Zeus
Zeus
I picked up this Zeus a couple weeks ago. From what I have gathered so far I believe it's ~late 60's-early 70's.
I originally started a thread in the C&V appraisal-inqury section which can be seen here..... https://www.bikeforums.net/showthread.php/925377-Zeus
Much thanks to juvela for sharing quite a few details about early Zeus bicycles and also much thanks to afilado for hooking me up with a very nice Super Alfa brakeset.
Still searching for Zeus specific (French threading) top tube cable clamps, cable guides, 5 speed freewheel, 165/170mm crankset and BB.
There does not seem to be a lot of info available on these bicycles and I welcome anything you may have to share.............
Be where your feet are.......Lisa Bluder
wrt f/w:
afaik there was no zeus branded f/w at the time your machine was produced. the 2000 f/w launched some years later. it is a costly little item with its alloy cogs.
for a metric thread contemporaneous one you might go with something from atom/maillard.
one possible spanish badge f/w and chain might be iris.
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Liked 9 Times
A zeus should really be built up with Zeus parts, that's how they came. They turn up on ebay, but have gotten pricey. I have 3 bikes.
cyclomondo has 2 versions of the decals on ebay.
one must measure...
"spins on easily" is not necessarily a good sign. metric f/w thread has a pitch diameter of 34.7mm which is smaller than BSC or Italian so a BSC or Italian thread f/w body will thread on very easily indeed. alas there is a possibility of stripping the thread. not even a good "class b" fit.
one must measure...
one must measure...
....."A bottom-bracket cup can serve as a thread gauge for a freewheel: Dimensions are usually marked on cups. Hold the threads of the bottom-bracket cup against those of the hub, and look in between, against the light. If the threads engage tightly all the way across, the thread pitch is the same. If they rock across each other, it is different. You may check the thread pitch of a freewheel by threading an ISO left bottom-bracket cup into it (not a right cup, which is left-threaded). The cup will go in easily if the thread pitch is the same -- but do have a freewheel extractor tool handy so you can unscrew the cup."
Likes For r0ckh0und:
Are you running a 5 speed fw on any of your bikes? I have not come across one yet.
Are yours repaints and did they have chrome socks?
Do you know how old these are?
I repacked the hubs yesterday and found it interesting that both sides of both hubs use 8 bearings each. If you don't put enough grease in there it makes quite a racket.
The hubs also have "dingle rings" (for lack of a proper term) on them.......ie; a piece of leather about the size of a shoelace, wrapped around the hub and banded together with a small thin piece of wire.
Extraordinary Magnitude
Liked 1,789 Times
Hub shiners...
Commence to jigglin’ huh?!?!
LOL @ "dingle rings"!!!
that Zeus has had a hard life. i hope you restore it to its shining glory! i've always been a fan of everything Zeus.
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
f/w threading: good to hear you have it sorted. just wanted to make sure you did not create a mismatch.
hub repacking: "eight balls per side front and rear" did not sound at all correct. but since it has been many years since repacking a zeus hub checked the Sutherland manual. for the front it gives 9 7/32" balls per side and for the rear it gives 9 1/4" balls per side. no wonder it clatters a bit! someone has been in there previously...
the bicycle's hubs will be a model called gran sport. the machine's road ensemble is called criterium but there are no criterium hubs. hub models went from gran sport to 2000 and then on to other models such as new racer, etc.
Liked 9 Times
The yellow one was a repaint, had chrome, got as a frame in about the same condition as yours. Had some of the parts and still looking for a set of brakes. The silver one was repainted by someone else, had few of the Zeus parts left, but it was cheap and I found a guy with a complete set of Zeus parts he sold at a fair price. I added the decals to it. The red one is original and complete and found on ebay. The red one is early 70s I believe, the other 2 later 70s. I had a copper one I sold that had a metal headbadge, I'd guess those even earlier. In the late 70s they came out with a more highly developed line of parts, but I know nothing of those. I'd guess ones with chrome were the higher end models. You didn't see them around much in the 70s, but there sure seem to be a lot around now! I think they're pretty cool and different.
Almost all my bikes are 5-speed, maybe a couple of 6-speed. I typically use 14/28 Suntours from ebay, though the red Zeus would only run a 24 for some reason.
car dodger
I guess here I should insert a pic of my restored zeus with mostly zeus parts...it can be done!
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Catalog scans? Where on earth did you find those?
car dodger
Thanks, mine was a proper road bike but I made it more upright / urbanish. I believe all the threading on it is french. I'm considering putting an ideale saddle I have on it but that would require using a non-zeus seat pillar.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
I see in dbakl's cat scans they actually list a Zeus leather saddles. Mine is an Ideale...........an 80TB I believe
I was cleaning the RD this afternoon, not the one I have pictured but a replacement, and even the jockey wheels are Zeus labeled.
Liked 3,015 Times
I like Zeus bikes 'cuz they're weird.
This quote sums up Zeus, and my feelings, well.
From my time researching Zeus I would agree that it is likely a late 60s frame. Much more documentation post 1973 and this frame does not match anything I have seen in my post Zeus 2000 introduction research.
Two things I have learned to watch for in Zeus frame identification, 1/2 chromed seat stays/forks and inlayed dots/triangles on the head tube lugs and forks.
I wouldn't rule out this being a competition model around 1970. Most likely, you'll come close but never know! Such is a life with an older Zeus!
Love my 1973 2000, it is in light blue and I wonder what shade of blue your frame was originally. It appears lighter near RD.
RiddleOfSteel
Classic & Vintage
34
07-17-18 01:36 PM
markk900
Classic & Vintage
21
10-01-15 05:01 PM
