Rack/ Water bottle cage combo help!
Non sibi sed patriae
Bikes: 2012 Surly Ogre (Shrek), 1985 Raleigh Kodiak, 1995 Specialized Hard Rock, 2009 Citizen Miami
So I have installed a Salsa Down Under Lowrider rack and two water bottle cages on the forks of my Surly Ogre. The Problem I am having is that when the rack is properly leveled, the end of it (see picture) goes through the water bottle cage and actually gets in the way of a bottle in the cage. Now, I can use a plastic bottle like a polar bottle, but I really prefer to use stainless steel bottles with no give. My question is, what to do? Should I cut back the end of the Salsa rack (voiding the warranty) or should I try to install some sort of riser for the water bottle cages and longer screws? Help!!!!
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
https://thestoutdog.blogspot.com/
https://www.facebook.com/TheStoutdog
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
I gather you can't reinstall the rack using the second hole?
Well, if it were mine, I'd cut that bit off of the rack.
The rack will still function and the water bottle holder will hold a stainless steel bottle.
Keep in mind, I rarely worry about warranties.
If you can't reinstall the rack using the second hole I would cut it off. It adds nothing to the rack.
SuperGimp
It looks like you have a lower water bottle mounting bracket also? Can you mount the bottle lower?
Bikes: 2003 Cannondale Jekyll 1000, 2014 Fuji Finest 1.5 (wife), 2008 Fuji Finest 1.0 (Daughter), 2012 Fuji Cross 2.0 (son), 2011 Cannondale Road Tandem 2
Quoted: 57 Post(s)
Liked 27 Times
What panniers are you using? Is that bottle cage even usable with the pannier in place?
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
+1, assuming you are happy with the rack and planning on keeping it. Otherwise, I'd go with spacers. Someone (Problem Solvers?) makes spacers specifically for water bottle cage bolts. I'd worry that bending it would end up scratching the fork.
Bending it could also weaken the metal.
If I could find some frame specific (bent) spacers I would just raise the bottle cages, though it hasn't happened yet. I may just have to grind away at the end of the rack.
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
Quoted: 5234 Post(s)
Liked 3,609 Times
take it off and trim the brace with a hacksaw, file the edges, then re-install
if you have power cutting and grinding tools, even better
Bottle Cage Adapter
https://mountskidmore.com.au
so you can put the hacksaw away for now.. if you want
Quoted: 184 Post(s)
Liked 353 Times
Here's a bottle cage adapter we made to fix these sort of problems
Think I'm going to bookmark your link for future reference.
