What's your favorite clincher tire width for urban use?
What's your favorite clincher tire width for urban use on a fixed gear bike?
~ 23 mm, ~ 25 mm, ~ 28 mm, ~ 32 mm or wider?
canis lupus familiaris
Bikes: En plus one
I like 32mm or 35mm. It allows me to run a bit lower air pressure for a more comfy ride. The larger volume means I don't have to top them off so often. Also, larger tires seem easier to mount and dismount on my rims, so changing a flat whilst on the road is much easier.
Fixie Infamous
My Ultremos are labeled 23mm, but they sit almost 28mm wide on my rim.
So idfk.
So idfk.
Team Beer
Bikes: Too Many
Liked 161 Times
I prefer 28's for urban use. For me it's the right mix between fast and smooth.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
I'm riding 25 right now. I have had 28, 32 and 38 on my fixed. Didn't like the 38 much but they were very heavy commuter tires. Heavy even for a 38. But I think 25/28 is my sweet spot. My road bike has 23 and I commute on that sometimes and I really have never felt like "damn I wish I had wider tires!" when riding that one.
Kit doesn't match
How wide can the frame/fork handle?
I'm fickle and have run pretty much every damned width, and they all have trade-offs. But if comfort is a goal, then the fatter the better... That said, I've never run tires wider than 35 on a bike with road geometry.
Minimum of 28 mm, but usually I prefer a 32 mm tire, both as measured. I may end up going wider with lower pressure now that I'm going to be riding a lot on cobblestones.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Liked 8 Times
I used to ride 28s but my Hillbrick came fitted with 23s. I like them and because I can buy my favourite tyre really cheap in 23s, I've stuck with them. No real urge to go larger but then again, my only reason for sticking with 23s is as stated.
Bicycle Repair Man !!!
Looking at the little crew I see 25, 25, 32, 38, and 50... they all work well for their intended purposes.
The 700:38 tyres are probably some of my favourite tyres of all time (Avocet Cross)... the rollout and ride quality is second to none. Wider does not mean that a tyre has to be slow if it is designed right.
