Bottle Cage concerns?
Old 07-15-14, 07:47 PM
coolcamaro12
coolcamaro12's Avatar
Bikes: 2012 Specialized Tarmac Apex Mid Compact, 2013 Specialized Sirrus Elite, 2007 Giant Boulder se
I am going to buy a bottle cage for my bike, but I am concerned about tightening them down. Do the bolts require a specific torque amount considering almost every other component installed onto the bike does?
coolcamaro12 is offline
Old 07-15-14, 08:00 PM
pdedes
ka maté ka maté ka ora
pdedes's Avatar
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Liked 4 Times in 4 Posts
just don't strip the threads
pdedes is offline
Old 07-15-14, 08:07 PM
RoadTire
RoadTire's Avatar
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
If the cages are plastic or composite, don't tighten the bolts too much or you can stress or even crack the plastic. The damage might not show up for 6 months. Like everything else on the bike, a quick check for loose things should be a habit anyway.
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
RoadTire is offline
Old 07-15-14, 08:12 PM
coolcamaro12
Thank you! I am just really concerned about my first (and new) carbon frame. It just seems like I should be a little more careful than I have been with aluminum and steel bikes.
Old 07-15-14, 08:22 PM
jon c.
Liked 1,091 Times in 609 Posts
Avoid aluminum bolts (which are supplied with some cages). I put on new cages and within about 6 months the downtube cage bolts sheared off at the frame. Fortunately I wasn't riding, I taking the bike out of my truck at the LBS and when I set it down the cage popped off. I ride steel and they had to drill the remaining part of the bolt out of the frame (which might be a more delicate operation with a carbon frame). The LBS guys put in steel bolts and said they'd seen the same thing with other Al cage bolts.
jon c. is offline
Old 07-15-14, 08:56 PM
kleng
kleng's Avatar
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
always grease the bolts and don't install to tightly as you can strip out the bosses in the frame, once they are loose it's all over.
kleng is offline
Old 07-16-14, 07:36 AM
RL7836
If you want to go a step further, use rubber washers on both sides of the carbon/plastic cage. This provides a bit of a shock mount & keeps the hard edges of the screw from being a critical stress point. If you can't find a rubber washer, cut a piece of old inner tube to fit.
RL7836 is offline
Old 07-16-14, 08:10 AM
gatortoes
What Kleng said. Just tighten them finger tight, then maybe a quarter turn with an allen key. Just as long as the bottle cage doesn't rattle around it should be fine.
gatortoes is offline
Old 07-16-14, 03:07 PM
coolcamaro12
Great advice, Thank you everyone
Old 07-17-14, 12:12 AM
CactoesGel
CactoesGel's Avatar
Bikes: Émonda SL 6
Thanks to everyone as well, learned something here.
CactoesGel is offline
Old 07-17-14, 12:26 AM
FIVE ONE SIX
SpIn SpIn SuGaR!
FIVE ONE SIX's Avatar
i can't stress this enough! and that doesn't just pertain to cage bolts...
i didn't grease mine the last time, and something happened to the threading on the seat tube threads so now they go in further before they catch, so i had to go to Lowe's to get 20mm long bolts for those two. the original ones are usually 14mm or 15mm long, depending on the brand...
FIVE ONE SIX is offline
TCR Rider
Bicycle Mechanics
19
10-23-17 09:36 PM
Chris516
Bicycle Mechanics
7
10-10-12 08:53 AM
Boofhust
General Cycling Discussion
19
06-11-12 07:17 PM
yongkun
Road Cycling
30
11-29-10 09:43 PM
tuxbailey
Road Cycling
23
09-20-10 10:52 AM
