-Izumi-Ba...d_sim_sbs_sg_1
Warbuff is offline
Old 11-08-12, 06:31 AM
Trek_geek
Trek_geek's Avatar
Location: Fredericksburg, VA to Fort Belvoir by VRE and bike
Bikes: 2006 Trek 1000 SL, 1995 Performance 505 MTB, 2012 Trek 520 (my daily commuter)
My helmet can adjust large enough for me to wear a Performance Fleece beany in colder weather.
Trek_geek is offline
