replacement rear shock
i need a differnt shock for my bike something newer i have a fox vanilla r right now and if my measurements are right its a 7.25x1.5 its a free ride bike so i need help
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
You actually need a a 7.25x1.75 for that bike. Santa Cruz doesn't have any clearance shocks right now; anyone else know of a good source?
BTW, ruskko, if your shock's not blown, why not just get the right weight spring for your Vanilla R? It's not a bad shock. Steel springs are cheap - - you can usually pick up a Fox spring for about $25 off eBay. To determine the right weight, I would contact Rocky Mtn directly and just ask them what weight springs they put on that year Flow FS.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
OK, here's the deal: not everyone who sells springs lists them by 'Fox-correct' numbers. In other words, they may list them by the sock stroke number that the spring fits - - like 600#x1.75, when the spring may actually be a 600x1.8 or 1.83 or whatever (the built-in extra we discussed before that is built in to avoid coil-bind).
I happened to find the Fox chart of almost all bikes by year, what shock it takes and what weight springs were offered with it (https://service.foxracingshox.com/con...educerSpec.xls). As you know, your shock is a Vanilla 7.25x1.75. The springs available on you 05 RM Flow FS were 500, 600, 700 800 and 900# springs (really? wow, has a higher leverage ratio than I imagined). Here are part numbers and travels:
500 = 039-02-016-A = 1.940
600 = 039-02-055-A = 1.85
700 = 039-02-056-A = 1.83
800 = 039-02-041-A = 1.83
900 = 039-02-025-A = 1.83
Hint: most companies other than Fox list their springs by shock shaft travel rather than actual spring travel.
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
That's what I thought. Before I saw the spread, I wondered what in the !@#$%^&*(!@ yours was doing with an 800# spring. 8-900 would definitely be for a heavier rider though . . . how much do you weigh?
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
The 800 should be in the ballpark, according to the range. But if it feels way oversprung, I'd order a 700# from an outfit that also carries a 600 or 650. That way you can put it on, test it out, then exchange it if you still need to adjust down. You'll be out a little shipping maybe but better than being stuck with another wrong-weight spring.
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Well . . . maybe you better throw in a bid on this Float:
https://www.ebay.com/itm/Fox-Float-R-...item460ce63195
