Japanese Loro Brompton 5-speed hub - anyone heard of this?
Old 12-15-12, 11:40 PM
bargainguy
bargainguy's Avatar
Quoted: 524 Post(s)
Liked 321 Times in 197 Posts
https://www.loro.co.jp/bro510set/brompton510.html
Website in Japanese, translation to English a little wonky but serviceable.
I can find precious little info on this hub. Looks intriguing, esp. the 5x2 derailleur option.
Don
bargainguy is offline
Old 12-16-12, 12:38 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
My guess, mechanically they did a mix and match of parts, you buy both hubs,
or the 5 speed core & tear them down,
doubt the 5 speed is 28 hole.. But could be..
but maybe more internal swaps can be done and retain the 28 hole hubshell.
try, give it a go?
fietsbob is offline
Old 12-16-12, 02:52 AM
badmother
badmother's Avatar
Quoted: 317 Post(s)
Approx £311.- labour included. Translation difficult but I would guess labour is cheap in the far east. Why not buy the same hub from SJS or other western supplyer?
Edit: Only found this one today, think i remember a W and a N https://www.sturmey-archer.com/products/hubs/cid/4/id/64 Same hub, 256% . Has been discussed here plus in the Bromptonforums.
badmother is offline
Old 12-16-12, 09:25 AM
graywolf
Bikes: Bianchi hybrid. Dunelt 3-sp. Raleigh basket case. Wanting a Roadster.
In looking at IGH, I have noticed that the 5-speed hubs often sell for more than the 8-speed hubs. you might want to check on prices before buying.
BTW, unlike a lot of people who object to the wide gaps between 1-2 and 7-8 on the SA 8-speed, I consider the hub to really be a Granny+6speed+Overdrive hub, which to me makes a lot of sense.
graywolf is offline
Old 12-16-12, 11:50 AM
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday triplet, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Hollands Tourer
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
Don
That is a neat page. Plus they have a wide range of cog pairs ... 12-17 seems to be the widest.
A narrative on bicycle driving.
invisiblehand is offline
Old 12-17-12, 09:56 PM
bargainguy
bargainguy's Avatar
Quoted: 524 Post(s)
Just mulling over gearing options for my new M3L with this one, but if it's just a mishmash of a couple different hubs, not as interested. Thanks, all!
Don
Old 12-18-12, 01:04 AM
fietsbob
Bikes: 8
I run a Schlumpf mountain drive crankset with my M3L, it uses the 3 speeds twice, for 6 ratios, wide range.
Or put on a double chain set and use the greasy finger shifting, unless you get one of the custom FD mount Brackets.
fietsbob is offline
Old 12-19-12, 09:35 PM
Dynocoaster
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times in 6 Posts
5 speed wheel with shifter
https://www.ebay.com/itm/Brompton-16-...item3f205656c2
Speed Uno
Dawes Kingpin 2speed
Dynocoaster is offline
Old 12-19-12, 09:55 PM
rofi
I heard that SA S-RF5 is underrated IGH. It needs more attention to keep happy pedaling. Is it true? I have plan to upgrade my brompton from 3 to 5 speed. I like 5 speed with 1 shifter than 6 speed with 2 shifter and 5 speed with wide ratio is enough for me. Schlumpf idea is the best solution I think, but it's too expensive.
rofi is offline
Old 12-20-12, 02:48 AM
badmother
badmother's Avatar
Quoted: 317 Post(s)
Search the forums to see what peopel say about them. I have an old (two wires) 5 speed hub on my B. Good but a bit sensitive on the adjustment.
After much thinking and reading I have decided to upgrade my sons B to 5 speed, the nine spline hub. I think it is a good solution since 5 is more than 3 and with the same weight. Also options for 10 speed instead of 6.
Old 12-20-12, 11:45 AM
fietsbob
Bikes: 8
Used Shelton's gear math engine, found combining the Schlumpf mountain drive, & the current wide range 5,
the lowest in high range, and the highest, in low range, are , overlapping there, almost the same ratio..
54t, [low is 21.6 equivalent]
.... High . Low range
1) 41.7 _ 16.7
2)50.1 _ 20.0
3) 66.8 _ 26.7
4) 89.0 _ 35.6
5) 106.8 _ 42.7
fietsbob is offline
raftr
Folding Bikes
20
08-08-19 03:57 PM
Still Pedaling
Folding Bikes
92
09-01-17 01:00 AM
jamesj
11
10-24-15 11:51 PM
thugpipe
Folding Bikes
7
08-05-14 04:41 PM
oban_kobi
Singlespeed & Fixed Gear
9
07-28-11 11:49 AM
